HEATER NOT PROVIDING HEAT
Discussion in '4th Gen 4Runners (2003-2009)' started by yoho360, Aug 18, 2022.
  1. Aug 18, 2022 at 9:01 AM
    yoho360
    yoho360 [OP] New Member
    Chris
    2004 4Runner SR5 V8
    none
    Hello everyone! My heater isn't blowing any heat AND there's a whirring sound coming from the passenger dash. Looking for any suggestions or jumping off points to look into before sending it in. Thanks in advance!
  2. Aug 18, 2022 at 11:43 AM
    ian408
    ian408 New Member
    Ian
    5th Gen TRD Offroad Pro - Super White
    Pls Stdby
    You don't say what model year. Heaters require hot water from the engine which flows through the heater core. The fan is what you probably hear running. Check the carpet on the passenger side for dampness. If it's damp, the core is leaking. First, check for engine over-temp and then for any blown fuses that are related to t the heater. When the engine is cold, check the coolant level and check the coolant overflow and be sure there's coolant in both (the radiator should be full and the coolant overflow, at the limit marks).
  3. Aug 18, 2022 at 12:01 PM
    yoho360
    Chris
    2004 4Runner SR5 V8
    none
    Thanks! It's a 2004 sr5 v8. I'll check the passenger carpet. I haven't notice a change in engine temp at all.
  4. Aug 18, 2022 at 4:13 PM
    mousemeat
    mousemeat New Member
    Memphis, TN.
    1997 4 runner limited
    heater core. again, check passenger area carpet..and go from there.
