Green oxide on the oil cooler?
Discussion in '5th Gen 4Runners (2010-2024)' started by golfpilot, Mar 20, 2025.
  1. Mar 20, 2025 at 11:39 AM
    golfpilot
    golfpilot [OP] New Member
    David
    Switzerland
    2019 TRD Off Road Premium
    Hi
    Year 2019, around 52K miles. Some oxide or similar on the underside of the oil cooler (the one by the oil filter).
    Should I be worried about the look of the oil cooler or is this normal?
    It's also a bit strange that the coolant is not green-blue but pink, so it almost can't be coolant.
    Or does this heat exchanger have copper in it which can oxidize? Maybe from the outside.
    Thanks if anyone has experience with this.
    20250320_191329.jpg 20250320_191303.jpg 20250320_191224.jpg 20250320_191025.jpg
  2. Mar 20, 2025 at 1:40 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Looks like normal corrosion from outside elements.
    Unrelated to your Toyota Pink "Super Long Life" coolant.
  3. Mar 20, 2025 at 3:06 PM
    Most oil coolers of this type have stacks of copper plates in them brazed together. That's just copper corrosion from the environment.
  4. Mar 20, 2025 at 5:57 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    I would try cleaning off the corrosion. A nylon brush and a spray household cleanser. Household cleaners are usually mild.
    I would start with Simple Green and see if it is effective. If not, work thru your cleaning supplies.
    Rinse fully after each cleanser.
    There are various coolants and colors out there, most not interchangable. As said above Toyota Long Life is pink.
