Frequent dead car (sporadic)
Discussion in '5th Gen 4Runners (2010-2024)' started by 4Runner115, Sep 12, 2023.
  1. Sep 12, 2023 at 6:07 AM
    4Runner115
    4Runner115 [OP] New Member
    2012 4RUNNER SR5
    I own a 2012 SR5 with 70,000 miles. If the car sits for a week at a time it will not start. I replaced the battery a few months ago (because the car was dying ). It ran good until I was away for 2 weeks, now the car wont start without a jump( and dies after ignition off). I was told there is no draw, starter or alternator issues by Toyota last time this occurred. Not sure what to do.
  2. Sep 12, 2023 at 6:18 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    You have some sort of parasitic draw. Have you installed anything that draws power when when off?
    Also: sporadic
    4Runner115[OP] likes this.
  3. Sep 12, 2023 at 7:01 AM
    If no parasitic draw or alternator problems were found by the dealer, then start looking at any aftermarket mods that tap into the electrical. Do you have a remote start system?
  4. Sep 12, 2023 at 7:49 AM
    4Runner115
    2012 4RUNNER SR5
    All mods:
    grille with raptor lights
    Usb port
    ICS rack with usb ports
    Baja design ditch lights
    Is there a way to test mods to find the culprit?
  5. Sep 12, 2023 at 8:30 AM
    joshdub
    joshdub New Member
    2020 TRD ORP
    Unplugging them is a sure fire way
    MeefZah likes this.
  6. Sep 12, 2023 at 9:00 AM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    Clamp on amp meter on the battery cable to verify a drain then move on to test the individual mods.
  7. Sep 12, 2023 at 5:42 PM
    I’d only suggest doing that if the OP knows his way around a multimeter. It’s possible to screw the pooch much worse than it is now if you make a mistake, especially measuring draw. Don’t ask me though, i only know enough to be dangerous.
    steelevo likes this.
  8. Sep 12, 2023 at 6:21 PM
    How do you mess up using a clamp on meter?
    He doesn't have to unplug anything. But if you get a regular MM you do.
