Front rattle from "cupping"???
Discussion in '5th Gen 4Runners (2010-2024)' started by BiggestAUfan, Jun 1, 2021.
  1. Jun 1, 2021 at 1:51 PM
    BiggestAUfan
    BiggestAUfan [OP] New Member
    2018 Super White TRD Off Road Premium XP
    Pending ;)
    So, the service tech is saying my rattle in the front, driver side isn't from the loose mud flap clips as discussed here a lot, but from my tires "cupping"?
    What the heck is this???
  2. Jun 1, 2021 at 1:56 PM
    ToyoTaco25
    ToyoTaco25 New Member
    Chris
    North Carolina
    2017 Blizzard Pearl Limited
    Your tires are wearing unevenly.
    You should be able to see this with your eyes.
    Just Google “tire cupping”???
    Mtbpsych and LandCruiser like this.
  3. Jun 1, 2021 at 6:21 PM
    Gumpus
    Gumpus New Member
    As I think you already suspect your service tech is making stuff up, probably because rattles can be hard to diagnose.
  4. Jun 1, 2021 at 7:04 PM
    kbp810
    kbp810 rebmem wen
    Tire noise can manifest itself in strange ways; I've heard cupped tires before that sounded exactly like a metallic grinding/whirring sound that had me convinced (as a passenger) they had a bad wheel bearing... but nope, a new set of tires fixed it for them.
    A rattle seems like a bit of a stretch to me though... I could see vibrations from a cupped tire causing something else that was already loose to rattle; but without hearing it myself, having a hard time imaging it being just the tire itself.
    Perhaps rotate tires and see if the sound changes or seems to come from a different location after? (assuming for only front being cupped and rears still looking good)
  5. Jun 1, 2021 at 7:26 PM
    Good idea!
    @BiggestAUfan how often do you rotate your tires?
  6. Jun 2, 2021 at 10:41 AM
    BiggestAUfan
    Pending ;)
    Tires have been R&B by Toyota every 5k and the truck has never been off road (don't judge) so there's no way anything is bent. I'm thinking about having the dealership document they think it's from the tires, that way when I get new ones (which will be after 36k miles, I can hold them accountable to the warranty repair to fix it under the "bumper to bumper warranty.
  7. Jun 2, 2021 at 10:57 AM
    It seems weird that you would have any unusual wear. Do the tires look cupped to you?
    Bumper to bumper does not include regular wear items, so tires would not be covered unfortunately.
  8. Jun 2, 2021 at 11:16 AM
    4runningMan
    4runningMan New Member
    New Mexico
    This.
    If you can see cupping on the edges of the tire, overinflate them and see if the rattle goes away. That could help pinpoint the culprit.
  9. Jun 2, 2021 at 11:42 AM
    You should have received a separate tire warranty information when you bought the truck.
  10. Jun 2, 2021 at 5:48 PM
    Bad shocks can cause cupping, along with other suspension.
  11. Jun 2, 2021 at 8:34 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    I had some destination MTs cup. It was awful.
    The back end of the lugs was 1/4” lower than the front.
    Never figured out what caused it.
  12. Jun 2, 2021 at 11:14 PM
    4runningMan
    New Mexico
    It’s kinda like chasing a snowball down hill. The bigger it gets, the faster it rolls. It could be an almost immeasurable alignment or balance issue… then once the cupping starts, it’s a runaway train that becomes un-fixable really quickly.
    LandCruiser[QUOTED] likes this.
