Front Caliper Piston Seized
Discussion in '5th Gen 4Runners (2010-2024)' started by TheSponge, Apr 6, 2024.
  1. Apr 6, 2024 at 11:08 AM
    TheSponge
    TheSponge [OP] New Member
    So in the process of changing my front brakes due to pulsing and the previous owner obviously never servicing them I came to realize one of the pistons is seized on the driver side front.
    Called parts stores they ask me if it’s 12mm or 14mm mounting hole. Any idea what they are talking about here? VIN was of no use to them. This is a 2016 4Runner limited.
    What I am thinking of doing, order a caliper from Amazon $100 and rebuilt the one that’s on the 4Runner since it’s OEM. Local guys are selling $250+ including my core unit for god knows what brand...
    Thoughts on this and specifically the 12mm vs 14mm mounting ordeal? Also, are rebuilt kits for these readily available? In Canada if it matters.
  2. Apr 6, 2024 at 11:26 AM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    I’d go with a new OE, you should be able to find one for about $200
    raimieb likes this.
  3. Apr 6, 2024 at 11:49 AM
    TheSponge
    Well certainly not here around me in the land of Canada.
  4. Apr 6, 2024 at 2:14 PM
    TheSponge
    So based on my research - I should have the 14mm calipers, but oddly enough that corresponds to a 21mm hex head - however to remove my calipers my bolts utilized a 19mm hex head… every I read it says they switched from 12mm at 2015.. my 4Runner is a 2016 so it’s supposed to have the 14mm caliper, I guess?
    So now I’m confused what’s actually going on.
  5. Apr 6, 2024 at 2:19 PM
    just my $.02, buy OEM. I made the mistake of getting an autozone caliper for my 2011 and it crapped out 6 mos later. Replaced it with same version and it lasted 1 yr. Save yourself the headaches and go OEM
  6. Apr 6, 2024 at 2:21 PM
    TheSponge
    Is there a website that I can find part #s for these vehicles? I go to http://japan-parts.eu/toyota/us/# but can go over the model year 2014..
  7. Apr 6, 2024 at 2:35 PM
    have you tried BAM wholesale?
    raimieb likes this.
  8. Apr 6, 2024 at 2:36 PM
    TheSponge
  9. Apr 6, 2024 at 2:37 PM
    Its not copying right for some reason
  10. Apr 6, 2024 at 2:38 PM
  11. Apr 6, 2024 at 2:59 PM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    Are you trying to buy a brand new caliper? Or a rebuilt with a core charge? I've gone the rebuilt route a couple times before with my old BJ74 Land Cruiser and also my parents FJ Cruiser. Both times they were genuine Toyota calipers that had been rebuilt.
  12. Apr 6, 2024 at 3:05 PM
    WanderlostOverland
    WanderlostOverland New Member
    It's the size of the mounting bolts. Ask your local parts store to bring one of each into their store and compare to yours. Is the stuck one an OEM part? Even the ones from Toyota have the problem of freezing up. We've gone through plenty before we decided they aren't worth the inflated cost.
  13. Apr 6, 2024 at 3:19 PM
    TheSponge
    Yes it’s a OEM caliper, only one of the 4 pistons is seized. The local calipers are all $250+ (including my core) so even more if I keep my caliper. and they’re not remans - so Chinese premium.
    my train if thought is get the Amazon unit, $100, buy a rebuild kit $20. Refurb my OEM unit and then swap it back. This way it cost me $120 and I have a OEM unit back on the rig?
    I’m just not sure what rebuilt kit to get and where I can find a new piston?
  14. Apr 6, 2024 at 3:24 PM
    TN_FunRunner
    TN_FunRunner Custom Title
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    Had this issue on my 4th gen a few years back. I put a rebuilt one on from AZ and it’s been good ever since.
  15. Apr 6, 2024 at 3:43 PM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    If you're going to rebuild your OE caliper, at least get OE Toyota parts to rebuild it with. The cheap rebuild kits are an invitation for another rebuild in pretty short order.
    raimieb and TrailSpecial22 like this.
  16. Apr 6, 2024 at 3:57 PM
    TheSponge
    I would if I could find a website that actually shows OEM part numbers. See my issue a few posts up, the website I have only goes to 2014 year model - and it seems the caliper actually changed in 2015 so would be good to see what the part # should be for the OEM kit for my year machine.
