grinding gears shifting into 4L
Discussion in '5th Gen 4Runners (2010-2024)' started by Montanawildlives, Dec 2, 2025.
  1. Dec 2, 2025 at 1:47 PM
    Montanawildlives
    Montanawildlives [OP] New Member
    My 2024 OR runs fine in 2H and easily shifts into 4H at normal speeds. But, when I try to shift into 4L I get grinding gears. Of course, I stopped and put it in neutral first.
    From 4H, stopped and in neutral, when I push the 4x4 level to the right and up, it goes to the right but when I push it up the gears start grinding. From that point, I can’t move it forward or back without the gears grinding. Today I had to put it in park and turn off the engine before I could shift back through 4H to 2H. In fact, this only worked 2/3 times—once I could not shift the 4x4 lever back to the left even with the engine off. Turning the engine on and off again then let me do that.
    The first time I noticed this was a few months ago but it made the noise momentarily and then let me go into and out of 2L. I think today was the next time I tried.
    Any thoughts? I have never used 4L much—mostly just put it there every few months and run through the options (A-trac, etc.) to wake everything up.
    Thanks.
  2. Dec 2, 2025 at 1:48 PM
    Are you shoving the lever where you want it? I hear that's the way to shift.
    werlyb23 likes this.
  3. Dec 2, 2025 at 1:53 PM
    2019 TRDP w/Kangs brah!
    alittleoff, BS67, ChessGuy and 2 others like this.
  4. Dec 2, 2025 at 1:57 PM
    Montanawildlives
    ok, I’ll try that. I think that with the slightest hint of grind I’ve scared myself into being even more gentle, probably from 30 year old PTSD from wrecking the manual transmission in my chevette by ignoring a clutch problem and just cramming it into gear.
    Was going to edit to add that the AT/P light came on (a first for me), I think in the midst of maybe being in Park with 4x4 level in no-man’s land between 4H and 4L. I guess that is normal.
  5. Dec 2, 2025 at 1:57 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics XPR reverse bulbs LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    My 2022 did that until I swapped out the t case fluid w/ MT-LV. It seems better now. Also shifting fast kind of helps. Don’t force it, but don’t baby it into place either. Shift like you mean it.
    the more you do it the easier it will get
    If it was older I might recommend swapping the neutral safety switch. It’s counterintuitive since I used to think “I have a manual transfer case lever, that shouldn’t matter” but in reality everything is done with solenoids on these things. The t case lever is essentially asking permission. The ecu then checks position of all systems before sending the command. I’ve personally seen switching that neutral position sensor out make using the transfer case lever much easier.
    Again, with how new your 4Runner is I can’t imagine that sensors already going. Just shift like you mean it and it should get easier. If it doesn’t, go ahead and swap the fluid and report back
  6. Dec 2, 2025 at 2:01 PM
    1SilverRunner
    Tejas
    Exceptional video I enjoyed every second of it.
    I realize this sounds sarcastic but I’m being genuine lol
  7. Dec 2, 2025 at 2:04 PM
    It's a Toyota, it will handle you just grabbing gears.
    That light came on to warn you that park with the trans but neutral at the transfer case will not keep the vehicle from rolling.
  8. Dec 2, 2025 at 2:11 PM
    Have you seen my baseball?
  9. Dec 2, 2025 at 3:00 PM
    1SilverRunner
    Tejas
  10. Dec 2, 2025 at 3:02 PM
    Something about Mary. Appartly I said "throw it like a baseball" a couple of times.
  11. Dec 2, 2025 at 3:04 PM
    1SilverRunner
    Tejas
    It was funny. Usually sports references aren’t my thing.
    Not a fan of watching men play with their balls
  12. Dec 3, 2025 at 2:14 PM
    Montanawildlives
    Thanks everybody, that did the trick! I think at the first hint of a grinding noise (just being lazy or slow or tired or absent minded one time), I got more and more gentle with it, and so it got worse and worse. Thanks!
    Now, off to watch Something about Mary!
    icebear and whippersnapper02 like this.
  13. Dec 3, 2025 at 5:17 PM
    Try not to get hair gel on the headliner.
    whippersnapper02 likes this.
