Front Fascia Color
Discussion in '5th Gen 4Runners (2010-2024)' started by rickystl, May 4, 2021.
  1. May 4, 2021 at 10:02 AM
    rickystl
    rickystl [OP] New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    Hi ALL
    Picking up my new 2021 TRD/ORP this coming Saturday. The color is Magnetic Grey Metallic.
    There are only 2 changes I want to make.
    1. Change tires to BF Goodrich All-Terrain TA's
    2. Possibly re-paint the front fascia (from silver) to either black or body color. Which do you think would look better ? Opinions welcome. Thanks.
    I don't think the silver looks bad. Just....well...boring. LOL
    Rick
  2. May 4, 2021 at 10:03 AM
    icyhotahs
    icyhotahs NEw mEmBER
    Samuel
    Sacramento, CA
    2022 ORP Super White
    Method 703 - Nitto G2 - C4 Ladder - UpTop Rack - EIbach 2.0 Coilovers & Load Levling Kit (250) Victory Strike Sliders - Dometic 55 - EcoFlow Delta
    There are more threads than god on this topic. Search is your best friend... you'll probably end up with pictures of both!
    7385 likes this.
  3. May 4, 2021 at 10:21 AM
    Jack Diesel
    Jack Diesel New Member
    2020 TRD OR Premium
    I had the front and rear painted professionally and it makes a world of difference.
    rickystl[OP] likes this.
  4. May 4, 2021 at 10:34 AM
    rickystl
    Rick
    St. Louis, MO
    Hmmm. I must be using the wrong words to search. Any suggestions ? Thanks.
    Rick
  5. May 4, 2021 at 10:35 AM
    rickystl
    Rick
    St. Louis, MO
    WOW !!! That does look good !! Is that body color or black ? Thanks.
    Rick
  6. May 4, 2021 at 10:37 AM
    DRH
    DRH TRD Broverlander Extraordinaire
    Dave
    Santa Clarita, Ca
    2020 ORP
    I hated the silver valance. Finally removed it and chopped out the piece behind it for a bumper. Whatever you do in the front should also be done to the back valance.
    Toy4X4 likes this.
  7. May 4, 2021 at 10:44 AM
    icyhotahs
    Samuel
    Sacramento, CA
  8. May 4, 2021 at 10:47 AM
    rickystl
    Rick
    St. Louis, MO
    Good point. Front AND Rear. Noted. Thanks.
    Rick
  9. May 4, 2021 at 11:08 AM
    This is one of the reasons I wish SR5 had some of the features the Off-Road provides, such as the manual transfer case shifter and rear locker.
  10. May 4, 2021 at 11:20 AM
    rickystl
    Rick
    St. Louis, MO
  11. May 4, 2021 at 2:14 PM
    Jack Diesel
    2020 TRD OR Premium
    Black.....the painter color matched it to the Heritage grill piece. After some wear, it looks almost identical in color. It makes a MASSIVE difference in the look, both front and back. Definitely worth the money IMO.
  12. May 5, 2021 at 6:48 AM
    rickystl
    Rick
    St. Louis, MO
    Thank you ALL for your replies. Much appreciate it. So, I guess I will either have the two pieces professionally painted, or just order the parts from a Toyota dealer for the TRD/PRO which sounds like they already come black from the Factory.
    I used the Forum's search feature as recommended above. Just the two changes I want to do, does in fact dramatically change the look of the ORP.
    Can't believe what a difference it makes.
    I'll have to check and see what the price difference would be having both valences professionally painted including off and back on labor versus purchase of the PRO replacements and the off and back on labor. Might be a wash (?)
    But thanks again guys. This Forum is so helpful.
    Rick
  13. May 5, 2021 at 6:52 AM
    Alloutdrs1
    Alloutdrs1 New Member
    PXL_20210425_224829337.jpg It makes a huge difference in the appearance, I just did this on my 21' ORP. For me it was cheaper to order and install the pro pieces vs having the factory ones painted or wrapped. Plus I was able to get both installed on about an hour and a half so down time was minimal.
    hallkb and Slopemaster like this.
  14. May 5, 2021 at 7:42 AM
    rickystl
    Rick
    St. Louis, MO
    Thanks Allout for your response and photo. Sure does make a big difference. Yea, with that little downtime, I'll just buy the PRO replacements and do the labor myself. Can't be that difficult.
    When you installed yours, did you order any extra clips, or other hardware to install the new ones ?
    Rick
  15. May 5, 2021 at 8:03 AM
    Alloutdrs1
    No extra clips needed, everything is so new they came off without any breaking like they usually do when they are a couple years old. I also did mine without removing the bumpers, the rear was tricker then the front but I got it done.
  16. May 5, 2021 at 8:06 AM
    rickystl
    Rick
    St. Louis, MO
    OK. Thanks. Good to know. I plan on doing mine right away.
    Rick
  17. May 5, 2021 at 8:34 AM
    Jack Diesel
    2020 TRD OR Premium
    Please confirm for the original poster that the pieces you ordered came in BLACK. I ordered both valences from my local dealer and the parts showed up silver. I was told that they would be black from the factory, but when they arrived the service advisor changed and said they all come in silver. That is why I went to a paint shop!
    If yours came in black, maybe post the actual part numbers so OP has full information.
  18. May 5, 2021 at 12:21 PM
    Alloutdrs1
    Part #'s I ordered
    53901-35250 & 52169-35120. A member in the forum helped me out with this and steered me towards lagrange toyota for ordering.
    hallkb likes this.
  19. May 5, 2021 at 1:53 PM
    DallasTRDPro
    DallasTRDPro New Member
    Dallas
    2021 Honda CRV...UGH!
    Which bumper is that??
  20. May 5, 2021 at 2:32 PM
    DRH
    Dave
    Santa Clarita, Ca
    2020 ORP
    Southern Style Offroad slimline hybrid bumper with Smitty 10k and 30" Heise light bar.
  21. May 8, 2021 at 7:39 AM
    Metalsaber
    Metalsaber New Member
    I did PlastiDip on my front Valence. Simple and cheap.
    hallkb likes this.
  22. May 8, 2021 at 9:31 AM
    rickystl
    Rick
    St. Louis, MO
    WOW!! Thanks Alloutdoors1 for the info. Much appreciated.
    I just posted my new ORP here on the Forum. For me, the silver valences look OK. But the black just looks better. Thanks again.
    Rick
  23. May 8, 2021 at 10:20 AM
    I'm curious as to how you did the rear without removing the bumper...I thought that was necessary.
  24. May 8, 2021 at 10:47 AM
    Alloutdrs1
    That's what I read to but don't like removing plastic panels like bumpers of I don't have to as they have a chance to not go back together exactly like they were. What I did was open the hatch and I removed all the bolts at the bumper lip, then there are two clips towards the middle I removed and then I removed the ones behind the rear mud flaps. That gave me enough wiggle room in the bumper to get my hand in there too remove the clips. I had my wife hold up the new valance so I could see the approximate location of the clips. The two closest to the hitch were the toughest.
  25. Jun 20, 2021 at 4:07 PM
    hallkb
    hallkb New Member
    Massachusetts
    2017 SR5 / 2021 SR5-P
    wish they came in a non-gloss black. Still good to know it’s an option. I’m changing mine as well.
  26. Jun 20, 2021 at 5:35 PM
    travelinscout
    travelinscout New Member
    2020 TRD ORP MGM
    I used Plasti Dip on mine. After 15 months being sandblasted on Arizona roads, it still looks pretty good. Pro Grill 4.16.21.jpg
    hallkb likes this.
