Help Installing LED Bar
Discussion in 'Lighting' started by seattle_submariner, Dec 25, 2020.
  1. Dec 25, 2020 at 10:25 AM
    seattle_submariner
    seattle_submariner [OP] New Member
    Hi -
    I am trying to install a Behind the Grill LED Bar for my 2017 4Runner.
    I am stuck on the very first step! What I am trying to do is install the mounting bracket on the front impact bar. Here is a link of an image from the instructions of an installed mounting bracket. As you can see, I have to unscrew one of the existing bolts on the impact bar, place the mounting bracket on, and then screw the bolt back on. Since I can access this bolt without having to totally remove the full bumper, I am trying to access this bolt from over the top.
    The problem is I can't unscrew the bolt! I pushed firmly, but it isn't giving and I wanted to get your opinion on what to do first before trying other measures (I don't want to strip or break something!)
    Thank you!!!
  2. Dec 25, 2020 at 10:34 AM
    gunsnob
    gunsnob New Member
    Vince
    2019 4Runner TRD ORP
    Are you supposed to remove the front bumper?
  3. Dec 25, 2020 at 10:48 AM
    4Runner170V
    4Runner170V New Member
    Tony
    Los Angeles
    2014 4Runner Trail
    Remove front bumper for full access. It is easy steps and will take no more than 10min.
  4. Dec 25, 2020 at 11:03 AM
    seattle_submariner
    So if I remove the front bumper, I should be able to loosen the bolt by pushing hard?
    gunsnob likes this.
  5. Dec 25, 2020 at 11:06 AM
    4Runner170V
    Tony
    Los Angeles
    2014 4Runner Trail
    Removing the front bumper will give you full access to impact bar. if needed, you can even remove impact bar and work on LED installation, then re-install impact bar.
  6. Dec 28, 2020 at 9:42 PM
    seattle_submariner
    hey, closing the loop on this. I pulled the bumper and was able to install the bar!
    SlvrSlug, gunsnob and 4Runner170V like this.
  7. Dec 28, 2020 at 9:45 PM
    gunsnob
    gunsnob New Member
    Vince
    Good job. Glad it worked out for you.
  8. Dec 29, 2020 at 7:30 AM
    Thanks for the follow up.
