Fuel gauge not reading correctly
Discussion in '3rd Gen 4Runners (1996-2002)' started by Mikey96Rnner, Jun 20, 2023.
  1. Jun 20, 2023 at 4:00 PM
    Mikey96Rnner
    Mikey96Rnner [OP] New Member
    1996 4Runner Limited black
    3 inch lift
    I have a 1996 4runner limited. My fuel gauge does not read correctly. The needle will go to full when I fill up the truck. After will start to wonder between full and empty. Truck when fuel get low the light will turn on and it is accurately turning on on but the needle is still wondering. Any ideas. I already tried to give it a good ground. Thanks
  2. Jun 24, 2023 at 5:53 AM
    Ahdofu
    Ahdofu New Member
    Matt
    Quite likely that the fuel level sending unit needs to be replaced. There is an informative video on this.
    https://youtu.be/GrzX_K-jcuo
    negusm likes this.
  3. Jun 25, 2023 at 8:42 PM
    Yes, typically a bad fuel sender. I replaced mine and my wandering fuel gauge is perfect again.
    Figure on replacing the fuel pump too (denso only) as well as the big plastic valve on top of the tank.
