Got my stage 2 Eibach kit installed today! EXTREMELY pleased!
Discussion in 'General 4Runner Talk' started by brownersd, Apr 12, 2021.
  1. Apr 12, 2021 at 7:46 PM
    brownersd
    brownersd [OP] You are the weakest link, buh-bye!
    Sean
    Humble / Kingwood, Texas
    Hey guys and gals,
    I wanted to let you know that I had my Eibach 2.0 Stage 2 Pro Truck Lift installed today. WOW, what a difference! It made me wonder why i hadn't done this before. I am really happy with it, the 4Runner drives like a TRUCK now. In addition, I went with the Toyo Open Country A/T III in grade E, which are surprisingly quiet! Went with the L285/70 R17 and there is minor rubbing when in reverse (on the mud guard).
    With that being said, I remember reading with my first impression of the front looking higher than the back... Someone said at one time, measure the edge of the wheel well (fender) to the ground, and realised that it is level.
    What I'm wondering is should I do the diff drop?
    Shout out to All Out Off-Road in Tomball, Texas for doing a SPECTACULAR job! It was done in about 4 hours.
    Here are some pics... Lemme know what you all think!
    20210412_141154.jpg 20210412_141222.jpg 20210412_183909.jpg 20210412_183930.jpg
  2. Apr 12, 2021 at 7:54 PM
    brownersd
    Sean
    Here's the alignment spec sheet... Thoughts? Also, what tyre pressure do you recommend for daily driving?
    kolter45 and K-Paul like this.
  3. Apr 12, 2021 at 9:08 PM
    That looks really good!! That's a great looking 4R.
    I'm curious, what do mean by it "drives like a TRUCK"? How does it compare to stock? Is it stiffer?
    I'm thinking of the lift myself, that's the reason I ask. Typically, saying something "rides like a truck" isn't a good thing, haha.
    brownersd[OP] and DrewMan like this.
  4. Apr 13, 2021 at 4:22 AM
    21Venture
    21Venture Roof Rat
    Bryan
    Edinburg, TX
    2021 4R Venture Super White & 2007 FJ
    4R-TerraFlex Falcon Sport/Tow 2/1 Lift/Level, Nise Rack Crossbars, KO2 LT265-70-17 FJ- Icon Stage 3, 4.56 gears and 10k winch
    Looks great! Looking at the same kit.
    brownersd[OP] likes this.
  5. Apr 13, 2021 at 4:30 AM
    brownersd
    Sean
    Thanks guys!
    @Trail Runnah: hahaha, of course! What I meant was that it feels of course heavier, but a bit more stiff than stock. The stock suspension feels ok, but I feel this is the way Toyota should equip the TRD Off Roads at least from factory.
    Cheers,
    Sean
    Trail Runnah likes this.
  6. Apr 13, 2021 at 12:00 PM
    Looks great!
    No diff drop needed.
    brownersd[OP] and DRobs like this.
  7. Apr 13, 2021 at 12:13 PM
    brownersd
    Sean
    I appreciate you mate! Thank you! :)
    Cheers,
    Sean
    nimby[QUOTED] likes this.
  8. Apr 13, 2021 at 3:21 PM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    +1 to both.
  9. Apr 13, 2021 at 4:05 PM
    Thanks for the info! Mine is a 2013 I bought two years ago with 79k miles, 115k now. I don't think it rides that great, but then again I don't know how a new one rides. I feel like the front is too soft, but the back is too stiff over harsh bumps.
    I'll have to look into this kit more, I think it's on sale for a couple more days.
    brownersd[QUOTED][OP] likes this.
  10. Apr 14, 2021 at 10:13 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Alignment looks to be what I'd expect. If it feels fine to you, especially on the highway, then it's fine. Aftermarket UCA's would probably offer a bit more stability at high speeds, easier return to center, etc. Nearly 3* of caster isn't far off spec, but you also have bigger tires, so... your call there. Nothing to worry about if you like the way it drives.
    Curious, did you put a level against your frame? I am curious if it's level or not.. not that it really matters if you like it. FWIW, the rear fenders are about 2" higher than the fronts from the factory.
    The correct tire pressure for LT tires on a near-stock-weight 4Runner is ~39 PSI.
  11. Apr 14, 2021 at 10:48 AM
    Very nice!!
  12. Apr 14, 2021 at 11:27 AM
    thirdyota
    Brian
    Cincinnati, OH
    2017 T4R TRD Off Road Premium
    Looking good OP :cheers:
  13. Apr 22, 2021 at 3:22 PM
    brownersd
    Sean
    Hey hey matey!
    Absolutely does feel well. I did go with the aftermarket UCA's... Went with the OME UCA0004, which I understood would help with better alignment numbers casterwise. They seem to be working out as well.
    You know, i didn't do the level unfortunately... I did measure from top of wheel well to the ground on all 4 sides, and as read on different posts, it's about 1/8 lower on the left side than the right, but it isn't noticeable.
    Thanks for the tire pressure recommendation... Currently playing around with it, and currently at 38PSI.
    Cheers,
    Sean
  14. Apr 22, 2021 at 3:29 PM
    brownersd
    Sean
    Thanks gents, I appreciate you both!!
    Cheers,
    Sean
  15. Apr 22, 2021 at 4:20 PM
    brownersd
    Sean
    Man, I highly recommend it. All I can say is be patient, mate! It took me a WHILE to find some place (Stage3Motorsports) that had everything in stock.
