Having trouble replacing stock horns with FIAMM Low tone and High tone horns
Discussion in '4th Gen 4Runners (2003-2009)' started by LongsPeak95, Oct 7, 2023.
  1. Oct 7, 2023 at 6:51 AM
    LongsPeak95
    LongsPeak95 [OP] New Member
    Tampa
    2005 4Runner SR5
    I am replacing the stock horns with a pair of FIAMM Highway Blaster horns. I tried installing them according to the instructions, but one of the horns will not work and I have confirmed that the horn is not faulty.
    One of the stock horn's factory connectors had two wires in it. The other horn's connector had just one. The FIAMM horns both have two male blade connectors.
    I attached female blades to each of the wires from the dual-wire horn and connected those to one of the new horns.
    I attached a female blade to the other wire, the single wire to the other stock horn, and connected that to one of the other new horn's terminals. A short wire with a female blade on one end and an eyelet on the other was provided, and that was to be connected to that horn's other terminal, and the eyelet was to be attached to the rear of that horn using the bolt that attaches the horn to the mounting bracket. See attached photo.
    The problem is that only one horn; the one with the dual wires, works. I disconnected those dual wires and attached them to the other horn, but then neither worked. I left those attached and connected the single wire to the first horn, and neither worked.
    So I only have one working horn; the one with the dual wires, and it only works if the other horn is connected to its wire.
    What am I doing wrong? I appreciate the help! This is frustrating.
    https://www.amazon.com/dp/B000DINKPQ?ref=ppx_yo2ov_dt_b_product_details
    https://www.amazon.com/dp/B000FKKOK6?ref=ppx_yo2ov_dt_b_product_details
  2. Oct 7, 2023 at 8:57 AM
    It has to be grounded. Or your grounding it by mounting to metal and it’s not supposed to be?
  3. Oct 7, 2023 at 8:58 AM
    I just put one on the sandrail had to mount it to plastic.
  4. Oct 7, 2023 at 9:13 AM
    LongsPeak95
    Tampa
    2005 4Runner SR5
    Are you referring to the horn with the single wire?
    If so, I have connected that metal eyelet to the bolt that holds the horn to the chassis, as well as I have it pictured above. It doesn't work either way.
