Front suspension thoughts.
Discussion in '5th Gen 4Runners (2010-2024)' started by Winston#5, Feb 10, 2026.
  1. Feb 10, 2026 at 4:24 AM
    Winston#5
    Winston#5 [OP] New Member
    So I went through reviews and searches. I'd like some thoughts on keeping as close to stock ride height as possible but a better front end ride. 1" lift or so would be fine too but it will occasionally tow a 3000lb boat. The dive upon braking is bad. Truck has 135k on it also. It's a 2019 sr5 premium. I'd like to just get preassebled coil overs. Right now thinking of kyb srg4528/4529 kits. Rockauto has them for about 350 pair. Having a hard time finding bilsteins preassembled and coils springs that are 0-1"lift. Thoughts on this vs?
    TrailSpecial22 and NB4x4 like this.
  2. Feb 10, 2026 at 4:56 AM
  3. Feb 10, 2026 at 5:17 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Get 6112's and don't look back. Best thing I've done for my 4Runner. Someone here had problems with KYB's. KYB wasn't too helpful IIRC.
  4. Feb 10, 2026 at 10:48 AM
    i will cast my vote for the Eibach Pro Stage 2. Had them for 70k miles and have done some solid off roading with them. My front driver side just blew and Eibach stood by their warranty and sent me a replacement free of charge and a hassle free experience. I dont know if Bilstein offers the same customer experience. KYB is decent but if you plan on going on rough terrain, Id go with EIbach. If you plan on just street driving, go with KYB
  5. Feb 10, 2026 at 11:06 AM
    94hokie
    94hokie New Member
    23 TRD ORP Lunar Rock
    Been happy with my Bilstein 6112's, but to morf's point, I wish I had known more about the Eibach Pro Stage 2's when I decided to go aftermarket. Those look very solid and offer much easier height adjustment relative to the 6112's.
  6. Feb 10, 2026 at 11:17 AM
    its funny you called me "morf". That was my nickname growing up. All my buddies call me Morf. Yeah, the eibachs have been solid. 2 Toyota Jamborees, 3x to Moab, Colorado 2x and they have just exceeded my expectations. Plus, the way they processed my warranty was exceptional. I was in a boulder garden in AZ, how i survived without damage is beyond me. I started hearing a squeak and knew something gave out. - I included a pic, what you dont see is to my left is like a 1,000 foot drop off and that rock garden lasted 2-3 miles. IT SUCKED. A side-by-side passed me and waited for me to get to the end. He told me....."we took bets on how bad you were going to damage your truck" Jokes on them. My 4R dominated. Nobody tell my wife i posted this pic. She gets pissed.
    94hokie[QUOTED] likes this.
  7. Feb 10, 2026 at 11:18 AM
    If you don't mind spending the money, 6112's are going to be a great set-up.
    If you don't want to spend that much, get a pre-assembled set of 5100s with a 600lb (stock height) coil spring set at 0.85 inches.
  8. Feb 10, 2026 at 11:49 AM
    OregonTrail
    OregonTrail New Member
    Jennings Lodge, Oregon
    2011 Silver 4Runner Trail Edition
    Currently 5100 front/5160 back shocks just to level, also running "E" rated tires
    I have a 2011 Trail and tow a boat a lot thats about 3200-3300# loaded. I'm running 5100's up front set at .85 and 5160's in the back that are toast but worked great, a few more $$ but a much better set-up. I'd probably do 5100's in back as well to save a bit of money and consider replacing the back coils while you are at it to help with the tongue weight.
    Toy4X4 and nimby[QUOTED] like this.
  9. Feb 10, 2026 at 1:22 PM
  10. Feb 10, 2026 at 6:45 PM
    Gravel
    Gravel New Member
    SR5 4x4
    That’s a great video, he hits all the important points except I’ve always let the truck down on its weight before tightening the control arms and bottom shock bolt.
    nimby and TrailSpecial22 like this.
  11. Feb 10, 2026 at 6:55 PM
    just my $.02 but for a daily driver I love my set up for 2022. Bilstein 6112 with 600 lb springs set at 2” for the front and Wheelers T13 1.5” lift rear coils paired with Bilstein 5100.
    or on my 2011 SR5, Bilstein 5100 with stock coils set at 2” up front or you can go 0-1” as you prefer and in the rear, stock coils with 1” poly spacer with 5100 shocks.
    Lc200, Toy4X4, roooo and 1 other person like this.
  12. Feb 10, 2026 at 6:57 PM
    NB4x4 and nimby[QUOTED] like this.
  13. Feb 10, 2026 at 7:43 PM
    I don’t think much about my front or rear end.
  14. Feb 26, 2026 at 6:26 PM
    Winston#5
    I got 5100's. Going to try the fronts set at clip 2 for the .8" lift and see how it goes. I did order new kyb mounts/tops too. Sticking with oem springs and bought timbrens for the rear for towing. Will see how it comes together. This is my daily so I don't want to go crazy with a lift and bigger tires
    nimby, NB4x4 and TrailSpecial22 like this.
  15. Feb 26, 2026 at 6:44 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    I had KYB struts on my Pilot. Just okay-should have done oem Honda, but was short on funds at the time.
    Are you upgrading front and rear bump stops?
