Got Cali Raised sliders, flat with no kick-out? Please help.
Discussion in '5th Gen 4Runners (2010-2024)' started by Captain Spalding, Apr 28, 2022.
  1. Apr 28, 2022 at 3:51 PM
    Captain Spalding [OP] . . .
    Hi folks. I’m in the market for some sliders for my ‘22 ORP with KDSS. My preference is a flat slider with no kick-out. I’ve narrowed it down to Cali Raised or RSG. I think both companies offer great products.
    My knees aren’t what they used to be, and I will be particularly relying on the slider’s functionality as a step. I know the RSG protrudes from the sill about 4 inches. I would like to know how much the Cali Raised slider protrudes.
    So if this post catches the eye of any of you who happen to have CaliRaised flat no-kick sliders on your truck and wouldn’t mind taking a measurement and passing it along, it would be appreciated. (I emailed CaliRaised but they couldn’t tell me.)
    I’m attaching a photo for reference. I’m not asking you to post a photo. Just a measurement is fine.630DDF75-27AE-4CCD-A29E-D9C0FADE85B3.jpg
  2. Apr 28, 2022 at 5:54 PM
    KYFHO
    KYFHO Generic Scumbag
    UT
    2017 SR5P with some stuff
    I don’t particularly feel like going down to my garage to measure at the moment, but I do have those sliders. What I can tell you is that I wear size 11W steel toe boots and use mine as a step all the time
    Captain Spalding[OP] likes this.
  3. Apr 28, 2022 at 7:42 PM
    Thanks for your input.
  4. May 4, 2022 at 11:09 PM
    Saturnine90
    Saturnine90 New Member
    2020 Army Green Pro
  5. May 5, 2022 at 3:33 AM
    Pavo
    Pavo New Member
    That's what she said
    Thepremier141 and Yoytota like this.
  6. May 5, 2022 at 10:34 AM
    The heartless wench.
  7. May 8, 2022 at 3:39 PM
    Cati
    Cati New Member
    Any flat sliders that protrude more than 4in?
  8. May 8, 2022 at 4:30 PM
    Hi Cati. Just to be clear, these photos show how far the step protrudes beyond the sill when looked down upon from directly above. They do not necessarily show how much of a usable step there is. That would depend on how wide the slider is as well as how far the slider hangs below the sill. I emailed Cali Raised and they replied that the filler plate on their slider is 5⅛” wide. If the slider sits low enough that one’s shoe can fit under the sill, that would mean a usable step of 5⅛”.
    jake long15 likes this.
  9. May 8, 2022 at 6:08 PM
    SYTY
    SYTY New Member
    THE ARM PIT OF AMERICA NY STATE THE ROTTEN APPLE
    BudBuilt 15.5 inches out from frame I think that would be about 4 maybe 4.5 inch from sill.
    (2010-2021) 5th Gen 4Runner Bolt-On Rock Sliders with Kicker
    Defending the most vulnerable areas of your 4Runner, BudBuilt sliders are engineered to protect both rocker panel and frame alike. As with all BudBuilt products, our sliders are CAD designed by mechanical engineers, with specialties in material science and failure analysis. Combining formal education with decades of engineering and hard-core rock crawling experience, BudBuilt has the proven edge to make products the best they can be.
    BudBuilt sliders begin with the strongest foundation in the industry, 3/8" thick, that runs the full height of the frame rail. This foundation works in conjunction with factory welded captive nuts inside of the frame rail to appropriately move stress up and down the frame rail during impact. We have seen too many frames buckled inward from other sliders that do not distribute the 4Runner's crushing load appropriately.
    Four (4) 1.75" OD steel legs with additional reinforcing gussets solidly mount the frame plate to the main tube. We chose this design for its superior strength qualities over three (3) leg designs, regardless of whether round or square tubing is used. Our main tube is constructed of 2" OD steel tube, providing a rock solid, smooth sliding surface. The 2" OD round main tube is far strong enough to support the full weight of the 4Runner under lifting situations, and provides an additional 1" of ground clearance as opposed to 3"x 2" rectangular tubing. Angled 20° upward from the main tube, the outer tube is constructed of 1.75" OD steel tube with smooth angles to stand up to constant abuse and not hang up on rocks. Three (3) additional reinforcement 1.5" OD steel tube legs tie the main and outer tubes together, creating a total of six (6) connecting points. This design further increases rigidity and strength across the entire slider. Total distance from the 4Runner's frame to the outer tube is 15.5".
    Our kicker design is accomplished by forming the outer tube to smoothly add 2" of additional protection to the rear of the slider. When driving on tight and narrow trails, the kicker greatly reduces fender impacts from rocks and trees by either kicking the 4Runner away from danger, or preventing the 4Runner from getting too close to an obstacle to begin with. BudBuilt's kicker, combined with our 20º upward angle, provides massive ground clearance and protection where you need it most. From the 4Runner's frame to the furthest point on the kicker is 17.5".
    • BudBuilt sliders are designed and manufactured in house from pure American steel. We will never use lower grade Chinese or Indian raw materials
    • Only round tubing using is used for its strength and function increase over square tubing
    • Unique mounting system provides unsurpassed rigidity and strength during hard impacts
    • Mounted with industrial grade 10.9 metric hardware and ultra thick washers
    • 20º upward outer tube angle provides incredible ground clearance and protection
    • Sold as a pair (2)
    Fitment FAQs:
    From the factory, 5th generation 4Runner SR5 and Limited models are sold with one piece plastic rocker panels and side steps. When installing BudBuild sliders, the factory side step will need to be either trimmed or replaced with a Trail edition plastic rocker panel.
    5th generation 4Runner Trail and Pro models do not require any trimming or replacement of the plastic rocker panels. Simply bolt on and go
  10. May 9, 2022 at 11:02 AM
    jake long15
    jake long15 Cali Raised LED
    If you have any other questions. Feel free to shoot us a PM and we will be happy to answer them.
