Front end hum after needle bearing replacement
Discussion in '5th Gen 4Runners (2010-2024)' started by Orion099, Jul 22, 2023.
  1. Jul 22, 2023 at 10:55 AM
    Orion099
    Orion099 [OP] New Member
    2020 TRD off road
    Hello all,
    Another front end hum post.
    2020 5th gen 4Runner with KDSS. 2 inch lift with bigger UCA’s. 285’s. KDSS drop from dr KDSS.
    Last winter I experienced the usual front end hum at about 35-40 MPH. Went away when 4wd engaged. Dealership diagnosed as needle bearing. They.. allegedly replaced with the clamshell bearing.
    Well. The hum is back. Exact same symptoms. My understanding is that this is simply not supposed to happen or be really possible with the needle bearing replaced with the clamshell.
    Anything I can check before taking it back to the dealership?
    Thanks in advance!
  2. Jul 22, 2023 at 11:06 AM
    MAXIM
    MAXIM New Member
    Toyota Dealer should not installed non OEM part. Did they warranty the work? Seems unlikely. Those sleeves don't just lay around at NAPA. Did Toyota order ECGS part online and then installed it? So many red flags. Some one is Full of it...
  3. Jul 22, 2023 at 11:41 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    I wouldn't be surprised if they installed another needle bearing instead of the ECGS part.
  4. Jul 22, 2023 at 12:14 PM
    Orion099
    2020 TRD off road
    Toyota ordered the ECGS part online and installed it. At least per their invoice. But my understanding is that with the Clamshell bearing this physically can’t happen because there are no teeth on that to make the hum sound.
  5. Jul 22, 2023 at 2:37 PM
    Matt83
    Matt83 New Member
    Northeast
    Interesting they installed the ECGS part. That are not swapping needle bearings anymore, changing out entire diffs instead.
    Toy4X4 likes this.
  6. Jul 22, 2023 at 2:45 PM
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    Side note (sorry for pedantry). ECGS part is a bushing (or "plain bearing"). A shell bearing is a two piece thin bearing such as used in connecting rod big ends.
    Really surprised a dealer would install an aftermarket fix such as the ECGS kit. Could be a red flag. Could be a cool/practical dealership. Given the noise has returned, going more towards the former.
    BTW, I did the bushing retrofit on mine and am a fan of the kit ECGS offers.
    Jason
    Toy4X4 likes this.
  7. Jul 23, 2023 at 4:31 AM
    rmiked
    rmiked New Member
    Fort Mill, SC
    I would have a hard time believing a Toyota dealer would install a non-Toyota part also. If they documented that on the repair order you have to believe them because if something else goes wrong it raises warranty liability questions? Unless their position is since the vehicle is lifted and other non-factory parts, it is NOT warranty work anyway? Did the OP ever say it was warranty work? This is very interesting. I would really like to know if Toyota has approved aftermarket parts for warranty work. If so, it’s an admission of a design flaw.
    Toy4X4 likes this.
  8. Jul 23, 2023 at 7:53 AM
    FWIW, When I was a dealership tech for over 15 years, We never installed any type of non factory parts on any of our vehicles.
    Unless a tech was doing some side work after hours, I too do not see a Toyota dealership doing this and at the same time offering the factory warranty to cover future issues.
    Rocko9999 and Toy4X4 like this.
  9. Jul 23, 2023 at 4:18 PM
    Hans Moleman
    Hans Moleman New Member
    SF Bay
    Toyota dealers install aftermarket lifts all the time on new 4Runners, tacomas and tundras then offer them for sale.
    For the OP, was this a warranty repair or did you pay to have the ECGS bushing installed? I don’t believe Toyota would approve the dealer to do this for a warranty repair. However dealers would install anything if customers pay them.
    kolter45 likes this.
  10. Jul 23, 2023 at 4:25 PM
    rmiked
    rmiked New Member
    Fort Mill, SC
    When the dealers install aftermarket lifts and then sell the new vehicles, do they still have the factory warranty? Will it be honored by Toyota and any dealer?
  11. Jul 23, 2023 at 5:01 PM
    Regional mileage may vary, Was simply offering actual regional offerings available at the time.
  12. Jul 24, 2023 at 6:49 PM
    Orion099
    2020 TRD off road
    Sorry for the delay.
    The humming that disappears when 4wd is engaged seemed to smooth itself out when driving 65+ (in 2wd)
    for a long period of time on the highway. Its still there at lower 40mph speeds, but its not as pronounced/loud as before.
