Help me identify a driver's side leak?
Discussion in '4th Gen 4Runners (2003-2009)' started by 2nd_runner, Apr 19, 2024.
  1. Apr 19, 2024 at 1:25 PM
    2nd_runner
    2nd_runner [OP] New Member
    2007 4Runner SR5
    Hey folks, new around here. Hello!
    I've got an '07 4Runner Sr5 with ~166k miles. Noticed some ground drip on the driver's side. Took a look and there's a fair amount of... something leaking. Maybe oil? But it doesn't feel very oily to the touch. Attaching a pic here. I also have a video, but doesn't look like that's an uploadable format. Can anyone identify that part? It might be that hose that's leaking.
    Also, maybe unrelated, I opened up the engine oil cap- it smelled of gasoline and there was some smoke swirling around (just after driving). That normal?
    Thanks!
  2. Apr 19, 2024 at 1:58 PM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    got any more pics?
  3. Apr 19, 2024 at 2:24 PM
    2nd_runner
    2007 4Runner SR5
    Yep. Let me know if these are helpful. I can go out and grab more if needed
  4. Apr 19, 2024 at 3:28 PM
    Old goat
    Old goat Trout chaser
    Hudson Valley NY
    5th gen
    Looks like it may be from area of rubber hose where clamp is? If it’s an original hose it could be there
  5. Apr 19, 2024 at 3:29 PM
    2nd_runner
    2007 4Runner SR5
    That's what it looks like to me too, but any idea what that part is? Or what the fluid is?
  6. Apr 19, 2024 at 3:35 PM
    hvac guy
    hvac guy New Member
    Looks like the power steering (rack and pinion leaking)?, it takes ATF fluid (dexron III) I believe. Check the power steering fluid level
  7. Apr 19, 2024 at 3:42 PM
    Old goat
    Hudson Valley NY
    5th gen
    The position of the clamp looks a little low on the fitting, may try to reposition the clamp a hair higher..may help..looks like a low pressure return line
    icebear and 2nd_runner[OP] like this.
  8. Apr 19, 2024 at 6:27 PM
    2nd_runner
    2007 4Runner SR5
    The power steering fluid was indeed low. I repositioned the clamp and topped off. Will give it another look in a couple days. Thank you to those who chimed in!
    4R777 and icebear like this.
  9. Apr 19, 2024 at 7:19 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    To find exactly where the leak is, clean all the leaking fluid off of everything shown in your photo with brake cleaner, then check it a couple of times every day until you can see where the leak is or if it's indeed fixed, if moving the clamp failed to solve the issue, then you can proceed to attempt to fix it!!
