Fuel pump, buy used???
Discussion in '4th Gen 4Runners (2003-2009)' started by ScottVee, Aug 19, 2022.
  1. Aug 19, 2022 at 6:20 AM
    ScottVee
    ScottVee [OP] New Member
    1997 Silver 4Runner Limited
    I have an'06 4Runner. Are there any problems with getting a used fuel pump from a salvage yard or would it be best to get an aftermarket used one?
  2. Aug 19, 2022 at 10:34 AM
    Buy a Denso. Never use used fuel pump. Aftermarket parts are hit or miss. Denso is the oem supplier and they'll be the same quality but cheaper than the dealer.
    7385 likes this.
  3. Aug 19, 2022 at 10:41 AM
    Bikeric
    Bikeric New Member
    Eric
    2003 V8 4x4 ARB Locked and Lifted on 35's with 4.88's
    You have to drop the gas tank on an 06 to change the fuel pump. After all that work I'd be putting in a new Denso pump and never worry about again.
    canadian.bacon and BearBio like this.
  4. Aug 19, 2022 at 11:08 AM
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Roof rack, side bars
    My '85 Toy p/u had a fuel sensor chip go out. It was $300 (in the late '90s) for a new one. Mechanic recommended getting a used one from the junkyard for $50. If it didn't work, get another one. Even if we had to go a third time, it would still be cheaper. (He said about 1 out of 4 wouldn't work). The first one worked like a charm=sold it with 329K on the odometer.
    BUT, in your case, you have to drop the gas tank, so it would be labor intensive to do it more than once!
    7385 likes this.
  5. Aug 19, 2022 at 6:53 PM
    Good luck. Both my fuel pumps went out on my Camaros. I’m testing local mechanics ability on one and it’s been to two shops, away from home over a month.
