First 4runner
Discussion in 'New Member Introductions' started by D solo, Jan 24, 2024.
  1. Jan 24, 2024 at 6:39 PM
    D solo
    D solo [OP] New Member
    2016 Toyota 4 runner
    I just purchased my first 4 runner ..2016 SRS premium....94,500 miles only had it for almost 2 weeks......luv it already
    ...any tips ? By the way i am new !
  2. Jan 24, 2024 at 7:13 PM
    DesertSurfer
    Tips, well the only tip I have is to buy a gen 5 4Runner before the gen 6 is released, but now that you got one that’s a moot point. Welcome to the forum from San Diego!
    2018 Limited and D solo[OP] like this.
  3. Jan 24, 2024 at 7:49 PM
    I’d change all the fluids, make sure the driveshaft is greased and engage 4WD every once in a while to exercise it (but of course not drive and steer on dry pavement)
    D solo[OP] and steelevo like this.
  4. Jan 24, 2024 at 9:14 PM
    steelevo
    Utah
    Welcome. What @icebear said is good advice. Don’t forget to check the serpentine belt, spark plugs, and air/cabin filters. You’re approaching the 100k service, so might as well get them done.
    D solo[OP] and icebear like this.
  5. Jan 25, 2024 at 12:22 AM
    D solo
    Thank you guys for your replies ....I will keep in mind....
  6. Jan 25, 2024 at 2:32 AM
    D solo[OP] likes this.
  7. Jan 25, 2024 at 3:00 AM
    Welcome from Wisconsin!
  8. Jan 25, 2024 at 3:06 AM
    welcome
  9. Jan 25, 2024 at 5:03 AM
  10. Jan 25, 2024 at 7:57 AM
    Just putting it here so folks can see, maybe someone in a decade will be helped by your question.
    In daily driving, you will almost always be in H2 (2WD). H4 (4WD) is for loose surfaces like dirt, sand, gravel, snow/ice.
    You won’t be using it often, but it’s good to exercise the mechanism so it doesn’t get stuck so I like to hit a dirt road every so often and use 4WD or at least on a straight section of road. It’s a commonly covered topic here so if that doesn’t make sense, someone else may have a better explanation.
    D solo[QUOTED][OP] likes this.
