Headlight Bulb Replacement--Help Appreciated
Discussion in '4th Gen 4Runners (2003-2009)' started by geo2007, Jan 4, 2025.
  1. Jan 4, 2025 at 9:12 AM
    geo2007
    geo2007 [OP] New Member
    George
    I have a 2007 4Runner V6 and would like to replace the headlight bulbs as the original bulbs are far too dim and yellow for night driving. However, I do not want to create any computer error issues, or adapt to fan-type bulbs if that requires modifications. I would like to replace with LED or HID, if that's possible that are plug and play. I'd appreciate any recommendations from others who have made a successful change to a brighter bulb.
  2. Jan 4, 2025 at 9:21 AM
    welcome
  3. Jan 4, 2025 at 9:53 AM
    geo2007
    George
    Thank you! I’m happy to learn of this forum as I’ve owned my 4 Runner since new and still running strong after 184,000 miles. However, now in my seventies the headlights are just not bright enough for night driving and hope I can get advice from others who have made a change to a brighter bulb.
  4. Jan 4, 2025 at 10:30 AM
    wolfpack3
    wolfpack3 New Member
    Alberta
    2007 v8 Sport 4x4
    LOSTR4 likes this.
  5. Jan 4, 2025 at 10:40 AM
    geo2007
    George
    Thanks, Wolfpack. Were these bulbs a direct fit, no modifications necessary? Did the LEDs produce any light scatter over the halogens? Lastly, did you get an error codes on the computer system when changing to LEDs?
    wolfpack3 likes this.
  6. Jan 4, 2025 at 10:59 AM
    Hey welcome. I have a gen 5 so I won’t be able to help You much. The only tip I would say is if you’re going with led find a level place 30 feet from a wall. Take some tape and mark where your old ones hit then replace them with led and and adjust accordingly. I’ve seen some posts where people mention the led light pattern may be a little different. Plenty of YouTube videos. Best of luck. Happy New year to you
    geo2007[OP] likes this.
  7. Jan 4, 2025 at 11:38 AM
    wolfpack3
    Alberta
    2007 v8 Sport 4x4
    No mods. Direct fit. No codes. No scattered light. Takes only a couple of minutes. Easy peasy. Do it. No brainer! : )
    geo2007[QUOTED][OP] likes this.
  8. Jan 9, 2025 at 9:42 PM
    esamos
    esamos New Member
    2006 Limited V8 4wd
    I did all auxito. Got them off Amazon. They had a hi/low beam led combo, front and rear blinkers, reverse lights, parking lights and fog lights. Zero issues. Very bright and work great. Nice and bright and would highly recommend.
    geo2007[OP] and LOSTR4 like this.
  9. Jan 10, 2025 at 5:15 PM
    LOSTR4
    LOSTR4 New Member
    Just a couple
    I recently bought the Morimoto 2stroke version 4 LED bulbs...they are fantastically bright and plugged right in with their supplied adapter harness...took all of of 20 min to do...they do have fans but if you listen to the radio/music, you'll never hear them...my ONL gripe is they have fans. They've been installed for 4 months with zero issues...:plane:
  10. Jan 10, 2025 at 6:09 PM
    On a 5th Gen ( Not 4th as OPs);
    The brightest LEDs I've tried are Hikari Titanova H11
    https://amzn.to/3C59yWA
    I came across LED called Novsight N70. They seem to draw stupid power a relay harness is included in the package.
    (They don't have Amazon link. When I try to copy the link from their site it's too long and messy. So not sharing here. But should be easy to search and find it.)
  11. Jan 10, 2025 at 9:38 PM
    LOSTR4
    LOSTR4 New Member
    Just a couple
    Those do look good! I'd definitely consider a relayed harness anything over 50w!
  12. Jan 12, 2025 at 9:13 AM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Beware LEDs with fans. EM interference triggering phantom ABS faults is a known issue. I had my LED bulbs for 3 years before it happened. Toyota issued a TSB for 5th Gens but it can happen in 4th Gens too.
  13. Jan 12, 2025 at 10:13 AM
    LOSTR4
    LOSTR4 New Member
    Just a couple
    True, I'm hoping the 4th version of my 2strokes are enough...so far, all good, but it's only been part of a year...will keep folks updated as the months tick by...
