Grease leaking from tie rod end joints -- related to PS flush?
Discussion in '5th Gen 4Runners (2010-2024)' started by auspilot, Mar 1, 2026.
  1. Mar 1, 2026 at 9:59 AM
    auspilot
    auspilot [OP] DustRunner
    2020 TRD OR
    Dobs IMS, lots of small stuff
    So I was inspecting my tie rod ends while rotating the tires and was surprised to see grease leaking from one of the boots. There is only 60k on the truck and they looked fine at the last rotation 5000mi ago. Then it got more weird when I saw the same thing on the other joint! I did a PS fluid flush recently and was wondering if cranking the steering wheel back and forth might have caused this. Anyone have a similar experience? How concerned should I be?
  2. Mar 1, 2026 at 10:09 AM
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    Did you drive through deep water recently?
  3. Mar 1, 2026 at 10:14 AM
    I did a power steering flush recently and do not have this.
    I jacked the front end up though so the wheels were in the air.
  4. Mar 1, 2026 at 10:24 AM
    auspilot
    2020 TRD OR
    No water crossings. I was off road a bit, but nothing like rock crawling.
    I jacked up the front end while pumping fluid out, then had the wheels on the ground for a couple of wheel turns to bleed the system.
  5. Mar 1, 2026 at 10:27 AM
    My wheels were up in the air while turning.
    Not saying that's your issue. Just that my method was different.
  6. Mar 1, 2026 at 10:30 AM
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    Tie rod end grease typically isn't that runny-looking.
    3JOH22A likes this.
  7. Mar 1, 2026 at 10:56 AM
    Looks a little much, but maybe they were a little overpacked with grease at the factory? Or maybe it’s this much white grease because you looked at it so soon after cranking it back and forth? Is this the first time you remember exercising the steering through its range that much?
    I noticed a little white grease coming out of mine. This at about 85,000 miles. It’s pretty clear that there’s been some grease coming out for a while. I’ve got a fair amount of off-road miles, so it gets a workout. The steering gets used gently, but fully.
    If you look closely, there is a little fresh white grease at the top. That came out literally after very gently touching the boot (the lightest of pushes). I think that grease is probably pretty thin relatively speaking.
    I’m keeping an eye on it I guess. Next oil change I’ll give the tie rods a fee good tugs to feel for looseness, but otherwise it seems fine and I don’t get any clicking or noises.
    auspilot[QUOTED][OP] likes this.
  8. Mar 1, 2026 at 10:58 AM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    Grease is too thick to leak out like that and it's not the correct color for it to be grease, it appears to be water that got into the boot that is leaking out.
    Slopemaster and 2Toys like this.
  9. Mar 1, 2026 at 10:59 AM
    Cranking the steering wheel back and forth is within the range of normal steering system operation. :notsure: This boot is not sealed against the stud pin at this location or against the knuckle. As you drive, grease can expel out and mud/water can get in.
    You should not be concerned because tie rod joints are wear items. Usually either the boot tears or the grease degrades with contamination. When you go off-road, you should carry at least one inner and outer tie rod as trail spare anyway, because they're easily bent or impaled by rocks or branches on the trail, and this can happen at 100 miles or 100,000 miles.
    You can do a quick tactile check of the tie rod for play every time the wheel comes off for tire rotation. If you see the boot torn or notice play, replace the tie rod end.
  10. Mar 1, 2026 at 11:13 AM
    auspilot
    2020 TRD OR
    It does look runny, but it is also pretty tacky. It's definitely grease. I drove on a bunch of dusty dirt roads about a month ago, so if it was there before then I think it would have more dust embedded in the grease. Then the PS flush was a couple weeks ago. Hmmmm...
  11. Mar 1, 2026 at 11:20 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    I’ve replaced my inner and outer tie rods. that’s simply just your outer tie rod balljoint boot leaking grease because possibly it’s starting to fail.
    or coincidentally it’s a spill from above.
  12. Mar 1, 2026 at 11:23 AM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    Water that's been sorta trapped in the boot with grease would sorta be tacky, doing the flush could of caused the boot to work it's way loose enough to allow the water to leak out, I still think it's water diluted by little bit of grease.
    There's been mention of "white grease" leaking out of their tie rod boot, the grease that's used in a tie rod end is not white lube A.K.A. white lithium grease. , it is much the same as axle/wheel bearing grease.
  13. Mar 1, 2026 at 11:25 AM
    auspilot
    2020 TRD OR
    That's actually what ChatGPT told me, for what that's worth. :rolleyes:
    It is pretty unusual for me to hit the steering stops. I tend to take gradual turns, not one of those people who always crank the wheel to the stop when turning.
  14. Mar 1, 2026 at 1:36 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited
    OME Nitrocharger struts and shocks. OME 884X front springs, OME 889X rear springs, full RCI skids, RCI roof rack, RCI sliders with kickouts, Method Racing MR306 Mesh wheels.
    Turning your wheels full lock in either direction isn't going to cause that. Neither is a PS flush. You have water infiltration there. Which means there's going to be oxidation of metal (rust). Change those things out.
    Saker and NB4x4 like this.
  15. Mar 1, 2026 at 6:36 PM
    I thought it would look like the typical honey colored axle grease too. But the fresh stuff I saw coming out of mine was white/bone colored, and quite thin for a grease. It’s probably some toyota special sauce grease that costs 45 dollars an ounce.
    auspilot[OP] likes this.
  16. Mar 1, 2026 at 7:27 PM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    You just described what water that has been confined and agitated with axle grease for a while looks like.
  17. Mar 1, 2026 at 7:56 PM
    auspilot
    2020 TRD OR
    The stuff coming out of my boots did not seem like a mix of grease and water. It looks runny in the pics, but it was actually very tacky, and felt just like chassis grease, just maybe a little lighter. It does look like it flowed, but probably extremely slowly. Also, I did not do any water crossings deep enough to cover the boots. Even if water did get in, I don't think there's a way for it to be agitated and mixed like it would in a differential, if that's what you're comparing it to.
  18. Mar 1, 2026 at 8:35 PM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    It could be old worn out grease which can get to a point of being somewhat runny and lose it lubricating qualities, but if so I would replace the tie rod ends with new ones with grease fittings at some point so you can regrease them.
  19. Mar 1, 2026 at 8:59 PM
    WRunner
    WRunner New Member
    Jason
    23’ 4Runner
    No Idea.
    I agree with the failing boot comment above. That was my first thought when I saw the grease pattern. I can’t see any visible cracks or separation in the picture but take a very close look at it with a flashlight even in the daytime and I’ll bet you find some separation. If they haven’t been recently greased there isn’t really a reason they would leak out from over greasing at the 60k you stated. Something has changed within the last 5k miles. 60k isn’t bad for a joint on an off-road vehicle that gets used off-road. Replace with a super cool upgrade.
  20. Mar 2, 2026 at 11:28 AM
    that has nothing to do with a power steering flush - at all. To me, it looks like PB Blaster but as others have mentioned i have seen this with water
    AuSeeker likes this.
  21. Mar 2, 2026 at 5:55 PM
    that looks like grease mixed with water
