Front Skid Plate
Discussion in '5th Gen 4Runners (2010-2024)' started by sweetsaltyair, Apr 7, 2026 at 9:10 AM.
  1. Apr 7, 2026 at 9:10 AM
    sweetsaltyair
    sweetsaltyair [OP] New Member
    2024 SR5 Premium
    Bilstein 6112/5160 TRDORP wheels
    RCI vs Rough Country. Any recommendations.
    RCI $349 RC $199
    kolter45 likes this.
  2. Apr 7, 2026 at 9:27 AM
    Both my TRD ORP and TRD Pro got RCI Aluminum full skids. (When I ordered for the TRD Pro I got a discount been a returning customer)
    I went with Aluminum for been light weight and my need of non technical trails driving. I understand the risk if I get a big hit on Aluminum I will be replacing vs steel can be fixed.
  3. Apr 7, 2026 at 9:37 AM
    Captain Sensible
    Captain Sensible New Member
    I bought a rough country bumper. For the life of me I couldn't get it flush. I could get one side flush but not the other. No one notices but me, still ugh! I guess their r&d ain't what it used to be. Just a word of caution.
    NB4x4 and sweetsaltyair[OP] like this.
  4. Apr 7, 2026 at 9:52 AM
    307WY
    307WY New Member
    Wyoming
    1997 Limited, 2021 TRD ORP, 2023 40th Anniversary Edition
    RCI all day long. Extrememely high quality products well designed and tough, definitely a case of you get what you pay for. I have a set of steel skids (engine and transmission, bumper filler, and cat guards) on my 2021 and the same set in aluminum on my wife's 2023. Aluminum is significantly lighter, but also costs more.
    In the past I've also used RIVAL skids which looked good and are cheaper, but their mounting hardware is cheap and will bend/deform if the skids are ever actually scraped on anything. If you want skids "just in case" and don't off road these would be fine and likely better than the Rough Country.
    Whammo, eurowner, NB4x4 and 1 other person like this.
  5. Apr 7, 2026 at 9:57 AM
    2019 TRDP w/Kangs brah!
    Definitely RCI. Never buy junk country anything.
    eurowner, NB4x4 and sweetsaltyair[OP] like this.
  6. Apr 7, 2026 at 10:30 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    ^ buying zero rough country things really is wise advice. ARB steel skid plates are competitively priced if you aren’t set on aluminum. Facebook marketplace could be your friend.
  7. Apr 7, 2026 at 3:54 PM
    eurowner, NB4x4 and roooo like this.
  8. Apr 7, 2026 at 4:09 PM
    Rough country more like dumb country
    Mods pls dont delete this threa
    NB4x4 likes this.
  9. Apr 7, 2026 at 4:18 PM
    sweetsaltyair
    2024 SR5 Premium
    Thanks all...RCI it is !
    roooo likes this.
  10. Apr 7, 2026 at 4:31 PM
    Have you looked at other companies? Here are some on top of my head and could be more companies. I'm sure there are other members running them.
    CBI
    C4
    CaliRaised
    Ironman
    Victory 4x4
    ARB
    LFD
    RSG
    Talons garage
    Hefty fabworks
    ChessGuy likes this.
  11. Apr 8, 2026 at 10:16 AM
    Ive had my RCI for about a year. Love it. Plus one of my recent gripes has been about the quality of the paint coating on rock sliders etc. My 4R is at the dealership now getting a new diff seal. I dropped the skid plate myself and whatever coating RCI uses is SUPERB. The diff leaked onto the skid plate so there was a lot of oil on the underside. Hit it with engine cleaner and high pressure water and noticed how good the coating is. The ONLY recommendation i would tell you is to replace the allen bolts that are on the oil filter cover to just stainless bolts. I rounded out the allen head already but that was likely me just rushing. RCI is a very very solid product
    sweetsaltyair[OP] likes this.
  12. Apr 8, 2026 at 10:29 AM
    just to add to my post above, the RCI uses different mounting points than your standard TRD skid plate. I personally like that because the dealership has cross threaded the OEM skid plate before. Hence now why i do the removal and installation of it myself. The RCI also has uses six mounting points as opposed to the OEM 4. Installing it is easy as well. I jack it into place and bolt it on. Having two people though is a plus but can be done with a jack and a little patience
  13. Apr 8, 2026 at 10:35 AM
    I respect your opinion but disagree with it. I have a RC awning and that thing is so solid and built so sturdy. The price point and quality of the RC awning is pretty damn good
  14. Apr 8, 2026 at 11:15 AM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    Buy local & do a local pick. I say buy whatever is cheaper or local - always
    kmeeg likes this.
  15. Apr 8, 2026 at 6:56 PM
    din know the had awnings. I’ll be damned
    morfdq[QUOTED] likes this.
  16. Apr 8, 2026 at 7:06 PM
    L
    20 Venture/17 Taco
    Over 4 yrs running RCI
    Heavy if you go with the steel version but full protection if you go :mudding: a lot.
    TrueTexas and sweetsaltyair[OP] like this.
  17. Apr 9, 2026 at 11:10 AM
    yes, they are absolutely amazing. Very heavy fabric, all aluminum frame and it sets up and takes down in 30 seconds. Just a fantastic product.
  18. Apr 9, 2026 at 1:24 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    I have Rival Aluminum skids. Agree that their mounting hardware can be improved. I made some changes to their mounts to beef them up and allow me to jack up the vehicle from the center of the crossmember where rhe front skid and transmission skid meet.
    Very happy with them but I am not a frequent or hard-core offroader. Dirt roads, forest trails and a single trip to Moab so far.
    307WY[QUOTED] and morfdq like this.
