Gear oil smell
Discussion in '5th Gen 4Runners (2010-2024)' started by Technologic80, Oct 20, 2023.
  1. Oct 20, 2023 at 12:17 PM
    Technologic80
    Technologic80 [OP] Sexy Member
    Chris
    SE Michigan
    '23 TRD Off Road Premium
    I just clicked over like 350 miles in my new 23 TRD ORP.... I noticed yesterday that my garage smells very strongly of gear oil - my 4R is the only vehicle in there, and I have never opened or drained gear oil in my garage on any other vehicle. I crawled down and looked at the front and rear wheels/rear axle/T-case, and did not see any obvious signs of a leak.
    Anything or anywhere specific I should check?
  2. Oct 20, 2023 at 12:19 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Front diff, transfer case and rear diff use gear oil and it stinks. Transmission and oil don't smell much in comparison. Did you really look closely for seepage/leaks? Check plugs, drain and fill.
  3. Oct 20, 2023 at 12:21 PM
    Technologic80
    Chris
    SE Michigan
    I grabbed my pen light and went down to look, rear axle drain - clean. T-case drain (couldnt locate) but the bottom of the t-case was clean. Could not see in the front where the drain was.
    Also I was checking at the wheels in case it was an axle end seal. Didn't see anything glaringly obvious. But the garage definitely stinks like it!
  4. Oct 20, 2023 at 1:06 PM
    Rocko9999
    2011 Limited
    Interesting. Might be worth dropping the skid plate to get a closer look.
  5. Oct 20, 2023 at 1:32 PM
    Technologic80
    Chris
    SE Michigan
    Should I though? It only has 350 miles and I've owned in exactly 9 days. Im feeling like making a dealer appointment and letting them check it out. Going to try it 1 more day and see if my garage stinks again, maybe it was just overflow??
  6. Oct 20, 2023 at 1:35 PM
    Matt83
    Matt83 New Member
    Northeast
    I would call the dealer if you can not find the source of the leak. Overflow? Not likely.
  7. Oct 20, 2023 at 1:37 PM
    Technologic80
    Chris
    SE Michigan
    Shit. Ok. I was grasping at straws on it being overfilled from the factory (it=axle, front diff, t-case). The smell is unmistakeable gear oil. I just went around the garage with the truck pulled out looking for any drips/puddles (none found) and looked for any remnant of gear oil, such as a funnel or opened quart laying around (none).
  8. Oct 20, 2023 at 1:50 PM
    Rocko9999
    2011 Limited
    Yeah, take it in. Shouldn't be that strong.
  9. Oct 20, 2023 at 8:36 PM
    Weird…. The breather for the front diff and transfer terminate in the engine bay near the drivers side of the engine. The rear is a check valve on top of the pumpkin. You could sniff around to see if one or more are the source of the smell.
    I think if I smelled it coming out of the breathers I would take it in. It’s not supposed to make your garage smell like gear oil. But maybe leave it outside a day or two to be extra sure the garage stops smelling. You’d hate to subject yourself to the dealer unless absolutely necessary.
  10. Oct 20, 2023 at 8:59 PM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Look for a pinion seal leaking front or rear slinging on exhaust but gear oil stinks burning or not for ever. Make sure transfer case to transmission seal not leaking either. They had a few issues on some
    Rocko9999 likes this.
  11. Oct 20, 2023 at 9:00 PM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    They might have undercoating the exhaust
  12. Oct 20, 2023 at 9:01 PM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    My bad. You don't have enough miles to worry yet.
    runnerjimmy likes this.
  13. Oct 23, 2023 at 8:16 AM
    Rocko9999
    2011 Limited
    I spilled some fresh Redline gear oil on an old favorite shirt of mine while changing my front and rear diffs. I soaked it in a bucket with Dawn dish soap for a couple of hours, scrubbed it, washed it 3X and it smelled just as bad as it did before I washed it. Threw it out. That stuff is just plain nasty.
  14. Oct 23, 2023 at 11:44 AM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    Do you have the TRD Exhaust? Because it smells when brand new
  15. Oct 23, 2023 at 2:40 PM
    It could be the tires being new. I doubt is gear oil.
  16. Oct 23, 2023 at 6:31 PM
    JS222STL
    JS222STL New Member
    2020 SR5 premium
    Normal smells unless you see fluid. Give it a couple weeks.
  17. Oct 23, 2023 at 8:43 PM
    I used to get that gear oil smell in the cab when I parked on a steep driveway over night. Never got it when parked on level ground.
  18. Oct 24, 2023 at 7:21 AM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    I don't know... all vehicles, when new, have their own smells. Diesel P/U's usually smell like half burnt diesel fuel. A strong V-8 in a car with a traction control "OFF' button, will smell like fresh burnt rubber. Cold catalytic converters smell like rotten eggs.
    Agitated gear oil just plain stinks and it's doing just what the axle vent is designed to do, vent.
    Be glad it doesn't smell like baby diapers.
