Fuel sender obsolete?
Discussion in '2nd Gen 4Runners (1990-1995)' started by cfaulkner00, Feb 21, 2020.
  1. Feb 21, 2020 at 7:02 PM
    cfaulkner00
    cfaulkner00 [OP] New Member
    Hey everyone,
    First off, Im in Australia, so I hope someone can help me... not sure if my model was ever sold in the US. Im having a lot of trouble finding a new fuel sender for my 95 2.8L diesel (LN130R). Mine is cracked and is leaking badly when filled past 2/3 tank. The dealer gave me the part number 83320-80134 but said that they're not available.
    Is there anywhere that has this part? Is there an aftermarket version? Does the part number supercede to a newer version? Is there a similar version from another model that would work, even if its slightly different (without low fuel thermistor, perhaps from a landcruiser or something?)?
    Ive been looking for days and cant find any helpful information.
    Thanks,
    Chris
  2. Feb 21, 2020 at 8:20 PM
    japhroe
    japhroe New Member
    Jdiddy
    1994 4runner 2WD AT
    ALL STOCK 100%
    Sounds like a diesel Hilux.. wish I had one! The parts for the diesels are available in japan. Lots of them.. all the deisels here in USA were mostly imported.. only Hilux diesels 4Runners I’ve seen are all over the Middle East and Asia... good luck mate!
  3. Feb 21, 2020 at 8:25 PM
    japhroe
    japhroe New Member
    Jdiddy
    1994 4runner 2WD AT
    ALL STOCK 100%
    D9C94475-335A-476D-B310-04EF156698DB.jpg Out of curiosity I did 20 second google search and found it.. or close
    See pic.. give KS a call..
  4. Feb 21, 2020 at 8:44 PM
    cfaulkner00
    Thanks a lot for the reply. I also saw that 80119 part, though it took me a lot longer than 20 seconds to find :facepalm:. Looks to be similar, just without the low fuel light thermistor. I wonder if the resistance is the same between the LN106 and the LN130... They have the same fuel capacity...
    I guess Ill just have to suck it up and try it out.
  5. Feb 21, 2020 at 9:40 PM
    cfaulkner00
    After a bit more looking I found that despite being the same volume, the LN106 and the LN130 have different fuel tanks. The sender on the 106 mounts to the top rear of the tank, the 130 mount to the top front, where the tank is stepped down quite a bit. The gasket is the same, though....
  6. Feb 22, 2020 at 8:01 AM
    japhroe
    japhroe New Member
    Jdiddy
    1994 4runner 2WD AT
    ALL STOCK 100%
    I would call them or a similar parts company.. Hilux parts are all over Asia and the ME...
  7. Feb 22, 2020 at 5:03 PM
    cfaulkner00
    I contacted a few places in Japan and Dubai, but they also said that the part is no longer available. I sent some emails to a few other parts places and they all said that the 80119 part wouldn't work. I may just make a blanking plate and cap off the sender location. Its a bummer that no one has the right part anymore.
  8. Feb 22, 2020 at 5:40 PM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    Can you use a universal sending unit?
  9. Feb 24, 2020 at 1:18 AM
    92T4R
    92T4R New Member
    Perhaps you could go external....
  10. Feb 24, 2020 at 1:23 AM
    92T4R
    92T4R New Member
    Sorry mate, read the post wrong initially, going external would be for fuel pick up.
    Your just having an issue with it communicating your fuel level. Correct.
    There are MILLIONS of these rigs. You will find one.
