Fuel injector Cleaner
Discussion in '5th Gen 4Runners (2010-2024)' started by danssr5, Jun 28, 2019.
  1. Jun 28, 2019 at 11:05 PM
    danssr5
    danssr5 [OP] New Member
    Dan
    2017 sr5 premium 4x4
    My 4runner has 51k miles on it. Lately it "seemed" like the lifters were slightly noisy. I realized the injectors probably needed some TLC. The 4runner just has a screen in the fuel tank and no fuel filter. This is exactly how my nissan 350z was set up. Taking from the same playbook I put some lucas fuel injector cleaner and cleaned the Maf sensor. Made a HUGE difference!!! I guess o get desensitized slowly over time.
    Screenshot of what i used if anyone is interested.
  2. Jun 29, 2019 at 1:16 PM
    DrewMan
    DrewMan 2016 4RTP-KDSS
    Middle Tennessee
    2016 Magnetic Grey 4Runner Trail Premium
    Bilstein 5100 Series Shocks, Daystar 1.5" Rear Coil Spacer (Mid Left), Level 8 Tracker Pros 17x9, 275/70/R17 B.F. Goodrich TKO's, N-Fab Nerf Steps
    Thanks for sharing with us; I’m getting closer to same mileage myself in my 2016 4RTP, so on my next oil change will have to do it.
  3. Jun 29, 2019 at 3:18 PM
    danssr5
    Dan
    No problem.
    16 bucks
    Walmart!
    KSJ08 likes this.
  4. Jul 1, 2019 at 12:45 PM
    PaulB-2006 T4R
    PaulB-2006 T4R New Member
    Paul
    Twin Cities, MN
    2016 Trail MGM
    Falken Wildpeak AT3W. Matte Black TRD Wheels. Leveled with 2" spacer. All LED interior. Mud flaps deleted. TRD Air Filter. TRD Oil Cap. Heated Front Seats. FJC Shifter. Subaru Kicker tweeters.
    If there was an immediate change in the feel of your 4Runner (butt dyno) I would guess the MAF Cleaner is to blame. For the most part unless you are buying the cheap gas from a no name station then most gas will have sufficient detergents. My vehicles are only filled with Top Tier gas but I also through in a bottle of Chevron cleaner ever 5,000 miles.
    I cleaned my TRD engine air filter and also cleaned the MAF sensor with the CRC. Good stuff!
  5. Jul 2, 2019 at 12:53 PM
    WallyT4R
    WallyT4R New Member
    I use Amsoil P.I. right before an oil change so every 7500-10K. Hammer it for a full tank of gas and then change the oil.
    JET4 likes this.
  6. Jul 2, 2019 at 9:57 PM
    4runningMan
    4runningMan New Member
    New Mexico
    You just pour this stuff into the gas tank?
  7. Jul 3, 2019 at 6:45 AM
    JET4 New Member
    I run a bottle of Amsoil P I about twice a year
    WallyT4R likes this.
  8. Jul 3, 2019 at 9:15 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    so what was the change in the engines operation... I do use Lucas products ..
    maf CRC cleaner I use and clean the Maf 20K miles on all my vehicles GM/toyota..if maf gets dirty then the throttle response will slow..
  9. Jul 3, 2019 at 11:11 AM
    danssr5
    Dan
    Very smooth at idle and throttle
    j cat[QUOTED] likes this.
  10. Jul 3, 2019 at 11:15 AM
    danssr5
    Dan
    Yes. Make sure you are filling up all the way as this stuff says it treats up to 30 gallons.
    Dump the bottle in first and then fill up
    and I would do this with about a half a tank or less of gas so that it mixes right.
  11. Jul 3, 2019 at 11:18 AM
    danssr5
    Dan
    FYI I have never used Lucas before. I have always used Prestone fuel injector Cleaner. Amazon will no longer deliver this in my area and its sad because it was 24.00 for 6 bottles. Even my local stores do not carry it. It's probably a stupid California thing. I really should work towards leaving the country by moving out of state.
    WallyT4R and 4runningMan like this.
  12. Jul 3, 2019 at 11:46 AM
    4runningMan
    New Mexico
    Should I do it even with just 15k miles on a newer truck?
  13. Jul 3, 2019 at 12:28 PM
    WallyT4R
    WallyT4R New Member
    Won't hurt. I do it every oil change and have since new. Maybe I am wasting my money, maybe not, but it always runs better after a treatment.
  14. Jul 3, 2019 at 1:53 PM
    danssr5
    Dan
    Its up to you. better to do preventative maintenance than have things screw up. But in all honesty This is the first fuel injector cleaner I have ran and I have 51k miles. Started running a little rough a few hundred miles ago.
    another tip for preventative maintenance that i personally do is to drain/refill the radiator only every 10k miles. This ensures that the coolant is ALWAYS clean!
  15. Jul 6, 2019 at 7:37 AM
    j cat
    j cat New Member
    massachusetts
    anti freeze 10K miles ? well I do it every 4 yrs ... I had to replace my radiator on my 96 GM sedan because the plastic side tank had a small crack.. when I removed that radiator 23 yrs old original owner the inside of it looked like the new radiator I installed alum was bright and shinny.. I use 65% anti freeze and distilled water.. toyota only has 50% coolant so that should good ..
    last month I was gonna return 3.5gallons of my used coolant .. I could not return to the auto stores anymore.. I called up the towns recycle of haz waste and they were gonna charge me $70 ..
