Front suspension noise
Discussion in 'New Member Introductions' started by Badcat6821, Dec 17, 2024.
  1. Dec 17, 2024 at 2:30 PM
    Badcat6821
    Badcat6821 [OP] New Member
    Doug
    2012 4runner
    None
    Hello, just joined this page today and I’m looking for some help with my 2012 4Runner front suspension noise/clunk/ rattle. I got new shocks and struts put on back in April at a local shop that has been in business for close to 50 years. They work on a lot of upper end vehicles and didn’t seem to have any issues with my Toyota even though I was concerned about whether they could deal with the xreas system on mine. Within 2 weeks of getting it done, there was a very distinct clunk/ rattle in the front drivers side area and it seemed like it was coming from all over the underside but not as bad as the front. I’ve had it back numerous times since and they can’t seem to find or replicate the noise while in the shop. About a month ago they said I should replace the front drivers lower ball joint which they did and that solved nothing. The noise is even worse now that colder weather is here in Alberta. I’ve now spent close to 3000$ between shocks and ball joint and the problem is still there! Any suggestions would be great!
  2. Dec 17, 2024 at 2:32 PM
    Welcome!
  3. Dec 17, 2024 at 2:37 PM
    Welcome. I've been living with a strut squeak for a year or so. Lol. So I'm not any help with that part.
  4. Dec 18, 2024 at 3:19 AM
    Welcome from Wisconsin!
  5. Dec 18, 2024 at 7:03 AM
  6. Dec 18, 2024 at 10:41 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Welcome!
    Only way I'd know how to diagnose this is to lift up the truck and apply force on the wheel to check for bad bushings. If all bushings look/ feel good I'd start start suspecting the CV's or possibly the steering rack.
    But it's probably something simple like a upper ball joint, sway bar link, etc.
    Maybe someone else had a similar noise and can point you in the right direction.
  7. Dec 18, 2024 at 11:01 AM
    DesertSurfer
    Welcome to the forum.
  8. Dec 18, 2024 at 11:51 AM
    jkirkpatrick
    jkirkpatrick New Member
    If you're in Edmonton go to 4Wheel Auto on Argyll Road.
    If you're in Calgary, go to KRave.
    Both shops will find what your shop missed.
  9. Dec 18, 2024 at 12:10 PM
    Badcat6821
    Doug
    2012 4runner
    None
    Thanks for the input, every little bit of info helps! It’s frustrating when even the dealership can’t seem to come up with anything and they are saying to avoid taking it on the highway as a precaution.I’m down in Lethbridge and not really familiar with any shops that could possibly help although I’m still looking. I’m not an off-roader by any means and my vehicle has always been maintained by the Toyota dealership. The only reason I took it to the other place was 1) they said they had done this work before and 2) it was about 1000$ less than Toyota. I guess my biggest question is does this noise have anything to do with the work done by the smaller shop, or is it just a coincidence that it started soon after I got it back. Seems a little suspicious to me! Hopefully more people can send their thoughts