    NB4x4 likes this.
  16. Feb 26, 2026 at 6:53 PM
    Winston#5
    rear bump stops with timbrens for towing. It's still winter here so I won't know till spring. Occassionally will tow a small trailer and my 19' boat. I have a tundra crewmax for most of my towing needs. KYB quality hasn't been great the past 5 years. A decade ago they were top notch.
  17. Feb 27, 2026 at 2:32 AM
    Welcome from Wisconsin! I thought Shock Surplus offered assembled Bilsteins, 6112's in front, 5100's in back or 5160's for a little more dampening longevity. Good luck.
  18. Feb 27, 2026 at 5:51 AM
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    A first or second gen pilot?
  19. Feb 27, 2026 at 6:11 AM
    Hungryhawk
    Southern CA
    2017 SR5
    A 2004 first gen. No VCM and I sold it after 20 years and 240,000 miles.
    NB4x4[QUOTED] likes this.
  20. Feb 27, 2026 at 6:39 AM
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    Our 07 is at 226,000 the last 10 years it's rarely left the farm and we've abused it. In the process of putting kyp in the front. It really stinks how limited the suspension options on these are.
  21. Feb 27, 2026 at 10:03 PM
    Hungryhawk
    Southern CA
    2017 SR5
    On your Pilot, Do you use the dash button to lock in the rear axle(VTM I think)?
    I did once driving on fresh snow at a Sierra ski resort. Not because I was stuck but just to see how it worked.
  22. Feb 28, 2026 at 5:07 AM
    San Angelo
    San Angelo New Member
    Rock auto has great prices on 6112s. For an all around daily driver that you want lifted they are great.
    It’s also easy to find a coupon ion line to get a few buck more off of them.
    Gravel and Toy4X4 like this.
  23. Feb 28, 2026 at 5:30 AM
    Sin4R
    2024 4Runner Limited
    Mall crawling kit.
    Keep in mind, while trying to solve very real issue of dive upon braking you can create other issues. This is because front vs. rear suspension stiffness also changes how 4Runner behaves at the limit of traction (e.g., wet, icy conditions) while turning. Putting stiffer suspension but only in the front is likely to result in more understeer.
    San Angelo likes this.
  24. Feb 28, 2026 at 5:58 AM
    NB4x4
    NB4x4 New Member
    Illinois
    2003 v8 sr5 4wd
    Ours is only fwd.
  25. Feb 28, 2026 at 9:48 AM
    I'm going to argue that the valving on the front of 4Runner is too soft to begin with. This warrants a firmer valving, IMO.
    However, the rear shocks are actually matched pretty well to the stock weight in the back.
    I have a Eibach shocks up front and stock rear shocks. It rides really nice and I don't get any weirdness in turns, wet or icy conditions.
    TrailSpecial22, Toy4X4 and NB4x4 like this.
  26. Feb 28, 2026 at 4:50 PM
    Winston#5
    UPDATE Got the 5100's put in today. Front at 2nd notch. Lift is about an inch maybe a little more even...supposed to be .86. Also put lean spacer on LF. Did my alignment after a quick road test on shitty roads. Drives really nice now like how it should have from the start. Nosedive is 90% gone and just going around a corner feels 10xs better. Other than my first set of snow tires years ago on my wife's van this is the best $500 upgrade I've done in years,
  27. Feb 28, 2026 at 5:00 PM
    CarlP
    CarlP New Member
    Carl
    Phoenix, AZ
    2018 Off Road with KDSS
    I have a Eibach shocks up front and stock rear shocks. It rides really nice and I don't get any weirdness in turns, wet or icy conditions.[/QUOTE]
    I plan to do this; did you leave the Eibachs set at there as-shipped preload or did you have to adjust to obtain level. Thx
    TrailSpecial22, nimby and NB4x4 like this.
  28. Feb 28, 2026 at 5:13 PM
    Winston#5
    bilstein makes the 5100s. 4 clip settings. I used #2. Reused old OEM springs and put new top hats on from kyb which appeared to be oem brand.
  29. Feb 28, 2026 at 6:03 PM
    Mine is on the 3rd clip from the bottom which is a 1.6" lift up front. I also added a 0.5" rear spacer.
    It has the same stance as a stock Pro except 0.5" higher all around.
    If you want yours closer to level (without touching the rear), you'll want to put your Eibach's on the 2nd clip from the bottom (0.85").
    Toy4X4 likes this.
  30. Feb 28, 2026 at 7:34 PM
    DocSR5
    DocSR5 New Member
    Cave Creek, AZ
    2023 SR5
    I went with the Billstein 6112s in front (preassembled from shocks surplus). Dobinson tubular UCAs
    Billstein 5100 rears with B12 Billstein spring.
    Durobump bump stops.
    The ride is so much better. Corners great. No more nose dive when hitting the brakes. I agree that the Eibachs are a solid option as u can adjust them easily (but there wasn’t much research on them when I did my build). Any of these options r solid.
    My cerclips r set at 4/6 and with the C4 bumper I’m at 1.4” lift in front and 1” lift in rear. Might go up to cerclips 5/7 which should pick the front up another 0.4” and level the truck nicely.
    Good luck.
    NB4x4 and Toy4X4 like this.
