Front ABS connector plastic broken - Replacing just the connector and not the entire harness?
Discussion in '5th Gen 4Runners (2010-2024)' started by Squalidskidmark, Jan 9, 2026.
  1. Jan 9, 2026 at 9:59 AM
    Squalidskidmark
    Squalidskidmark [OP] New Member
    Hey guys,
    I think I've had to pull this clip off one too many times and I managed to break the plastic clip.
    All i'm seeing for replacements is the entire wiring harness for way too much money. As it's basically a deutsch connector, which I have tools for, I'm thinking I should be able to replace just the clip without purchasing and re-routing the entire harness. Does anyone know what the clip might be called, where to purchase one, and/or part number? I'm betting toyota doesn't sell just the clip but I'm thinking it likely isn't proprietary and/or an aftermarket option exists.
    Any help would be greatly appreciated!
  2. Jan 9, 2026 at 1:23 PM
    Grug556
    Grug556 New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    take a closeup pic of the connector and post on chat gpt and have the beast find it for you...for free. Tell GPT where it came from to help source it. Should be no problem. I used it the other day for connectors for another part and gave me many sources.
  3. Jan 9, 2026 at 3:47 PM
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    Check on Rock Auto. I've bought lots of connectors and, on occasion, just de-pinned and used what I needed.
  4. Jan 10, 2026 at 12:01 AM
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    There's a separate skid wire to each wheel for about $60-70 on Ebay or $58 from TPD.com. They are color coded for left and right. Those wires break easily for me being careful. Before removing old harness, start at the top and install new one as you remove the old one so it isn't stretched or tugged on and routed correctly. If you need an ABS wheel speed sensor, I recommend a Toyota OEM. I have used $40 aftermarket ABS sensors on my AWD Limited and it doesn't work as well on that wheel that was replaced. Probably why the Toyota is $230 each. The Limited AWD is pretty advanced and impressive to anything I have driven, and reliable. It's been the most expensive model or a GX is the next step. Everything that is or might be replaced on these 4runners seems to be under $200.
  5. Jan 10, 2026 at 1:14 PM
    ABS wire damage is common when going off-road, seen it twice in my club, so I bought this as a trail spare: https://www.rockauto.com/en/moreinfo.php?pk=16316609&cc=1431544&pt=762&jsn=1
    Since only the connector is broken on yours, you can de-pin the broken connector, de-pin the SMP connector, and swap over the connector. Alternatively cut the wire and use the crimp & seal butt connectors included in the kit.
