Fire Extinguisher Installation Behind Center Console
Discussion in '5th Gen 4Runners (2010-2024)' started by Oldtoyotaguy, Oct 3, 2020.
  1. Oct 3, 2020 at 11:19 AM
    Oldtoyotaguy
    Oldtoyotaguy [OP] Paid cash for it
    2018 Toyota 4 Runner Offroad
    Not everyone perceives a need for a fire extinguisher, and although I've never personally experienced a vehicle fire, I have witnessed several and assisted in one. In the old days, with vehicles with point to point wiring they were more common. However with off road vehicles having extensive electronic mods, some better designed and executed than others, the potential is always there.
    There are a few threads on here showing other options for fire extinguisher locations, but since this one seems unique, I thought I'd post it with a new thread so it can be easily found if anyone wants to see it in the future.
    The other location options I've seen are: (1) in the jack & tool compartment (2) On the cover of the jack & tool compartment (3) in the rear passenger side cubby (4) on the retaining bar of the rear passenger side cubby (5) on a steel bracket mounted using the seat bolts to either front seat, in front. The best location, imho, is to mount a fire extinguisher within reach of the driver on a steel bracket. You don't want it to become a projectile in an accident.
    Having said all that, I mounted mine behind the centre console, by removing the rear panel and installing the bracket with 4 button head SS bolts. Although it is not mounted on steel, this location is extremely secure and won't easily become dislodged. Just be careful when removing the panel, to use a plastic body clip tool, and don't break any of the fasteners. It comes right off with patience and care.
    Once its off, and the wires disconnected you can correctly position the fire extinguisher bracket on the work bench, bolt up the bracket and then snap everything back together.
    There are a lot of options with fire extinguishers, and this location works best with 1.4 lb H3R - I chose a Halguard model because it uses a clean agent. I supplement this with a fibreglass fire blanket. It's not a lot of fire suppression. But it's for emergency response. If anyone has experienced the aftermath of a dry chemical model, they'll know it can create a lot of damage. I figure if a shot of halotron, and a blanket doesn't work, at least I've tried.
  2. Oct 3, 2020 at 11:37 AM
    Blue 4ever Runner
    Blue 4ever Runner New Member
    2019 Blue 4Runner
    I mounted mine in the passenger side cubby. Not the best location for fast access but at least it's in the vehicle. It's halogen too as I have seen the mess of a dry chemical extinguisher. I like the idea of the fire blanket and I'll pick one up next time I'm at HD or somewhere they are sold.
  3. Oct 3, 2020 at 3:15 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2019 TRD Offroad
    Is there any issue with folding the back seats down?
  4. Oct 3, 2020 at 4:36 PM
    Oldtoyotaguy
    The seat cushion on the passenger side compresses against the fire extinguisher, so they will fold but you can’t access the unit with the seats folded down. A disadvantage if you travel with the seats down or sleep in the back on a long trip. I don’t do that, so it’s not a problem for me. If it’s a matter of loading something in there for a quick trip you can also remove the extinguisher temporarily and it gives you a bit more room for the seat. Nothing is perfect!
  5. Oct 4, 2020 at 5:08 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Nice job.
    Mine's not within reach but it's present and accounted for...
    Sprouty115, Bob and Oldtoyotaguy[OP] like this.
  6. Oct 4, 2020 at 12:59 PM
    Over the LINE
    New Orleans
    2019 TRD Offroad
    That's one of the spots I looked at but ultimately put mine in the back storage area.
    Oldtoyotaguy[OP] likes this.
  7. Jun 6, 2024 at 10:05 AM
    R4Adventure
    R4Adventure New Member
    Omaha, NE
    2004 Gray 4Runner SR5 V8
    2.5" Bilstein lift, 1" body lift, 34" tires on 17x9 Method Racing 312 wheels, CBI front bumper with Warn EVO10s winch, full RCI under armor and rock sliders, ARB front and rear air lockers, 8.2" rear axle house swap, etc....
    I highly agree that not only having a fire extinguisher on board, but also having the right type(s) and having quick access as those first few seconds are the most critical. For example, a standard ABC type fire extinguisher might be good outside of your vehicle, but the powder residue is highly corrosive to wiring and will ruin your engine bay. It's best to use a Halotron based extinguisher, though they are pricey.
    When camping, I have both extinguisher types with me.
    I realize this is an older post but another option is made by the people over at Desert Does It, the makes of the seat jackers. If you already have seat jackers, you just need their under seat molle panel and extinguisher quick mount.
    Here's a pic of mine installed in my Tacoma. I am using a Halguard extinguisher. This has since been transferred to my 4Runner:
    java likes this.
  8. Jun 6, 2024 at 10:07 AM
    java
    java fauxrunner
    2023 ORP ice cap
    I too have mine mounted on desert does it.
    R4Adventure[QUOTED] likes this.
  9. Jun 6, 2024 at 10:11 AM
    I got mine in the back on the mollie panel by rago. It was rattling a little at first but I got it straight now.
    R4Adventure likes this.
  10. Jun 6, 2024 at 10:31 AM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    One thing I've always wondered, how do these do with 100+ degrees in the summer and sub-zero in the winter?
    djwantke likes this.
  11. Jun 6, 2024 at 10:32 AM
    java
    java fauxrunner
    2023 ORP ice cap
    Are element fire extinguisher sticks safe for corrosion? A video mentioned they produce Potassium Oxide and Water Vapor, sounds very caustic to me. What about sodium bicarbonate based ones?
  12. Jun 6, 2024 at 11:56 AM
    Mine fits in the driver's door cubby. Having secondaries stashed away is ok, but I want my primary as easy to access as possible.
  13. Jun 6, 2024 at 12:04 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Compact 2lb’er fit well here, screwed into the floor plastic. (I think some folks said that two or 2 1/2 pound extinguisher is not even sufficient for vehicle fires but fck ‘em, lol. Better than nothing, maybe?)
    Trail Runnah likes this.
  14. Jun 6, 2024 at 12:45 PM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    Mine's between the drivers door and the seat.
    A good yank on the velcro strap and I'm in business.
    Trail Runnah and djwantke like this.
  15. Jun 6, 2024 at 1:05 PM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    I want to know too.
  16. Jun 6, 2024 at 1:46 PM
    Ditto
    I guess I’ll find out :p
  17. Jun 6, 2024 at 6:35 PM
    HarrisNC
    HarrisNC New Member
    2022 Limited
    The commercial grade fire extinguishers we sale at work are rated from -65 to 120 degrees for an ABC and -40 to 120 for clean agents. I’ve definitely seen them used at higher than 120 degrees.
    I keep mine in the original box since it’s square and doesn’t roll around. I took different heavy duty brackets hook originally but never used them.
  18. Jun 7, 2024 at 8:16 AM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    An EMT I know said to wack the bottom of the extinguisher a few times with a rubber mallet every 6 mos or so. Keeps the stuff from solidifying/compacting.
    djwantke and R4Adventure like this.
