Hello and Help!
Discussion in '5th Gen 4Runners (2010-2024)' started by TonyLaz, Jan 6, 2022.
  1. Jan 6, 2022 at 10:06 PM
    TonyLaz
    TonyLaz [OP] New Member
    Tony
    2012 4Runner Limited
    Hello! My name is Tony, I’m new to the 4Runner forums. Happy to be here, and I need some help.
    I have a 2012 4runner limited and I need to replace the front shocks. I have tried looking for a good replacement for daily driver with very light off-road/overlanding and improved ride comfort/quality. I have two problems though. I cannot decide on the best, and also, what about the X-reas system?
    I believe that I have the x-reas system, and I can’t find any stock or aftermarket shocks that utilize this. Do I then have to remove/eliminate the x-reas system, and should I?
    Thanks ahead of time for the help.
  2. Jan 6, 2022 at 10:37 PM
    7385, Thatbassguy and SlvrSlug like this.
  3. Jan 7, 2022 at 2:08 AM
    Welcome from Wisconsin!
    7385 and Thatbassguy like this.
  4. Jan 7, 2022 at 7:16 AM
    Welcome to the forum.
    Toy4X4, 7385 and Thatbassguy like this.
  5. Jan 7, 2022 at 7:23 AM
    TonyLaz
    Tony
    Thanks Gary. That’s what I’ve been leaning to. I was just unsure of what to do with the xreas. Can I just unplug it and leave it on the rig?
  6. Jan 7, 2022 at 7:23 AM
    TonyLaz
    Tony
    Thanks Jeff!
    Toy4X4[QUOTED], 7385 and Thatbassguy like this.
  7. Jan 7, 2022 at 7:23 AM
    TonyLaz
    Tony
    Thank you John!
    7385 likes this.
  8. Jan 7, 2022 at 7:25 AM
    Welcome to the forum from Wisconsin!
    And, +1 to what @glwood54 said. :)
    Toy4X4 and 7385 like this.
  9. Jan 7, 2022 at 7:33 AM
    XREAS can only be purchased from Toyota Dealer if you want to go with the same XREAS.
    But you can remove XREAS from a good Toyota 4wd shop and get any shock fits 4runner from basic Bilstien to high-end Kings.
  10. Jan 7, 2022 at 9:40 AM
    TonyLaz
    Tony
    Thanks James. Appreciate the insight.
  11. Jan 7, 2022 at 9:42 AM
    TonyLaz
    Tony
    Thanks kmeeg, I’ll probably just leave it on the rig, unless anyone knows a reason that I can’t?
  12. Jan 7, 2022 at 10:01 AM
    If you switch to aftermarket shocks, you lose XREAS. Only the OEM shocks are compatible, and you'll have to pay whatever the dealership is asking. Or, you can usually find OEM parts online for cheaper than some dealers.
  13. Jan 7, 2022 at 10:01 AM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    Rip out XREAS. Lift.
  14. Jan 7, 2022 at 10:06 AM
    Malchango
    Malchango New Member
    Asher
    2011 Silver Limited 4RUNNER
    3” OME, 275/70/R17, Victory roof rack, Victory front skids, RSG sliders soon
    I have an 11 T4R Limited and recently installed OME front and rear, as well as SPC UCA’s. I’m happy with the result and it was a very straightforward process. Removing the Xreas system was simple. Just make sure to remove it where it connects at the Union bolt not the shock. Most shops won’t remove the Xreas lines they will just bend them up out of the way. It took me about 30 minutes to get it disconnected and removed.
  15. Jan 7, 2022 at 10:09 AM
    I'm not very happy with OME. I got Bilstien5100 now and is much better than OME for my taste..:)
  16. Jan 7, 2022 at 10:11 AM
    Malchango
    Asher
    That was definitely on the board for one of my choices as well. Unfortunately due to availability issues the wait was too long. What didn’t you like about it?
  17. Jan 7, 2022 at 10:18 AM
    What I don't like about OME Nitro - It give me the bumps on the road on local roads little harsh way. Feel little tired after long drives.
    What I like about OME Nitro - They are amazing to be abused on trails. Driving over hard bumps and dips at higher speeds. Little jumps are fun and very tempting.
  18. Jan 7, 2022 at 11:35 AM
    Bikeric
    Bikeric New Member
    Eric
    2003 V8 4x4 ARB Locked and Lifted on 35's with 4.88's
    Tony, you CANNOT replace just the front shocks with aftermarket if you currently have XREAS. You will need to replace the shocks at ALL 4 corners. You might as well do it because stock Toyota XREAS replacements cost more than King's or Fox's.
    I went the cheapo lift route and bought Rancho QuickLift pre-loaded struts ($400/pair) for the front of my daughters 2011. I then did a rear spacer and +1" store brand shocks from 4WheelParts ($40/each).
    Welcome,
  19. Jan 7, 2022 at 3:51 PM
    TonyLaz
    Tony
    Thanks!
  20. Jan 7, 2022 at 3:53 PM
    TonyLaz
    Tony
    Thanks Eric. I was planning on doing all 4. What did you think about the Rancho QuickLift? Was the ride quality good? Mine is a daily driver, so I want a decent ride, but good overlanding capability.
  21. Jan 10, 2022 at 7:06 AM
    Bikeric
    Bikeric New Member
    Eric
    The Rancho QuickLift's provide a great ride on the street. They are not heavier rate springs for armored bumpers and winches, but are just slightly taller than the factory strut. They are more intended for the lifted look and wouldn't be the top choice if you're adding a bumper and winch.
