Front Brake Kit .
Discussion in '5th Gen 4Runners (2010-2024)' started by Sybo, Jul 25, 2023.
  1. Jul 25, 2023 at 12:58 PM
    Sybo
    Sybo [OP] New Member
    Getting ready to do a front brake job on my 2018 4R SR5 Premium. It has 117,000 miles . Planning on replacing pads and rotors . I was considering Pro STOP Extreme brake kit with drilled and slotted rotors . My concern is a few reviews I read state that they had warping issues rather early after install . I do occasional light towing , a 5x8 utility trailer and no off-roading. Any advice . Thanks in advance .
  2. Jul 25, 2023 at 1:02 PM
    Henry J
    Sacramento Ca
    I just went to a Powerstop z36, no long term review yet but significant difference. I’ve seen a few go to the PowerBrake front kit and they really like ‘em but that’s a lot of cabbage right there!
  3. Jul 25, 2023 at 1:09 PM
    steelevo
    Utah
    Go with OEM rotors and pads.
    POWERPLANTHOMER and HotelMedicis like this.
  4. Jul 25, 2023 at 1:14 PM
    OEM and bed them in properly. Drilled is no good anywhere and slotted makes minimal difference if any at all.
    HotelMedicis and RumHamRunner73 like this.
  5. Jul 25, 2023 at 1:24 PM
    Sybo
    Going with original sounds like good advice . I'll wait to see if there are more opinions out there before I decide but that is probably the route I'll take .
  6. Jul 25, 2023 at 1:27 PM
    2016Pro
    Oem the rest is just wasted money, like buying a CAI
    CygnusX-4 likes this.
  7. Jul 25, 2023 at 1:57 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Akebono pads.
  8. Jul 25, 2023 at 2:00 PM
    CygnusX-4
    CygnusX-4 Member
    21 TRD OR
    Whatever you choose, clean the rust off of the hub if there is any.
    Rocko9999 likes this.
  9. Jul 25, 2023 at 2:12 PM
    Rocko9999
    2011 Limited
    Wire brush off, little anti-seize.
    Trail Runnah likes this.
  10. Jul 25, 2023 at 2:14 PM
    Matt83
    Matt83 New Member
    Northeast
    Another for genuine Toyota brakes.
  11. Jul 25, 2023 at 2:22 PM
    CygnusX-4
    CygnusX-4 Member
    21 TRD OR
    I use a wire brush after a die grinder with 3" cookie..:cheers:
    I hate anti-seize, BTW. If I use it, it will be copper anti-seize, but not on the hub.
  12. Jul 25, 2023 at 2:32 PM
    Since it's a pavement princess, Advics rotors and pads, a bit cheaper than the dealer. Advics is the OEM manufacturer (you see the name molded on your ABS unit).
    For off-road use, StopTech or Raybestos slotted rotors are better for water evacuation.
  13. Jul 26, 2023 at 8:43 AM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    Put Power Stop rotors and pads on my 1990 4R and my diesel 10 years ago and I am very satisfied with them.
    Both my sons own Cummins and both have said my truck’s brakes are much better than theirs.
    Being retired with three vehicles means none of them get a lot of miles now though so “your mileage may vary.”
    Henry J likes this.
  14. Jul 26, 2023 at 11:49 AM
    TRDSD
    2019 TRD Off Road Premium
    Stay away from cross-drilled rotors. Slotted or OEM style only. Drilling + slotted is too much for these trucks. It's not a lightweight, racing setup. Too much weight and heat for that type of rotor - especially with your use case. You're just asking for problems.
