Fog lights question
Discussion in '5th Gen 4Runners (2010-2024)' started by Lucky9924, Nov 29, 2024.
  1. Nov 29, 2024 at 5:54 AM
    Lucky9924
    Lucky9924 [OP] New Member
    1999 and 2024 TRD ORP
    For a 2024 TRD ORP:
    Is there a way to put the fog lights on its own switch? I want it to turn off/on independent of the headlights.
    Goal is to only have the headlights on by themselves (without the fog lights) when it’s dark and dry (not raining). Then I’d like the option to switch on the fog lights ONLY when it’s foggy/raining in addition to the headlights.
    Would something like the “Brite Box Anytime” do this? I emailed the company but haven’t heard back from them.
    edited to clarify: I’m installing amber SS3 fog lights. I want it to only turn it on when it’s foggy/raining. I don’t want it to automatically turn on when I turn on the headlights.
  2. Nov 29, 2024 at 6:13 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Brite Box will do what you are trying to do. I'm going to get one soon. Some days it would be nice to run fogs only.
    Stoney Ranger and Lucky9924[OP] like this.
  3. Nov 29, 2024 at 6:52 AM
    Lucky9924
    I will look again. Thanks.
  4. Nov 29, 2024 at 7:01 AM
    I don't get it...my fog lights don't come on automatically when the headlights are turned on, I have to turn them on with the stalk switch. Is that different for the 2024 models? I also have SS3 fog lights...
    catbrown357 likes this.
  5. Nov 29, 2024 at 7:14 AM
    Guppy1301
    Silver 2019 TRD ORP
    This is what you are after. Brite box anytime. Option 2.
    2021-2024 Toyota 4Runner
    On the 2021-2024 Toyota 4Runner the low beams will stay on but the fog lights will automatically shut off on high beams. Choose from 2 different options to control your lights the way you want. See options below.
    Option 1: The Brite Box Fogster - will automatically turn fog lights on when the high beams are activated
    The Brite Box Fogster model is FULLY AUTOMATIC with no additional switches or controls to operate, but by using your existing factory high beam switch to activate the effect.
    Option 2: The Brite Box Anytime - gives you full control of your fog lights. This kit will allow you to turn your fog lights on in any light setting such as no headlights, with daytime running lights, and with high beams.
    The Brite Box Anytime REQUIRES A SWITCH to turn your fog lights on at any time. When purchasing The Brite Box Anytime, it will include a Universal Switch (with a Blue LED). Upgrade to an OEM Style Push Switch here or a switch panel to control your lighting here
    For general product questions or wiring The Brite Box Anytime with an 8 switch control panel or other similar systems please contact the manufacturer (Aspire Auto Accessories).
  6. Nov 29, 2024 at 9:48 AM
    Lucky9924
    I read the manual again and figured it out. There’s an inner dial on the stalk switch that controls it. I read the manual when I first got the 4R, lots of info but not everything stuck.
    Bagman likes this.
  7. Nov 29, 2024 at 9:50 AM
    If you have the fog light stalk switch, maybe it's set to on. That means they would come on when you turn on the headlights. If you turn that switch to off, they won't.
    Bagman and Lucky9924[QUOTED][OP] like this.
  8. Nov 29, 2024 at 9:51 AM
    You got it.
  9. Nov 29, 2024 at 12:28 PM
    You can easily use a H11 wiring kit to have your fog lights turn on and off independently.
    This kit comes included switch-
    https://amzn.to/3CNwhqj
    Or if you want oem style dash switch you can buy separately as well.
    https://amzn.to/4eSA6rm
    I personally use this dual switch so I save space on my dash having 2 in one slot-
    https://amzn.to/4fNkLJT
  10. Nov 29, 2024 at 1:19 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    I went the easiest route with my PIAA 520 Yellow fogs mounted behind the lower grill.
    Just an independent separate switch and relay.
  11. Nov 29, 2024 at 2:10 PM
    SOSHeloPilot
    SOSHeloPilot New Member
    SouthEast USA & S.E. Asia
    2024 4Runner SR5
    Owned Many Toyotas - Past
  12. Nov 29, 2024 at 2:31 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Great ideas here.
    When modifying electrical there are basic " Must Dos".
    Fuse all new wires. Use relays for all powerful draw items-fog lights qualify.
    If new switches desired -decide: "always on" or "on when ACC on" or "Engine on".
    Protect wires & connections with shrink tube wrap, tape wrap, wire loom tube covering etc.
    If in doubt post your intended wiring idea or sketch to get valuable feedback.
    Wiring fires can be expensive.
  13. Nov 29, 2024 at 2:38 PM
    salvojimmy
    salvojimmy New Member
    Glen Allen VA
    2022 SR5P
    No Mods Yet
    Some states, VA for example, require low beams on if fogs are on. Dumb but required. So if on a switch need to make sure the set up will pass the state annual inspection.
    Jere39 likes this.
  14. Nov 29, 2024 at 4:21 PM
    I did exactly what you’re describing. Ran it to a Auxbeam Switch. It’s a good option especially if you’re going to add a light bar or ditch lights. I put in the Diode Dynamics extreme fog lights and love that we can just turn those on.
  15. Nov 29, 2024 at 4:40 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Dang someone beat me to it. But here it is again. Same trim as you OP
    Is this what this auto button is I've never used? TIL
  16. Nov 29, 2024 at 5:49 PM
    DavesPRO
    DavesPRO Living in the most hated state in America.
    Dave
    2023 Pro
    That switch is for your auto dim high beams.
    Thacrow[QUOTED] likes this.
  17. Nov 29, 2024 at 8:05 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    darn
