Help…fuse location ?
Discussion in '5th Gen 4Runners (2010-2024)' started by Piney, Sep 12, 2022.
  1. Sep 12, 2022 at 4:46 PM
    Piney
    Piney [OP] New Member
    2021 Cement trail edition
    None
    Left key accessory on in my vehicle overnight & completely drained the battery….yes my ‘21 still has an actual key !
    So I had to jump start it with my Noco jumper in override mode.
    Vehicle cranked & then suddenly died again 5 seconds later. 2nd attempt, vehicle cranked & stayed running.
    Drove approx 50 miles & everything is fine. Battery recharged itself, all controls lights work etc. however, I can’t roll my 2 rear widows up or down from the drivers control pad. They operate fine from the rear control buttons so the motors are functional.
    I pulled all 4 fuses related to door or power windows (inside fuse panel) & none “appear” blown. Does anyone know the exact fuse location for driver rear window operation ?
  2. Sep 12, 2022 at 6:01 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    I believe there is a window reset procedure after disconnecting the battery. A dead battery would behave like a disconnected battery to the vehicle. At least there was on my 4th gen. Check the manual. May not be fuse related.
    Piney[OP] and kolter45 like this.
  3. Sep 12, 2022 at 6:12 PM
    Piney
    None
    Here’s a link…worked like a charm & I only cycled the widows once.
    https://youtu.be/K_AGepBE9Is
    2Toys and TrueTexas[QUOTED] like this.
  4. Sep 12, 2022 at 6:34 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Not an answer but FYI dying after the first start in the situation you had is normal.
    Piney[OP] likes this.
