Grill upper/TRD pro heritage grill installation info (2020)
Discussion in '5th Gen 4Runners (2010-2024)' started by Gamma Ray, Aug 25, 2020.
  1. Aug 25, 2020 at 7:19 PM
    Gamma Ray
    Gamma Ray [OP] Be excellent to each other
    2020 SR5 Barcelona Red
    I noticed a couple things when installing my TRD pro heritage grill yesterday on my 2020. Specifically about the grill upper part. I expect that this info would also be useful if you ever go back to stock or if you need to replace your stock grill upper with another grill upper with the large Toyota emblem and the chrome. While I did this on my 2020, some if not all of the info may be applicable to earlier years.
    First, this isn't something that I figured out myself, but it bears repeating. For the big sheet on the top of the radiator housing, you can push in on the button in the center of the plugs to help free them. After the button's down, you can use pliers or a flat head screwdriver to gently pull the plugs up instead of prying them up. You can push the inner pins which are controlled by the button into the up position later before reinstalling them. Then after you reinstall the plugs at the end, you can push the button down to the locking position. It should be flush with the outer housing of the plug. If you push it all the way down, you pushed it too far and into the unlock position you did in the first step, so don't do that.
    Second, this is something that I noticed myself. This comes after you remove the big sheet. All of the videos I've seen say that you have to forcefully pry the 6 plugs out that are under the big sheet. These plugs are a different shape than the ones that held in the sheet. They work in much the same way, but they are a bit different. Before you go pulling these up, look closely at the top of the plug. You'll see they have a similar button to the other ones. You can't push it down into a lower position like the previous plugs, but you can use a flat head screwdriver to pop the button up. You can see it's possible because the housing surrounding this button gives you room to do so. After you pop the button up, you can easily pull the whole plug up. I noticed this after forcefully pulling out the first plug. I looked at the construction of the plug and realized that I could just pull up on the button. I did my method on the following 5 plugs, and they all came out perfectly smoothly. If I remember correctly, even the official instructions say to forcefully pry it out, but it's unnecessary and possibly damaging. Of course, when reinstalling, make sure the buttons are up, place the plug in the hole, and then push the button down. It will lock in place.
    Finally, this is the big one that I saw people on videos on the internet getting wrong. They say to yank the grill upper out. Some of them were kind of forceful about it. I was able to get the one clip out on the far left and had trouble with the rest. I looked at the one clip that I got out and realized how the grill upper clips into the body. I couldn't see how it all went together until I got the one out, but there are 6 clips. Have a look at the photo, and you'll see where the clips are. What I did with the 3 remaining easy clips was I shoved a long and smooth flat head screwdriver into the space between the grill upper and the body. This helped to free the clips on the grill upper from the holes on the body. After I got the easy ones free, I had to deal with the 2 more difficult clips. I couldn't come up with a better course of action than elbow grease, but at least I had more room to work with since the 4 easy clips were free. I was able to get the 2 difficult clips free without too much trouble. You may wish to lay down some masking tape before you shove the screwdriver into the 4 easy clip spots, but it would be worse to break the body than to scratch the paint if you don't do anything at all with the clips. And since you understand how the parts clip together, you can be more sure about putting it back together. You won't even have to worry about using the 2 more difficult clip holes if you're going to the TRD pro grill.
    Red_5 likes this.
  2. Aug 26, 2020 at 4:38 PM
    dcgarcia5
    dcgarcia5 New Member
    2020 4Runner OR
  3. Aug 26, 2020 at 5:22 PM
    4RunnerRVA
    4RunnerRVA New Member
  4. Aug 26, 2020 at 5:40 PM
    BgBmBoo
    BgBmBoo New Member
    Kansas
    This grill will not fit the 2020 models. I’m guessing that is due to the lack of a cutout for safety sense. You can cut that yourself, but something to be aware of.
  5. Aug 26, 2020 at 5:57 PM
    V4runner
    V4runner New Member
    Vikash
    2019 Sr5 Premium
    Daystar Leveling Kit
  6. Aug 26, 2020 at 6:41 PM
    4RunnerRVA
    You are correct- this is exactly why I bought OEM. Price hike sucks, but Id rather not worry about cutting something and risk messing it up on to go on a brand new 4R
    Jack Diesel likes this.
  7. Aug 26, 2020 at 7:05 PM
    dcgarcia5
    2020 4Runner OR
    If I buy the pre2020 pro grille, I can buy it 3 other times if I mess up the cutting and still spend less than Id if I had bought the OEM 2020 pro grille ;)
  8. Aug 26, 2020 at 7:45 PM
    Gamma Ray
    I got official parts from McGeorge Toyota's online store. These are the part numbers for my 2020. IIRC, the grill upper is the same for 2019 and before, but the garnish piece is unique for 2020 due to the cutout for the sensor.
    PZ323-35058 Garnish Front Bumper
    PZ327-35056 Grille Radiator Up
    Here's a shot of the finished product.
    gunsnob and JediMasterYota like this.
  9. Aug 26, 2020 at 10:27 PM
    JediMasterYota
    JediMasterYota UnsettleDown
    Rob
    Richmond, VA
    2020 Super White SR5 Premium
    That looks great! McGeorge is my local dealer. Great prices overall and they really went out of their way to land my new 4R.
    Cheers!
  10. Aug 27, 2020 at 7:33 AM
    Gamma Ray
    Thanks! I'm liking it, too. It's still the only one that I've ever seen in person. I see other 4Runners on the road, but I've never seen a TRD Pro grill.
    BTW, if you have a 2019 or earlier, the garnish piece is part number PZ323-35056. I know this because McGeorge accidentally sent that one to me at first. Yeah, they made an error, but they handled it spectacularly, so good on them for that. I'll definitely be buying more parts from them in the future. I'm a very happy customer. I would have gotten my TRD exhaust from them, too, but they didn't have any in stock at the time.
  11. Aug 27, 2020 at 12:18 PM
    4RunnerRVA
    I paid $400 or so.. definitely not as bad as the $644 MSRP price tag.. and you know it will fit perfect, so worth it to me
  12. Aug 27, 2020 at 1:19 PM
    Gamma Ray
    And it'll probably hold up better than the aftermarket ones. If I was to repaint it, I'd probably go with an aftermarket one, but I'm not, so I went with the official Toyota one.
  13. Sep 8, 2020 at 8:34 AM
    JediMasterYota
    Rob
    Richmond, VA
    My sales guy at McGeorge just said they could order the 2020 Pro OEM and install it for the purchase price, no labor upcharge. I just took them up on that. Adding the TRD black wheels and my baby will be lookin hot rolling off the lot this weekend. My wife is going to be annoyed at how many pictures I'm going to take of it.
    Thanks for all the info on this! I can't wait to share pics.
  14. Sep 8, 2020 at 9:17 AM
    4RunnerRVA
    Cant wait to see it man!! Finally mine is complete after McGeorge installed my wheels/tires this past week
  15. Sep 9, 2020 at 5:43 AM
    Red_5
    Red_5 New Member
    Thanks, man. That's a great write-up. I also recommend that pretty much everyone have a set of trim removal tools on hand as a general matter.
    They're cheap as chips and super helpful, especially if you ever decide to start digging into the dash or door panels.
    You can get more expensive metal versions, but I prefer plastic because the tool will break before you break an expensive OEM part or panel.
    7385 likes this.
  16. Sep 9, 2020 at 2:24 PM
    Gamma Ray
    Thanks for the suggestion. That's going on my wishlist. Going to hold off buying it for now because I already spent way too much on tools and parts this summer :D But I'll have to get it before I do some interior work.