  17. Apr 6, 2024 at 4:08 PM
    qcTRDct
    qcTRDct New Member
    2022 ORP KDSS
  18. Apr 6, 2024 at 4:15 PM
    qcTRDct
    qcTRDct New Member
    2022 ORP KDSS
    It's going to depend on your manufacture date, a you can see. But good prices here, I've used them for a long time.
    Screenshot_20240406-191132.png Screenshot_20240406-191045~2.png Screenshot_20240406-191109~2.png Screenshot_20240406-191057~2.png
    TheSponge[OP] and TrailSpecial22 like this.
  19. Apr 6, 2024 at 4:32 PM
    TheSponge
    Much appreciate the link! Looks like based on my VIN front left caliper is 4775060350
    Which comes back at $300 Canadian.
    it’s funny even that caliper bolt listed there shows that it’s for productions up to 2015 for a M12 head, lol. Only thing I can think of is that my body diameter is 14mm but the head is smaller - not even sure if this is possible?
  20. Apr 6, 2024 at 5:00 PM
    qcTRDct
    qcTRDct New Member
    2022 ORP KDSS
    Who knows, maybe the last guy that did the brakes used some aftermarket bolt
  21. Apr 6, 2024 at 5:03 PM
    qcTRDct
    qcTRDct New Member
    2022 ORP KDSS
    If you are dead set on using aftermarket, check rockauto.com. usually you can find a 5% off coupon out there too, which isn't much, but it's something. I am not sure if they operate in Canada. I have used the Power stop brakes in my FJ Cruiser and was very happy, if you are looking for an aftermarket option. But there are a million out there. The nice thing n Rock Auto is they break up the results into the "good" "better" "best" type system, so you can see all your options from your specific application
  22. Apr 6, 2024 at 5:10 PM
    2016 mid-year is when Toyota switched.
    17mm head -> M12. 19mm head -> M14.
    The other M14 bolts on your truck (like UCA pivot and lower shock bolt) have 19mm heads. Easy enough to verify. You can also easily drill out the holes on a 2010-2015 caliper from 12mm to 14mm. Commonly available 9/16" drill bit would work. Castings are the same, just the holes are drilled to different sizes at the factory.
    I'm running Powerstop and Raybestos calipers on my 4Runner and Tacoma. They've been good. Get this and call it a day:
    https://www.rockauto.com/en/moreinfo.php?pk=13342177&cc=3437058&pt=1704
    Rock Auto ships to Canada and collects HST. No surprises with customs and brokerage.
  23. Apr 6, 2024 at 5:22 PM
    TheSponge
    It’s not a 17mm head for sure. It was a 19mm hex socket that was used to remove the bolts, which corresponds to a M12.
  24. Apr 6, 2024 at 5:24 PM
    ^Toyota bolts don't follow ISO sizing. M14 Toyota bolts have 19mm heads.
    jgalt and TheSponge[QUOTED][OP] like this.
  25. Apr 6, 2024 at 5:24 PM
    TheSponge
    Really?? And here I am chasing a goose. Well that’s good to know! This sorts everything then ‍♂️
  26. Apr 6, 2024 at 5:26 PM
    ^Make sure you have the appropriate tools to loosen an M14 bolt with loctite (propane torch, impact wrench with at least 1000 ft-lb...)
  27. Apr 6, 2024 at 5:38 PM
    aroyalsfan
    aroyalsfan The Owner
    Kansas City
    I just did my brakes and rotors this week. I too have the 19mm bolts, but I believe they used to be 17mm not 12mm. The 12mm could be referring to the bracket above the calipers that you need to remove so they can be moved around. That 12mm bolt can also be used to break the rotors free from the hub via the holes in the rotor.
  28. Apr 6, 2024 at 5:40 PM
    TheSponge
    Oh they were broken loose man. I stick to eggs and oats in the morning :)
    think their ft-lbs is 137ft-lbs
  29. Apr 6, 2024 at 5:43 PM
    aroyalsfan
    Kansas City
    Those bolts sucked. I bought a 3/4" steel pipe and put it over my breaker bar to get the added leverage.
  30. Apr 6, 2024 at 5:46 PM
    ^Yes because they were installed with loctite at the factory, so it takes a lot more than 137 ft-lbs to break them loose.
    jgalt likes this.
