Fumoto Clearance
Discussion in '5th Gen 4Runners (2010-2024)' started by AE1M, Jan 26, 2025.
  1. Jan 26, 2025 at 12:57 PM
    AE1M
    AE1M [OP] New Member
    Bob
    2024 TRD Off-Raod Premium
  2. Jan 26, 2025 at 12:59 PM
    STrooper and scottiezilla like this.
  3. Jan 26, 2025 at 12:59 PM
    Plenty of room! Have it on my '23 SR5P.
    Connor MacLeod likes this.
  4. Jan 26, 2025 at 1:32 PM
    Bagman likes this.
  5. Jan 26, 2025 at 1:35 PM
    AE1M
    Bob
    Hard as a brass fitting and leaking oil.
    MeefZah, icebear and Steely123 like this.
  6. Jan 26, 2025 at 1:37 PM
  7. Jan 26, 2025 at 2:12 PM
    AE1M
    Bob
    Mine with their removable plastic fitting for 3/8 tubing. Wasn’t sure if the long nipple would fit.
  8. Jan 26, 2025 at 2:23 PM
    2020 Venture / 2017 Tacoma
    Go with the longer one. It would make things much easier. Still plenty of room.
  9. Jan 26, 2025 at 2:36 PM
    jetta23
    jetta23 New Member
    do you have the long one installed on yours?
  10. Jan 26, 2025 at 8:00 PM
    Not on mine. I have the short ones in the taco and the 4R. The short ones makes it a bit difficult to attach a hose or the other pieces shown above. That's all.
    jetta23[QUOTED] likes this.
  11. Jan 26, 2025 at 8:49 PM
    Knarf
    Knarf New Member
    DFW
    2024 White SR5
    I have the long nipple with RCI skid, it does not stick out past the hole opening
    ID_Yeti, BGH2023 and 5thToy like this.
  12. Jan 26, 2025 at 9:48 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    same valve and skid plate on mine, long nipple is above plate.
    ID_Yeti, BGH2023 and jetta23 like this.
  13. Jan 27, 2025 at 8:45 AM
    FatChance
    Sedona
    2024 4Runner Limited
    Do you use one of the white plastic pieces (either the straight one or the 90* one) that snap on to the short nipple and that the hose attaches to, or do you just attach the hose directly on the short nipple?
  14. Jan 27, 2025 at 8:49 AM
    Bagman
    Bagman Dental Floss Tycoon
    Georgia
  15. Jan 27, 2025 at 9:33 AM
    I find no need to connect tubing to your Fumoto valve.
    The stream is very predictable.
    Toy4X4, java, icebear and 2 others like this.
  16. Jan 27, 2025 at 9:41 AM
    coachhomer
    coachhomer New Member
    Thats what she said
    java and ChessGuy[QUOTED] like this.
  17. Jan 27, 2025 at 10:23 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I hate to be a stickler here... But is loosening a drain bolt that much of a pain?
    I've just never understood the need for this. Wouldn't this add an unnecessary failure point? What if the valve fails/ leaks... I just don't get it
    :crapstorm:
  18. Jan 27, 2025 at 10:29 AM
    coachhomer
    Ive used Fumoto valves on every car I have owned. Had a 2012 Ford raptor with 195k on it and it never leaked a drop. Makes the oil changes incredibly easier and less messy. But if you have reservations then don't do it. I have them on 5 of our cars.
    Toy4X4, Bagman, nimby and 2 others like this.
  19. Jan 27, 2025 at 10:53 AM
    No. I use just a hose with a clamp so that I don't make a mess and the wind doesn't mess me up as the final drips sometimes tend to go slow. Something like this.
  20. Jan 27, 2025 at 10:57 AM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    i agree. Used the nipple and hose first time then ditched it. Just drain direct from valve now.
    nimby[QUOTED] and Guppy1301 like this.
