Got to experiment with Multi Terrain Select on some serious ice
Discussion in '5th Gen 4Runners (2010-2024)' started by cuse93, Jan 19, 2022.
  1. Jan 19, 2022 at 7:39 AM
    cuse93
    cuse93 [OP] New Member
    Short story: I am really impressed with MTS (mud/sand) in 4wd High.
    Long story: i have a very long, steep, and twisty driveway that got hammered with sleet and snow that turned into a solid 1-2" of glare ice after plowing and a severe temperature drop.
    it was so bad I had to park the 4runner at the end of my driveway (and chock the wheels) to make sure no one tried to pull in.......it would have been like an olympic bobsled run before salting and sanding.
    the difference between 4wd high alone, and 4wd high with MTS set to mud/sand is VERY tangible. I could not get up a steep section of my driveway without MTS on. in 4wd without MTS the traction control was completely debilitating. With MTS on I had almost zero wheel spin.
    I did not even need to try 4w Low with ATRAC. I also didn't try disabling traction control. I'll do some more experimenting during our next serious snow event.
    FWIW, there is no chance my Tundra or my wife's Silverado would have been able to make it up the steep grade in those conditions.9F386C4F-369C-4F7C-A6B5-48BF6B60197D.jpg
  2. Jan 19, 2022 at 1:20 PM
    lowflyer
    lowflyer New Member
    2023 TRD ORP w/ KDSS <2021 Venture w/o KDSS <line of Tundras
    I can see why it would help climbing the slippery slope, but I'm guessing it would not have been wise to then drive down the hill with or without ATS. You would have been sledding in either case.
  3. Jan 19, 2022 at 1:45 PM
    kmeeg LionRunner
    Sorry for my dumb question in advance.
    I'm very interested to learn how Toyota MTS work in Mud/Sand mode and how it help in Ice? I thought in Mud/Sand mode should not stop wheel spin vs on Ice should we prevent wheel spin?
    Again I'm trying to learn here, appreciate expert advice how traction control should work on mud/sand vs ice.
  4. Jan 19, 2022 at 1:45 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    And praying nobody coming down the road as you blast through.
  5. Jan 19, 2022 at 2:00 PM
    MTS is just intensity control over the system. For mud you want wheelspin to clear the tires up but you don't on rocks so the power is transferred to tires with traction. On ice, the vehicle will more than likely not see a difference in traction and not control wheelspin unless you have tire with more traction.
    LandCruiser likes this.
  6. Jan 19, 2022 at 2:02 PM
    The videos I’ve seen demonstrating crawl control looked pretty cool.
  7. Jan 19, 2022 at 2:05 PM
    banjos-n-beer
    banjos-n-beer New Member
    Steve
    Maine
    2018 Pro
    Mine is 500 feet of glare ice as well, just not quite as steep.
  8. Jan 19, 2022 at 2:15 PM
    lowflyer
    lowflyer New Member
    In any "slippery" condition (sand, mud, ice) MTS controls wheel spin. In the sand/mud mode it allows some degree of spin which is helpful in those conditions.
  9. Jan 19, 2022 at 2:28 PM
    kmeeg LionRunner
    I was trying to understand how Mud & Sand "had almost zero wheel spin" helped on ice vs OP "could not get up a steep section of my driveway without MTS" in 4H. Where I thought Mud & Sand should allow more wheel spin than regular mode 4H vs something like Rock should be the mode that should have given "almost zero wheel spin".
  10. Jan 19, 2022 at 3:51 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    There’s no one way to appraoch this. Sometimes you just have to experiment.
    You could try creeping up an icy hill slowly in 4LO, turning on A-Trac, maybe adding the rear diff lock. Or a slow 4LO plus MTS in any of the settings. Or a higher speed 4HI plus MTS Mud&Sand.
    The MTS settings will be active under about 7MPH IN 4LO. The Mud&Sand (and Snow) setting can also be used in 4HI, and at higher speeds, which is often useful to keep momentum up in mud, sand, and snow.
    I don’t think of it as “the wheels are allowed to slip”. The MTS system uses selective braking to dynamically route power to the wheels that have traction. You have 4 settings to select how much individual wheel slip will be allowed before the system brakes it to allow other wheels with better traction to continue to rotate. It’s so fast that it’s hard to detect the individual wheels slipping.
    Yotaholic and kmeeg[QUOTED] like this.
  11. Jan 10, 2024 at 2:15 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    Is there a speed limit to use MTS in 4Hi on mud/sand?
  12. Jan 10, 2024 at 2:31 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    Very cool.....glad to hear it's worked for you.
    Yotaholic likes this.
