Factory style Trd pro wheels
Discussion in '5th Gen 4Runners (2010-2024)' started by titan34, Oct 27, 2021.
  1. Oct 27, 2021 at 6:55 PM
    titan34
    titan34 [OP] New Member
    Hawaii
    Hi
    Anyone has these factory style replica trd pro wheels 17x8.5 0 offset? If so you have any pics and how do you like them. I’m debating on going with the oem 21 trd pro wheels or these factory style reps since they are wider. Probably going to stick to 265 or 275 tires
    thanks
  2. Oct 27, 2021 at 7:03 PM
    If you're sticking with stock size tires than why not go with OEM TRD Pro rims?
  3. Oct 27, 2021 at 7:08 PM
    titan34
    Hawaii
    The oem is 17x7 vs 17x8.5
  4. Oct 27, 2021 at 7:11 PM
    Yes, but?
    4runnerTRDoffroad likes this.
  5. Oct 27, 2021 at 7:17 PM
    4runnerTRDoffroad
    4runnerTRDoffroad New Member
    2020 White TRD ORP
    Trd Pro wheels with Falken Wildpeak AT3 tires. Ceramic window tint. LED lights. Frontrunner 3/4 roof rack. Alpharex Luxx Headlights. Morimoto XB amber fog lights. Bilstein 5100 shocks front set at 1.75 and rear with a 1" cornfed spacer.
    Yea but what's the point of having a 17 x 8.5 if you are not going bigger than 275?
  6. Oct 27, 2021 at 7:19 PM
    Was it FN wheels or something that accepted Toyota center cap? I think whatever it was now discontinued. I think that one was a wider wheel which is recommended for bigger wheels. If I buy aftermarket wheel I would definitely go with known brand. Need some guarantee that it will not crack on trail runs.
  7. Oct 27, 2021 at 7:22 PM
    I think wider wheels will help against loosing bead? Because wheel is all most parallel to the width of the tire. Atleast what I was told in the past.
  8. Oct 27, 2021 at 7:47 PM
    I seen some tire/rim fitment chart posts here but don't remember the threads otherwise I'd attach to your thread.
    There has been discussions that 285 tires should be on a minimum of a 7.5" rim. Although many of us are running 285's on Pro 7" rims.
    I would say that if the tires you decide on 265/275, can be safely mounted on a 8.5" rim, then you should be good to go.
    Is it possible that by widening the tire bead width to a greater degree that you lose some of the benefits of contacting the tire sidewall rather than the rim when driving through tight trails?
    Roland likes this.
  9. Oct 27, 2021 at 7:54 PM
    titan34
    Hawaii
    I’m thinking a 8.5 vs 7 would have a different look on a 265/275
  10. Oct 27, 2021 at 8:03 PM
    Roland
    Roland New Member
    I have 285's on pro rims, no problem.
    DrewMan and TRD Toy like this.
  11. Oct 27, 2021 at 8:10 PM
    Question,
    Is popping a bead really a thing with modern tires?
    I've been reading 4Runner forums for several years now and not seen one post about popping a bead.
    I suppose if someone was running crazy low tire pressures then it would be a possibility, but if they are doing that, then maybe it's time to go with true beadlock rims.
    Roland likes this.
  12. Oct 27, 2021 at 8:31 PM
    Roland
    Roland New Member
    I'm running 16 Psi in Moab never had a problem.
  13. Oct 28, 2021 at 2:53 AM
    trouble_shooting
    trouble_shooting New Member
    Trig
    2021 TRD Off-road
    when it comes to rim width to wheel width. Tiresize.com is very helpful. You will see a given rim width to tire width fitment range. I like to be on the narrower side of the rim width. It creates a little buffer from curb rash on the wheels and when airing down less likely to break the bead.
  14. Oct 28, 2021 at 3:38 AM
    kami
    kami New Member
    Yep, have them. 0 offset, 265 KO2s and Eibach pro lift. They look great, ride great and are light. IMG_7342 2.jpg IMG_7343 2.jpg IMG_7344 2.jpg
    DrewMan likes this.
  15. Oct 28, 2021 at 10:04 AM
    FiReBReTHa
    FiReBReTHa New Member
    2014 4runner Trail
    -10 285s (did rub)
    pics in sig
  16. Oct 28, 2021 at 11:36 AM
    jetmechG550
    jetmechG550 New Member
    Frank
    2021 Off Road Premium
  17. Oct 28, 2021 at 3:40 PM
    TRD Toy
    TRD Toy New Member
    David
    20' Toyota 4Runner TRD OR
    Love the look. Just got a TRD OR 3 weeks ago. Yours stance is exactly what I'm looking for.
  18. Oct 28, 2021 at 5:17 PM
    Roland
    Roland New Member
    Thank you & welcome to the Forum from Texas. Congrats on the 4R.
    If you like the look & stance, you can duplicate it, my mods are on the bottom of my page. (lift & tires).
