Good adjustable lift kits for 07 4runner
Discussion in '4th Gen 4Runners (2003-2009)' started by Squatchunter, Nov 30, 2023.
  1. Nov 30, 2023 at 10:54 AM
    Squatchunter
    Squatchunter [OP] New Member
    Lynchburg, VA
    3” lift on front end 2.5” in rear toyotech suspension lift, 285/70/17 General Grabber AT3. Camburg Racing UCA, Wilco Offroad trailer hitch with spare mount, cali raised offroad Pods(Amber), TEQ Customs Headlights dual high and low beam with hex halo’s and Custom Toyota grill with Raptor lights.
    What are some good lift kits for a 07 4runner RWD, looking for adjustable coilovers. Also ive herd that anything over a 3” lift on a runner would be basically better off doing a mid-long travel. Is this true or someone being a fibber?
  2. Nov 30, 2023 at 12:38 PM
    Squatchunter
    Lynchburg, VA
    Ive got toyotec 2.5-3” adjustable on the front atm with camburg UCA. Just trying to figure out mext best step besides going King like I normally would or Fox which im iffy about
    MI-FL off roader likes this.
  3. Nov 30, 2023 at 6:38 PM
    Nomadik Overland
    Nomadik Overland New Member
    David
    2006 V8 Tacorunner
    Tacoma Swapped Frontend +2 Long Travel in the front Long travel in the rear Addicted offroad front bumper True North Fab Rear bumper Custom rock sliders Nomadik Overland Drawer system Nomadik Overland roof rack Yakima RTT w/Napa Awning Caliraised Lights
    As someone who's ran Kings, Fox, Radflo, Bilsteins, Locked Offroad, and Carbon Shocks, my two favorite have been the Fox and Radflo's. Fox are higher performing than the Kings, Radflo are really good and more affordable. If you order Fox, order them from accutune and get them tuned for your build. If you order from Radflo, they will also tune the shocks to your build.
    As far as lift height, you want to stay around 3" typically to stay within alignment specs (With aftermarket UCA's). Since your 2wd, you can run a spindle lift as well and stay within alignment spec. A mid travel build is typically just a slightly longer coilover with aftermarket UCA's, Long travel is longer upper and lower control arms that provide more travel. You can get a ton of performance out of a mid travel build but a LT build is obviously better..
  4. Dec 1, 2023 at 5:06 AM
    Squatchunter
    Lynchburg, VA
    Okay so on that note, if im trying to stay in alignment spec whats a good radflo size to get for a piggy back? The 12” the 14” or the 16”?
    Im trying to stick to having a 3-3.5” lift so tryna get my research. Ive looked at the dobson overland rear springs for my spare tire carrier to keep it level
