Headlight removal
Discussion in '5th Gen 4Runners (2010-2024)' started by glwood54, Apr 20, 2022.
  1. Apr 20, 2022 at 6:32 AM
    glwood54 [OP] Stop making me buy stuff!
    I'd like to remove my passenger side headlight to access the inside of the bumper cover...I know it's held in by 4 bolts...is it possible to remove the outside bolt for that headlight without removing the bumper cover?
  2. Apr 22, 2022 at 9:32 PM
    ProRunner
    ProRunner New Member
    I didn't technically remove my bumper cover when I swapped headlamp assemblies. I didn't want to remove the entire bumper because of the hidden winch, so I managed to remove and install the assemblies by just unclipping the sides of the bumper. The hard part was getting the outer bolt of the assembly with the cover still on. You still have to take out the bolts/clips on the fender well, but if you just need access on one side, you could get away without removing the whole cover. It's easy enough to remove the entire bumper, and you're less likely to break any clips.
    392194d1643771606-texastjs-2017-t4r-trd-_201a7dff18cb3a277e6a90b60045e6233756a270.jpg
    392193d1643771595-texastjs-2017-t4r-trd-_a9fd32f59575745aeeeac58d3313d77e3b9be2a7.jpg
  3. Apr 22, 2022 at 10:17 PM
    blksubykid
    blksubykid New Member
    Its honestly not that difficult. After you get it off once, it’s a walk in the park every other time
    BionicRandy likes this.
  4. Apr 22, 2022 at 11:49 PM
    DallasTRDPro
    DallasTRDPro New Member
    Dallas
    2021 Honda CRV...UGH!
    Be careful the side clips can break easily.
