Help- Need to go larger tires and so think LT
Discussion in '5th Gen 4Runners (2010-2024)' started by Vandal6, Feb 21, 2024.
  1. Feb 21, 2024 at 5:44 PM
    Vandal6
    Vandal6 [OP] New Member
    Bryan
    2016 4Runner Trail
    IMG_5713.jpg Sorry for the long post but I posted on one Facebook group and several “Digital Creators” could not stop commenting like I bought my 4Runner last week and want a fancy setup for the mall. Trust me, I can’t afford to buy a setup for looks, just like I can’t afford to take the 4Runner out and break components regularly. I’m good with armor and I do take it off road.
    I live in Virginia and have traveled to PA, WV, and NC, so I’ve done some east coast rocky trails to a mild rock garden and would like to step up to doing more, so I’m looking to go up to 317’s or 35’s” with a strong setup.
    I’ve had the Bilstein 5100s and 285/70r17 Nitto Ridge Grapplers for four years and want to buy once, and need to start buying soon and figuring out if I need to delete the KDSS. I’ve been looking at the Marlin Crawler RCLT for more two years but there’s no way I can justify that purchase. I’ve also been looking at the Dobinson’s MRR, Total Chaos, Wicked Creations, and am starting to lean towards the JD Fabrications 2.25" long travel kit. Anyone familiar?
    Here’s what I like about the JD Fab kit: (1) rebuildable Kings, (2) pushes the tires forward some just like the RCLT, (not as much, I know) to reduce chopping and banging and help with caster, and (3) less expensive axle solution (RCLT uses RCV and people have issues with the boots). They also state at the bottom that they recommend some other components which seems like it moves closer to the RCLT but still a significant reduction in cost.
    https://jdfabrication.com/collectio...tion-4runner-03-109-6-lug-4-long-travel-kit-1
    Appreciate any help.
    djwantke likes this.
  2. Feb 21, 2024 at 6:06 PM
    LT is not going to help fit larger tires and you will most likely need fenders to accommodate your current size and larger when at full compression.
  3. Feb 21, 2024 at 6:31 PM
    HazOpRed
    HazOpRed 22' TRDOR
    What does long travel have to do with tires? Just go skinny 34's
  4. Feb 21, 2024 at 7:29 PM
    Vandal6
    Bryan
    2016 4Runner Trail
    The LT is for better articulation, and don’t the control arms need to be upgraded when you go 2.5”?
  5. Feb 21, 2024 at 7:48 PM
    steelevo
    Utah
  6. Feb 21, 2024 at 7:55 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Thanks for the info
    Can you explain the fenders apart
  7. Feb 21, 2024 at 7:57 PM
    Hey OP
    So I have KDSS and did 3" front, 2" rear lift with aftermarket lift springs and Bilstein 5100's on all four corners. I also got SPC UCA's w/ sealed bjoints.
    I could use one or two KDSS correction parts, it's certainly on the to do list, but money is the issue like you've stated.
    But I don't think deleting KDSS is something one should do, in your situation. I haven't seen anyone actually do so here. Could be wrong but if your saying 2.5" lift? You arguably don't need much KDSS correction either.
    I ain't know much about LT tho if you can't tell
  8. Feb 21, 2024 at 8:05 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Why did you buy the KDSS that you want to delete now? Don't go higher than 34s, spend money on steel bumpers and skid plates.
    If you wanted 37s or higher, you bought the wrong vehicle. 37s won't make a 4Runner Jeep either. Don't ruin your nice truck, trade it in for a Jeep if rock crawling is your thing.
    Slopemaster likes this.
  9. Feb 21, 2024 at 8:11 PM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    djwantke, Slopemaster and Yotaholic like this.
  10. Feb 21, 2024 at 8:16 PM
    Yotaholic
    Olympia, WA
    IFS and smaller tires are not the only problems of our truck, it is also the angles, it is too long for a rock crawler. That's true for the Jeep Gladiator too. If hardcore rock crawling is your thing, buy an old TJ and build it into a dedicated rock crawler. You will not only waste your money on the 4Runner, but you will also ruin it. Keep your 4Runner light so that it can tow your TJ to Moab lol
    1SilverRunner likes this.
  11. Feb 21, 2024 at 8:24 PM
    Yotaholic
    Olympia, WA
    Leave that poor truck alone. Go buy one of these lil things and bash it on the rocks.
    Ironguy and djwantke like this.
  12. Feb 21, 2024 at 8:31 PM
    Fenders meaning fiberglass fenders. These are AVD:
  13. Feb 21, 2024 at 8:32 PM
    Betcha Newman wouldn't have died if he had a 4Runner and winch :p
  14. Feb 21, 2024 at 8:33 PM
    Riiiight fiberglass
    Thank you
  15. Feb 21, 2024 at 9:16 PM
    Excellent video, really shows what a 5th gen is capable of.
    Thanks for sharing
  16. Feb 21, 2024 at 9:34 PM
    Yobruhitsme
    Denver
    Ineos Grenadier
    Dude’s channel is crazy!
    just a lift, full armor and k02s. No other superficial mods
  17. Feb 22, 2024 at 9:42 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    Long Travel means replacing the upper/lower control arms, long axles, long travel shocks (notice I didn’t say extended shocks), longer break lines, possibly positive offset wheels (at least zero offset), tie rod extensions. Then you’ll want to do something with the rear axle like small spacers, maybe tundra shocks, break lines again. And really a litany of other considerations (regear, lockers cuz why not it’s only money!, reinforcing shock mounts, upgrading breaks for massive tires, power steering). Then you get into bumpers for your winch and spare tire.