  21. Jan 27, 2025 at 11:59 AM
    None of it is such a pain. But for anal retentive OCD types like us who change our oil twice as much as the manual recommends, every step removed from the process helps. Loosening the bolt is just the first step. Then there’s:
    • Wiping the oil off your hands
    • Prying the washer off the bolt or pan, whichever it’s chosen to weld itself to.
    • Wiping oil off of bolt and pan
    • Installing new washer and bolt
    • Setting the torque wrench
    • Torquing down the bolt
    vs.
    • open Fumoto valve
    • Close Fumoto valve
  22. Jan 27, 2025 at 12:03 PM
    SOSHeloPilot
    SOSHeloPilot New Member
    SouthEast USA & S.E. Asia
    2024 4Runner SR5
    Owned Many Toyotas - Past
  23. Jan 27, 2025 at 12:44 PM
    Not to mention when laying on my back I gotta unscrew the bolt by hand while applying a bit of pressure, gauge when it’s unthreaded, pull it out quickly and sometimes oops! I dropped it or got oil on my arm. (the former isn’t an issue unless I’m using the cheap drain pan)
    This isn’t an issue with the 4Runner since the drain is vertical but on the Honda’s I care for, the drain is sideways and I’m always needing to gauge how far to place the drain container so as to catch the oil, and then pull it back under the engine as the flow slows.
    And on occasion the oil splashes off the container due to the shallow angle based on positioning. Edit: And exacerbated by being on ramps or jackstands.
    Adding a Fumoto to those applications has certainly made things easier. If my drain containers are full, it can be routed right into a jug too.
    nimby, Toy4X4, Bagman and 1 other person like this.
  24. Jan 27, 2025 at 12:47 PM
    Not only that, but if you accidentally over-fill it’s easy to drain a little oil out.
    Bagman, icebear and AE1M[OP] like this.
  25. Jan 27, 2025 at 1:01 PM
    1SilverRunner
    Tejas
    I change mine every 3-5k.
  26. Jan 27, 2025 at 1:47 PM
    I don’t use mileage or time as a guide. I wait until visions of scored cylinder walls, sludge-covered valve trains, and oil as black as pitch all creep into my dreams. Then I change the oil, no matter time of day or night.
    Guppy1301 and MeefZah like this.
  27. Jan 27, 2025 at 2:00 PM
    java
    java phoRunner
    2023 ORP ice cap
    too poor for mods
    I think with the bolt there is a risk double gasketing, or forgetting the gasket, cross threading etc. One needs to use a torque wrent every time with the bolt. I was skeptical at first too. But once I saw the Fumoto in person, it is a simple ball lock valve, I do not see a way it could just fail. Either the body gets catastophically cracked, or the ball itself explodes. Any other failure would be a slow leak, which I am willing to live with given the convenience. I keep the original drain plug bolt with a new gasket in the vehicle, just in case.
    STrooper and Toy4X4 like this.
  28. Jan 27, 2025 at 2:28 PM
    1SilverRunner
    Tejas
    Now that's a funny visual. Wake up in cold sweats. Tell the wife you have to go. Frantically go change the oil in the garage by flipping your oil drain switch.
    Fumoto should have an ad campaign on this idea.
  29. Jan 28, 2025 at 3:22 AM
    We had the long nipple valve on at 1st, (I mis-ordered the part number) when I looked at it I was skeptical, but took some cardboard and taped it to the skid pan, the valve made an indent on the cardboard and there was adequate room between the skid and valve. We have a few applications with Fumoto, upon ordering another valve with the same thread as the 4Runner, I ordered the short nipple, I decided to put the short one on the 4Runner and the long one elsewhere, but both will work on the 4Runner.
    BS67 likes this.
  30. Jan 28, 2025 at 4:33 AM
    STrooper
    STrooper Let’s Go Places!
    I have the valvomax
    I was between the Fumoto and the ValvoMax and decided to go with the ValvoMax as the device offers double leak protection. I’ve had mine for 5years and no issues at all. I’m very happy with it!
    Toy4X4 and java[QUOTED] like this.
