Gas gauge
Discussion in '4th Gen 4Runners (2003-2009)' started by Cooper_05, Feb 16, 2024.
  1. Feb 16, 2024 at 5:28 AM
    Cooper_05
    Cooper_05 [OP] New Member
    05 fourrunner
    275/60r20 tires 2 inch lift
    Hey I have an 05 four runner and my gas gauge gets stuck every time I fill up my tank. It usually goes back to normal after a while but does anyone know how to fix it
  2. Feb 16, 2024 at 11:55 AM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    More info please, what do you mean by "stuck"?
  3. Feb 16, 2024 at 11:56 AM
    Cooper_05
    05 fourrunner
    When I fill up the tank the gauge does not go up
  4. Feb 16, 2024 at 12:36 PM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    It sounds like the fuel gauge float is sticking, or bad sending unit, if so it means you have to drop the fuel tank to replace the fuel pump/sending unit assembly which the float is a part of and it's all in the tank.
    ID_Yeti likes this.
  5. Feb 18, 2024 at 7:12 AM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Fuel sending unit is a known 4th Gen issue. may be helpful as it has pics of the unit and an explanation of how it goes bad. There's also a video somebody did that is a deep dive into this issue.
  6. Feb 18, 2024 at 5:14 PM
    gkomo
    gkomo New Member
    San Diego, CA
    2014 Tacoma AC 4x4
    I have a feeling mine is just starting to go, once I get to 1/8th tank it sort of doesn’t move. Ran out of gas the first tank when I owned it cause the guage read 1/8th tank but it was obviously empty. This was before I knew about the Miles Till Empty on the center information mode.
