Front end lift problems
Discussion in '3rd Gen 4Runners (1996-2002)' started by Lilmish, Jan 11, 2020.
  1. Jan 11, 2020 at 9:59 PM
    Lilmish
    Lilmish [OP] New Member
    Zack
    1997 4runner Limited
    I had the dreaded LBJ failure on my 97 limited, so just decided to upgrade the suspension while fixing it. I put OME 890s on the rear and OME 2881s up front, with pro comp shocks (I know not the best option, but it fit my budget),after install the front was a sitting noticeably lower than the rear, so I added a 1.5'' spacer. Now it hits the spring where the upper ball joint connects to the spindle and doesn't allow any steering. I know the alignment is totally out of whack, I replaced both lower control arms, but that shouldn't make this big of a problem right? 20200111_213330.jpg
  2. Jan 11, 2020 at 10:17 PM
    Is the upper ball joint separated or can they actually angle that far?
  3. Jan 11, 2020 at 10:35 PM
    Lilmish
    Zack
    It's still attached, probably wouldn't be for much longer if I were to drive it as is
  4. Jan 11, 2020 at 11:50 PM
    Dark Knight
    Dark Knight Get off my lawn
    If the spacer on top of the strut assembly that was added later measures an actual 1.5” in height, that would mean you put a lift on a lift.
    Because it’s roughly a 2:1 ratio in geometry, a 1.5” spacer is a 3” lift. Seems you may have stacked lifts and are now overextending you’re suspension.
  5. Jan 12, 2020 at 12:34 AM
    Lilmish
    Zack
    The spacer itself isn't 1.5'', it was 3/4'' equaling a 1.5'' additional. The initial lift was roughly 1.5'' lower than the rear. The 881s said they were good for 1.5-2.5'' of lift, so I thought I was on the low end and a small spacer would level it out. It looks perfect right now, front and rear looking equally lifted, I love it, but obviously can't drive it.
    Dark Knight[QUOTED] likes this.
  6. Jan 12, 2020 at 1:15 AM
    So new UCA’s?
  7. Jan 29, 2020 at 8:37 AM
    jross20
    jross20 New Member
    I would take out the spacers, but that is just me. 1.5" on a spacer seems excessive.
    :bucket:
    Shit I read that wrong. I would still remove the spacer for now.