    It’s a big rabbit hole for sure! You’ll find yourself equipped with racing parts that demand racing parts maintenance too!
    Begin with the end in mind, plan your build around your use case. Maybe LT will still be the way to go. If so, I’ll see you in the rabbit hole :spending:
  18. Feb 23, 2024 at 4:30 AM
    Vandal6
    Bryan
    2016 4Runner Trail
    Yea, trying to keep this concise because it’s in my original post. My question was response to doing the lift without the other components. The fact is that my goal is wheel it a little harder. I got the tires and Bilstein’s five years ago have probably spent everyday since reading and watching videos, I even a spreadsheet with what I believe are pretty costs ranging from RCLT HD, Total Chaos Expedition Series, Dobinson MRR, and a JB Fabrivation LT kit and lower pivot kit. Trail4R.com did a review on the lower pivot.
    I have friends who tow a rig to the trail, I don’t want to go that route, but I have to drive 3+ hours from SE Virginia to go anywhere.
    I came on here because I don’t have a good shop nearby to discuss. I think a meetup will be better.
    https://trail4runner.com/2023/12/03...control-arm-pivot-kit-5th-gen-4runner-review/
  19. Feb 23, 2024 at 6:53 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    This^ I love the 4Runner platform for what it is but building a rock crawler out of it defeats the purpose imo. A basic mid travel kit and 33's will get you most places you need to go and maintain Toyota reliability.
    If you want to spend over $100,000 then convert the 4R into a rock crawler sure. But it makes absolutely no financial sense... If you've got a ton of money and you can afford to break shit and replace shit all the time, then sure. If this is your daily and you "don't have money to break parts all the time" then I'll ask you to come back to earth...
    https://www.youtube.com/watch?v=g9xk6-Y1w84
    A dream build like this is awesome but it's not attainable for most people. You're talking about 150,000 dollar vehicle without any labor calculated... For what? To take it out a few times a year? When are you going to need the extra capability? Is it worth $150,000 +
    2021venture likes this.
  20. Feb 23, 2024 at 7:13 AM
    dgtulsaguy
    dgtulsaguy Rocklanding Jedi Master equivalent
    22 MGM ORP long travel
    I've put about 10k on a +2.75 RCLT kit over the last year. LT is a ton of work to get going and even more maintenance than you'd expect if you actually use it. It is SOOO worth it.
    I'm double locked on 35's and cutting for 38's now. I have no hesitation tackling a 1k mile road trip and hitting hard trails when I get there. I put my rig through the same trails as my friends with dana 60's on the regular. I can hit speeds of 70 or 80 on the highway without issue. If you're handy and plan on going hard then do it.
    Thacrow and MEski4x4 like this.
  21. Feb 23, 2024 at 7:16 AM
    dgtulsaguy
    Also, if you have a grinder you don't need expensive fenders lol
  22. Feb 23, 2024 at 7:25 AM
    1SilverRunner
    Tejas
    How much money did you spend on the long travel kit, wheels and tires? Regeared to 4.88s as well?
    Also, is this your daily?
    I'm glad you're out there using it! I know many people personally with very expensive setups who hardly go use them. Maybe they'll go out 2-3 times a year.
  23. Feb 23, 2024 at 8:50 AM
    dgtulsaguy
    It isn't cheap, about the same ballpark as a SAS. Haven't split out those specific items but I have a spreadsheet I can share with people who are serious. Upgrades tend to snowball once you get into it.
    It has revolution 4.88's and an arb up front. I split daily duties between it and my Tundra. It see's around 1k of pavement a month, at least a weekend or two of wheeling too.
  24. Feb 23, 2024 at 8:54 AM
    Vandal6
    Bryan
    2016 4Runner Trail
    I’ve been tracking RCLT since they announced the prototype. Please look at my original post, and I’d love to see your spreadsheet to compare to mine.
    dgtulsaguy likes this.
  25. Feb 23, 2024 at 9:07 AM
    dgtulsaguy
    Total Chaos makes a kdss compatible kit that works well if you want to keep it. I wheel with a LC that has TC and KDSS, he does work on the trail with that big body! JD makes some AWESOME stuff too, can't go wrong with it. I've also seen Dirt King in action and love their products.
  26. Feb 23, 2024 at 9:48 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    You need to come back to reality and reset goals and expectations accordingly.
    Unless of course you're looking to spend 10k minimum and cut your fenders or replace them with fiber glass.
  27. Feb 23, 2024 at 9:48 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Respect
  28. Feb 23, 2024 at 10:46 AM
    nova
    nova New Member
    mike
    I think the jd-fab pivot kit would be a non-LT option. Why? Because I think (someone should fact check this b/c what do I know?) the LT systems might already move the axle forward. I called Total Chaos and they told me that the +2 and the +3.5 kits move the axle forward, but they would not divulge the amount. So you'd need to make sure that compounding the two would be copacetic.
    If LT isn't your cup of tea, the pivot kit combined with extended travel shocks sound interesting. As many have stated, lifts do not actually help fit 35s. Cutting, tubbing, messing with body mounts, and alignment are the ingredients for successfully fitting 35s (but still creating other issues like gears, breaking, steering). This should be required reading:
    https://www.coastaloffroad.com/clearing-35-tires-at-any-ride-height/
    Choose your adventure, but choose wisely and I'll see you out there!
    1SilverRunner and dgtulsaguy like this.
  29. Mar 6, 2024 at 11:14 AM
    dgtulsaguy
    You can run both the JD fab pivot and LT. The truck in the thread linked does and I've been eyeing one myself:
    https://www.tacomaworld.com/threads/rclt-hd-2-75-travel-numbers-and-notes.771723/
