Fuel gauge issue
Discussion in '4th Gen 4Runners (2003-2009)' started by DM75, Jan 3, 2022.
  1. Jan 3, 2022 at 7:17 PM
    DM75
    DM75 [OP] New Member
    2007 4Runner
    Hello,
    My fuel gauge just started reading like I am on empty (07 SR5) but l just gassed up with a full tank and my digital reader is showing around 275 miles so long have a way to show about how many miles l have left to go. Should l worry about this or just drive? I just don’t want to worry if there could potentially be any underlying dangerous issues. Thanks in advance!
  2. Jan 5, 2022 at 7:35 AM
    On the 3rd gen (and most cars), that would be a bad sending unit in the tank. Nothing dangerous. When mine went out, I filled her up, zeroed the trip meter and made sure I filled up again before 300 Miles.
    On the 3rd gen you have to drop the tank to replace, probably the same on the 4th gen. If that is the case, I would have any/all gaskets replaced along with the fuel pump.
    In my case, I dropped the tank and replaced the sending meter. Then a year later I got an Evap code...so I had to drop the tank AGAIN to fix and I just replaced most everything including the fuel pump because dropping the tank isn't fun.
  3. Jan 5, 2022 at 10:53 AM
    DM75
    2007 4Runner
    Thanks so much for your help. I think l will use the trip meter method
  4. Jan 5, 2022 at 2:51 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    I would replace the fuel cap before dropping the tank.
    I had the same issues with my 2007 FJ cruiser and my 2013 5th generation, which are close relatives of your truck.
  5. Jan 5, 2022 at 8:26 PM
    How does changing the fuel cap fix a bad fuel sender?
    importman likes this.
  6. Jan 6, 2022 at 8:04 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    The fuel system runs on a vacuum. If the gas cap does not make a good seal then the vacuum will never be created, and the system might not register right. In your case, possibly showing as consistently empty
    LandCruiser likes this.
  7. Jan 6, 2022 at 8:11 AM
    No. The FUEL SYSTEM runs on pressure. The fuel pump creates pressure to send fuel to the engine.
    The EVAP system runs on vacuum...and is affected by the gas cap. Is that what you meant?
    BUT, I don't see how the gas cap is going to fix a SENDER issue. The Sender is a float setup in the tank which doesn't use either pressure or vacuum.
    I provided EVAP information because it will be a problem down the road...and if you are replacing the SENDER...it's worth replacing any of the seals for anything else in the tank...if you have to drop the tank. For my issue, yes, I replaced the cap to try and solve the EVAP code it but it didn't help. OP doesn't have any EVAP issue yet.
  8. Jan 6, 2022 at 8:47 AM
    LandCruiser
    East Bay Area
    5th Gen OG TE
    I’m saying is I had the exact same problem with two similar vehicles and all the problems that you were describing happened, and replacing the gas cap solved it, so unless you are confident that it is a fuel sender issue, I would replace the gas cap first.
  9. Jan 6, 2022 at 9:30 AM
    https://www.ebay.com/itm/323959169934?fits=Year%3A2007%7CModel%3A4Runner&epid=658609712
    This is the sender for a 2007 4Runner. It is a dirt simple device with a float that moves based on the fuel level. The float moves a bar which is connected to a potentiometer (white box) which is read by the gas gauge on the dash (or by the ECU...not sure). No vacuum is involved which is what a new gas cap would play a part in.
    The only crazy way I could see a gas cap affecting the sender...is if the ECU is reading the sender and won't send the right data to the gauge if something else is wrong in the EVAP system. That would be outlandish and really bad engineering...but maybe newer cars are that bad?
    AColbe likes this.
  10. Jan 6, 2022 at 9:37 AM
    LandCruiser
    East Bay Area
    5th Gen OG TE
    The fuel caps have vents in them which stop working over time, usually from environmental contamination, and will mess with the evaporation system.
    On both of my vehicles I was just driving and the fuel gauge dropped down to empty from completely full, but no other warning light came on.
    Both times replacing the fuel cap with a new Toyota fuel cap fixed it.
  11. Jan 6, 2022 at 9:44 AM
    Gotta be something else in the mix then. Maybe the ECU is in the equation somewhere. That would be a PITA to diagnose.
  12. Feb 11, 2022 at 5:52 AM
    DM75
    2007 4Runner
    Update! I replaced the gas cap and the problem appears to be solved! I still 0 out my trip meter just to be safe but everything appears to be in working order. Thanks so much for all of your responses.
    LandCruiser and spencermarkd like this.
  13. Feb 11, 2022 at 9:01 AM
    Whelp. Lesson learned.
  14. Feb 11, 2022 at 2:46 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
  15. Feb 12, 2022 at 10:56 AM
    Yeah, good call by him.
    I'd still like to know HOW a fuel cap screws with the fuel sender though? It's literally the simplest system for measuring fuel level but somewhere it's in some way connected to the gas cap by way of the evap system.
  16. Feb 12, 2022 at 1:08 PM
    AColbe
    AColbe New Member
    2014 Trail
  17. Feb 12, 2022 at 1:14 PM
    AColbe
    AColbe New Member
    2014 Trail
    This guy knows the facts! The electrical thing attached to the float can become oxidized and not make the variable electrical connection to vary the needle on the gauge!
    I had a car one time if I didn’t run gasoline w Techron the the dash gauge wouldn’t work right….. had been buying cheap gas.
    Keep the 300 mile range in view but try a top tier fuel for a couple of tanks to clean up the fuel system!
  18. Feb 28, 2023 at 12:16 PM
    RedShadow
    RedShadow New Member
    2004 4Runner Sport V8
    Hello there,
    New member here. I have a similar, but different issue. 2004 Sport V8. Fuel gauge on cluster reads empty, the gas light stays on constant, as well as the Range remaining on the digital display with the clock also says zero(0) miles. I've been using the trip A meter and resetting every fill up.
    Not sure what may be causing this - possible electrical issue since both are affected? Mice chewed the wires? Fuse? Any help and suggestions are much appreciated. Thanks in advance.
  19. Feb 28, 2023 at 8:07 PM
    RedShadow
    Sorry for double post, but... did some research, took the back seat out above the access gas tank, and found the wires were indeed chewed to the 5 pin connector going to the fuel pump. I resoldered those, and everything seems fine now. Cheers.
  20. Apr 3, 2023 at 7:25 AM
    Rampage
    Rampage New Member
    I had this happen on my 09'. I dropped the tank and replaced the potentiometer that also has the float attached to it. Not a hard job at all. Only took me about 4 hours start to finish and fixed the problem. I think I paid just over $100 for the part from Toyota.
