Help fan wobble/grinding noise
Discussion in '3rd Gen 4Runners (1996-2002)' started by 7754runner, Apr 5, 2023.
  1. Apr 5, 2023 at 5:26 PM
    7754runner
    7754runner [OP] New Member
    Victor
    2002 sr5
    None
    Hi I'm a new member
    I bought a 2002 4runner sr5 V6 from a co worker.he told me about a grinding noise coming from the cooling fan and on the way home a belt snapped I ended up buying a timing kit thinking it was the water pump put it all in fired it up and still had the same issue I noticed a wobble in the pulley and fan I think it could be maybe the fan clutch what do you guys possibly think I'll upload a video thanks
  2. Apr 5, 2023 at 5:41 PM
    7754runner
    Victor
    2002 sr5
    None
  3. Apr 5, 2023 at 8:06 PM
    CygnusX-4
    CygnusX-4 Member
    21 TRD OR
    With the engine off, spin the fan by hand, it should feel stiff but smooth. There is a bearing in the part called the fan stay. Its that bracket on the front with the studs for the fan. I would be suspicious of that, they go bad often. Never seen one snap a belt though...
  4. Apr 5, 2023 at 8:17 PM
    CygnusX-4
    CygnusX-4 Member
    21 TRD OR
    Just to be clear, to feel the bad bearing in the fan stay you will need to spin it with the drive belts off. To feel bad clutch, spin fan with belts on.
    7754runner[OP] likes this.
  5. Apr 5, 2023 at 8:34 PM
    7754runner
    Victor
    2002 sr5
    None
    I'll def check that out tomorrow
    Thanks
    CygnusX-4 likes this.
  6. Apr 5, 2023 at 10:14 PM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    Is there a reason you have the radiator cap removed?
  7. Apr 6, 2023 at 12:36 AM
    7754runner
    Victor
    2002 sr5
    None
    Yes I was burping the coolant
