First T4R Build, Looking for Parts and Build Advice
Discussion in '5th Gen Builds (2010-2024)' started by 4runcali4, Jan 25, 2023.
  1. Jan 25, 2023 at 6:40 PM
    4runcali4
    4runcali4 [OP] New Member
    Hi everyone,
    Very excited about my new 2023 t4r SR5 premium. I have had an idea in mind for a while now about the look I want to go for but lack experience in cars, selecting parts and what steps to take to build my 4r (so hoping I can get some help on here). The second picture is what I would ideally want my SR5 to look like. To note, I do not plan to do any off-roading with it and this is purely for the look (I know it may not be the best idea but have wanted to do this for a while). Key questions I would have based on the "ideal look" picture:
    - what lift height does this seem to be?
    - could I reach this lift with a leveling kit only? (understand this may impact driving experience)
    - what size/type of tires are these?
    - Should I have the toyota dealership install the parts?
    Any help on this is very appreciated, thanks!
    dgrenier15 likes this.
  2. Jan 25, 2023 at 8:51 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey man welcome here. That's a nice look, I had very similar questions when I started jacking up my 4R.
    That looks like he levelled it with at least a good 3" lift in the front, sometimes less in the rear.
    Def more than levelling kit, upgraded suspension in the front and coil springs in the back I'd say.
    Lastly those tires look like 33" Nitto Ridge Grapplers prolly mud terrain, 17 or 18" wheel.
    I highly recommended going that route, doing it right. Some dudes get real offset wheels and/or spacers for an aggressive stance. Good luck
    https://www.nittotire.com/light-truck-tires/ridge-grappler-light-truck-tire/
  3. Jan 26, 2023 at 5:58 AM
    4runcali4
    @djwantke thanks for the response, that's very helpful. Any recommendations on the lifting kit? Been seeing a lot of Bilstein or OME on here
  4. Jan 26, 2023 at 6:50 AM
    If money is not an issue go for the OME-BP51. This will give you the lift and the ride quality. I would concentrate more on the quality of ride you are looking for, the stance can always be tweaked. Those tires on the Pic look like 285/70/17, most of us stick to that size and seems to work well. Good luck with the build.
  5. Jan 26, 2023 at 7:03 AM
    1 old trucker
    1 old trucker New Member
    robert
    2010 trail-possible 1st in USA
    tires and wheels,updated shocks
    i bought my parts from toy-tec,i didnt want to lift kit mine,i got front leveling shocks and bilsteins for the back from a outfit called toytec out of colorado,it leveled it out nice.i also run 285 17s with no issues,i would upload a pic but dont know how.
  6. Jan 26, 2023 at 10:20 AM
    @4runcali4 you bet, I was recommended Bilstein and Old Man Emu, Bilstein can be your most affordable option for your ride and I've been happy with Bilstein. I was told upgrade to Fox or Kings suspension for higher level build quality, more advanced capabilities.
  7. Jan 30, 2023 at 6:30 PM
    4runcali4
    Great, that all makes sense - thanks all
  8. Jan 30, 2023 at 9:20 PM
    Saker New Member
    21 Black T4RORP
    Welcome 4runcali4,
    Congrats on your Black T4R !
    Ok, to start, I am on my 2nd T4R and basically built the current one, same as the first with a few more items.
    It's hard to tell how much he has lifted, but it seems to be 3/2 (front/rear).
    You could possibly get that lift with spacers. So, the front would require a 1.5" spacer and the rear a 2" spacer.
    That changes your up travel and down travel of your front A arms. You can google it on the net. That being said, that will give you the same ride just increase height, but not my choice of options.
    My choice would be Eibach, Bilstein or Fox coilovers and shocks.
    As stated, those appear to be Nitto, 275 or 285.
    Lastly, talk to the service tech (not a service writer) and tell him what you are wanting to achieve on lifting, some will treat you right, some will give you push back on installing lifts....