    I pulled the invoice from the repair that Toyota did. At the time the Rep said that they knew about the needle bearing issue and they replaced it with a... Their words not mine... Clamshell Bushing. The rep said that when vehicles come in with these specific symptoms they are just replacing the needle bearing with a bushing. The rep claimed that if the vehicle was still under warranty they would have repaired it under warranty with a bushing. They did not specify if it was from ECGS or not. On the repair invoice it simply says "bushing" with no associated part number which is a little maddening.
    This specifically was NOT a warranty repair as it was out of the warranty period for that vehicle. So the repair came out of pocket.
    In my limited experience I've seen dealerships install non OEM parts all the time on vehicles, but yeah, maybe not for warranty work. The only real remaining question is if the bushing installed is an OEM part made by toyota or not.
    Regardless when I have a moment this week i'll have Toyota look at it since they did the work on it. Figured I would update with what in formation I had.
    java likes this.
  13. Jul 24, 2023 at 6:56 PM
    I think it is the tires now. I would try to rebalance at Discount Tire with their Road Force machine and try to get to see what numbers they get. I had similar experience and had to try a couple of different tire places until got the right spot and the right techs. Just my two cents. Don't give up.
  14. Jul 24, 2023 at 7:03 PM
    Orion099
    2020 TRD off road
    I'm pretty sure its not the tires as the noise totally disappears when 4wd is engaged when coasting in neutral at 40mph. This is just a puzzle i've been obsessing over. Discount tires installed the tires, but they have only been rotated, not rebalanced since they were installed.
    To be clear. Loud humm from front end roughly driver side when in 2wd. 4wd hum goes away. When shifting back to 2wd it immediately comes back. A few months back Toyota replaced Needle Bearing with a "bushing." Noise continues with the same symptoms as before, except only after driving long distances on the highway the hum in 2wd seems to dissipate to a tolerable level. After 4wd is re-engaged for dirt road shenanigan's or what not it returns when shifting back to 2wd.
  15. Jul 24, 2023 at 8:16 PM
    My dealership will install non OEM parts to include the bushing. Had this conversation with my service advisor regarding the bearing hum.
    kolter45 and Toy4X4 like this.
  16. Jul 28, 2023 at 3:12 PM
    MAXIM
    MAXIM New Member
    They won't guarantee pars or work.
  17. Dec 17, 2023 at 4:34 PM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Op how is the humming symptom now?
  18. Jan 20, 2025 at 1:11 PM
    King110793
    King110793 New Member
    Victor
    2017 4Runner TRD ORP
    Ironman lift kit, 33s, KDSS, gobi rack,
    Any updates on your rig ? Getting the same symptoms even after installing ECGS bushing. Symptoms go away engaging 4x4 4H.
  19. Jan 20, 2025 at 4:38 PM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    Did they use or buy the gasket with it? You’re supposed to buy the clamshell & the gasket from ECGS
    Toy4X4 likes this.
  20. Jan 20, 2025 at 5:57 PM
    Yobruhitsme
    Denver
    Ineos Grenadier
    wtf is a “clamshell” ? Clamshell is the whole front diff itself.
    Toy4X4 likes this.
  21. Jan 20, 2025 at 6:08 PM
    kolter45
    Denver
  22. Jan 20, 2025 at 6:21 PM
    Yobruhitsme
    Denver
    Ineos Grenadier
  23. Jan 20, 2025 at 6:35 PM
    kolter45
    Denver
    I’ll be sure to type it out all the way next time. Thanks for the info
  24. Jan 20, 2025 at 6:40 PM
    Yobruhitsme
    Denver
    Ineos Grenadier
    “Did you buy the clamshell” can simply be “did you buy the bushing” clamshell is an adjective describing the front diff design that has been in 30 years of Toyota trucks. Bushing is a noun. It’s the part than ecgs sells
    clamshell conveys the wrong concept. “Did you buy the clamshell” asks whether he bought the front differential
  25. Jan 20, 2025 at 9:58 PM
    King110793
    Victor
    The shop used the regular ECGS bushing from the website. They mention my needle bearing was cooked. FYI I started to get all my symptoms after I had my car serviced at my local Toyota. Had a diff fluid change front and rear and also did a transfer case oil change. Toyota said the symptoms aren't related to the service, I think it’s bullshit cause my rig was running great with no issues before I brought it to Toyota. 75w90 front 80w90 rear 75w90 T-case
    Toy4X4 likes this.
  26. Jan 21, 2025 at 3:46 AM
    I don't recall a "gasket" when we replaced the needle bearing with the ECGS bushing. There was a 'seal' where the axle shaft went into the diff. housing though, is that what you mean?
  27. Jan 21, 2025 at 9:21 PM
    Yes. Clamshell & gasket translates to bushing and seal.
    kolter45 and Toy4X4[QUOTED] like this.