    Cheers,
    Sean
  16. May 26, 2021 at 5:08 PM
    Toyotafvr
    Toyotafvr New Member
    Joe
    OP. It looks great. I love the look. I am looking into this kit for my wife's 4runner. What did you do in the rear?
  17. May 26, 2021 at 8:39 PM
    brownersd
    Sean
    Hey matey,
    Thanks so much for the compliment. Did the standard Eibach 200lb springs, with the Pro Truck Shocks that comes as a part of the stage 2 kit. I was debating adding the adjustable kit in the rear, but it isn't really needed. I definitely recommend it!
    Cheers,
    Sean
    icyhotahs likes this.
  18. May 27, 2021 at 3:27 AM
    Toyotafvr
    Joe
    Thank you sir! You have the prefic stance and looks great. Definitely going to go this rout.
  19. May 27, 2021 at 4:38 AM
    brownersd
    Sean
    Absolutely mate... Thanks again, and let me know if you have any questions. Good luck mate!
    Cheers,
    Sean
  20. Jun 13, 2021 at 5:07 PM
    Marbenz
    Marbenz New Member
    Matt
    17 4runner
    Ordered my Eibach pro truck kit in April, still waiting on front coilovers and eta is October! :(
  21. Jun 14, 2021 at 7:33 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    I'd call them and talk to them in person.
  22. Jan 21, 2022 at 10:51 AM
    TNCave
    TNCave New Member
    This is an old thread, but I thought I would add my recent experience with Eibach.
    I was interested in the Eibach 2.0 coilovers and rear load leveling system as well as some competing products. I called Eibach directly, the phone was answered by a human, knowledgeable about the products, who could easily answer my questions directly.
    One of my primary concerns was the service interval and working life. I know many of the higher end coilovers have service intervals at 30-40k miles, and I'm hoping for something more simple and robust. I'm not racing in the Baja 1000 over here. Eibach confirmed an 80,000 mile service life for the coilover 4Runner struts with free replacement in the event of leakage.
    I ended up ordering the full kit directly from Eibach. They don't offer the coilovers with adjustable rear leveling system as a kit on their website, but they will price it as a kit over the phone ($1499.44 as of 1/21/22). I figure this cuts out any middle men for potential warranty issues and I really like that I can call and reach a human if needed.
    I just thought I would report out my experience in case anyone else would find it helpful.
  23. Jan 22, 2022 at 1:02 PM
    brownersd
    Sean
    Thanks for the heads up mate... I know you will be happy with it as well.
    Cheers,
    Sean
  24. Jan 22, 2022 at 1:07 PM
    Toyofan87
    Toyofan87 New Member
    Seth
    Blue & Grey Hwy Gburg
    1987 Toyota 4Runner SR5
    Congrats, nice stance and looks killer. Big fan of Eibach and Toytec Coilovers Lifts. Solid and true. I installed the Toy 2.0 Alumas to my 2d Gen Tundie.
  25. Jan 22, 2022 at 1:39 PM
    brownersd
    Sean
    Thanks a million mate... Still enjoying it, and no issues so far!
    Cheers,
    Sean
    Toyofan87 likes this.
  26. Feb 11, 2022 at 9:25 AM
    LunarTR4
    LunarTR4 New Member
    22’ TR4 ORP LR
    What were your final lift #s? I ask because I purchased the pro-truck stage 2 coils, rear sport shocks, and the pro-truck level system (400lbs of added weight) directly through Eibach and will be having them install everything at their shop here in Corona, CA.
  27. Feb 11, 2022 at 9:30 AM
    K-Paul
    Corbin Dallas
    SR5 4WD
    H-Town shoutout, I was out in the Heights this past weekend catching up with friends :)
    I'll take a look at the shop out in Tomball next time we are there. Glad your lift is working out!
  28. Feb 11, 2022 at 12:05 PM
    brownersd
    Sean
    Hey hey mate, I think I ended up with 3" up front, and 1.5" in the back. I have been meaning to measure and compare with a stock vehicle at my local dealer, but problem is, my local dealer has NO 4Runners as of lately. :(
    Hey hey mate! Shout out to you too. I'm in Dallas usually once a month. Next time you're in Houston, definitely let me know.
    Cheers,
    Sean
  29. Jun 26, 2022 at 6:01 AM
    TNCave
    TNCave New Member
    I finally had a chance to install my 2.0 adjustable coil overs and adjustable rear springs from Eibach. Install was very smooth as long as you don’t follow the instructions. Thanks to YouTube there are a lot of install videos for lifting 4Runners. On the front, just loosen and drop the lower control arm and everything falls out very easily. The Eibach instructions make the front install much more complicated.
    I set my rear at max height and the front at about 2” which measures level at the fenders. With stock size Michelin LTX the center of the wheel wells are at about 38.25”. Interestingly, I had to adjust the driver’s side strut up quite a bit to level between the driver’s and passenger side.
    I’ve only had it on a short drive so far, but overall it feels much more controlled compared to the stock suspension. I had newer struts and shocks, but stock springs with 150,000 miles on them. The Eibach is a bit stiffer and more harsh at low speeds, but feels so much better on the road at speed, especially on curvy two lanes. Less body roll overall and much more confidence inspiring to drive. So far I’m very happy with the kit.
  30. Nov 26, 2023 at 1:21 PM
    Y0TA
    Y0TA New Member
    Montana
    23 ORP w/ KDSS MGM
    Hey OP, the 4runner looks great. I have a 23 ORP with KDSS. I hope you can help me out. I just ordered the stage 2 kit. Does yours have KDSS and did you have to get anything else for it?
