Got suspension installed and passenger rear is higher?
Discussion in '5th Gen 4Runners (2010-2024)' started by zombieswithmustaches, Jul 7, 2021.
  1. Jul 7, 2021 at 1:42 PM
    zombieswithmustaches [OP] New Member
    2019 TRD Off-road Premium
    AFE Momentum intake, Pedal Commander, Sherpa Crestone roof rack (ordered), C4 summit hatch ladder (ordered), Rigid Armor tire carrier (ordered)
    So I got the Toytec/Bilstein coil overs with SPC uca’s up front and Toytec HD Superflex 2” springs out back with Eibach pro lift shocks (everywhere was out of the Bilstein 5100’s). Anyway, besides a little sway in the rear when turning or going around a curve, my question is…
    I've heard 4runners are known for front driver lean a little (mine is 3/4" lower drivers side) but my rear passenger side is almost an inch taller than the driver rear. Is there a reason for that? Am I measuring wrong?
    Measured from ground through middle of wheel to bottom of fender:
    Driver front: 38 9/16”
    Passenger front: 39 5/16”
    Driver rear: 40 5/8”
    Passenger rear: 41 9/16”
  2. Jul 7, 2021 at 2:00 PM
    Tuco S.
    Tuco S. New Member
    Measure from the center of wheel hub to the bottom of fender opening. This will eliminate any error caused by tire height, which may be different for each tire.
  3. Jul 7, 2021 at 2:10 PM
    David@Toytec
    David@Toytec New Member Vendor
    David
    Denver Colorado
    2005 4Runner
    To much
    You might of just emailed into us here at Toytec but if not
    The best way to measure is on a flat level surface and measure from the center of the wheel hub to the edge of the fender in all 4 corners. From there that will give us an accurate reading to ensure we get you dialed in properly.
  4. Jul 7, 2021 at 2:29 PM
    Haha! Yes I did! I was just about to go measure it and message back. Would you prefer here instead of email?
  5. Jul 7, 2021 at 2:57 PM
    New measurements from center of hub to bottom of fender on flat surface:
    Driver front: 23”
    Passenger front: 23.5”
    Driver rear: 25”
    Passenger rear: 26 3/8”
  6. Jul 7, 2021 at 2:59 PM
    David@Toytec
    David
    Denver Colorado
    2005 4Runner
    To much
    Do you have added weight back there to accommodate the HD Rear springs?
  7. Jul 7, 2021 at 3:03 PM
    No. It was just suggested to me by Hugo (I think?) to get them. I only have a Sherpa Roof Rack and C4 ladder on the back. Should I switch to normal load springs?
    I was also looking to be more level. What do you suggest as far as springs go?
  8. Jul 7, 2021 at 3:25 PM
    I will say these are pretty stiff!
    Measured again:
    Driver front: 23”
    Driver rear: 25.5”
    Passenger rear: 26”
    Trying to find the best flat place. Not easy in my town! :(
    3rd measurement:
    DF: 23”
    PF: 23.5”
    DR: 25”
    PR: 26 1/8”
