Every dash warning light is on! Too cold?
Discussion in '5th Gen 4Runners (2010-2024)' started by 4Daughters, Jan 7, 2025.
  1. Jan 7, 2025 at 6:27 AM
    4Daughters
    4Daughters [OP] It’s how I know God has a sense of humor
    Ken
    Powder Springs, Ga
    2022 TRD ORP; Silver; too many port options...Ah well...
    TBD
    Woke up this morning to 16 degrees in the NC mountains and every dash warning light is on, and the dash screen is cycling through alerts. Video from iPhone won’t upload; screen shot here is just one of the warnings. ABS, pre-collision, blind spot, drive-start control. My 2022 ORP hasn’t been this cold before. Will this go away after the temp rises?
    werlyb23 likes this.
  2. Jan 7, 2025 at 6:40 AM
    Do you live in an area where critters might want to get up into the engine bay? Wire chewing is their favorite pastime, and is a cause of multiple warning lights.
    evank, Yotaholic, JR7 and 3 others like this.
  3. Jan 7, 2025 at 6:41 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    What a Christmas tree of lights.
    What gear is it in? Did you attempt to change gear when this happened?
    What a smart man would do is take it do the dealer and have them fix it. I am not a smart man.
    If I woke up to this I'd probably warm it up and attempt to get it fully in gear. 2wd, or 4hi doesn't matter. Whatever it was in when you last turned the car off is probably the best bet. This may require driving a bit and shifting back and forth if needed.
    Once in gear if the lights are still present I'd disconnect the battery and reboot the whole system.
    One of the solenoids may have malfunctioned or the system is stuck between gears. Or the system isn't reporting all of the solenoids position to be in the correct spot.
    All of these solenoids and position sensors have to work together in order to shift between 4High, 4Low, 2High. If something is not in the correct position you'll get a prompt like this on the dash.
  4. Jan 7, 2025 at 6:42 AM
    kouack
    kouack New Member
    Prov. Of Québec, Canada
    4Runner Limited 2024
    Bone stock
    16f too cold? this is like only minus 8 Celsius! so not too cold. I would let her warmup and shut it off, wait couples minutes and try again and See what happens. Mine already been in the 0F ( -30 c) no issue.
  5. Jan 7, 2025 at 6:46 AM
    I agree that it is a critter issue. They’re having this issue in Florida as well. It’s got cold and rats are jumping in the engine bay to get warm.
  6. Jan 7, 2025 at 6:51 AM
    4Daughters
    Ken
    Powder Springs, Ga
    TBD
    Thanks. I drove a few miles and it acted normally. Will try disconnecting the battery first and go from there.
  7. Jan 7, 2025 at 6:53 AM
    4Daughters
    Ken
    Powder Springs, Ga
    TBD
    Ha! Yeah, we southerners don’t like the cold. I’ll try a few things before going to the local dealer. Thanks
  8. Jan 7, 2025 at 6:53 AM
    4Daughters
    Ken
    Powder Springs, Ga
    TBD
    Critter is a possibility…it was parked overnight at a hotel, but ya never know…
  9. Jan 7, 2025 at 6:54 AM
    1SilverRunner
    Tejas
    Glad to hear it drives normally.
    The other guys are right, checking for rodents is a very good idea. If your at a loss for the issue taking it back to the dealer is recommended. Hopefully its something simple!
  10. Jan 7, 2025 at 6:59 AM
    They did a news report on it happening in Ft Myers. A repair shop said he advises customers to spray the engine compartment with a mixture of water and peppermint oil.
  11. Jan 7, 2025 at 1:22 PM
    4Daughters
    Ken
    Powder Springs, Ga
    TBD
    Local Toyota dealership in Boone (great folks) diagnosed a possible faulty left rear wheel speed sensor. Said its warning light can cause all the other warning lights also. Just enough uncertainty that it would solve the overall problem, so I declined the $475 replacement. Also talked to my local mechanic who said driving in slush can cause the issue. If the lights are still there when back in Atlanta, we’ll deal with it then. Thanks for all the feedback.
  12. Jan 7, 2025 at 2:14 PM
    1SilverRunner
    Tejas
    STrooper, Saker, KilluFirst and 2 others like this.
  13. Jan 7, 2025 at 5:13 PM
    mattkoz
    mattkoz New Member
    Interestingly, I had a similar issue just today as well. I was driving home in slush and snow and got the following errors:
    "Blind Spot Monitor Malfunction"
    "Rear Cross Traffic Alert Malfunction"
    "Drive-Start Control Malfunction"
    "Braking Power Low - Stop in a Safe Place" (my favorite)
    "Antilock Brake System Malfunction"
    "Pre-Collision System Malfunction"
    Headed to the dealer tomorrow. Will follow up with what they say.
  14. Jan 7, 2025 at 5:14 PM
    4Daughters
    Ken
    Powder Springs, Ga
    TBD
    Same exact list of errors I got. Looking forward to your follow up. Thanks.
  15. Jan 7, 2025 at 5:16 PM
    4Daughters
    Ken
    Powder Springs, Ga
    TBD
  16. Jan 8, 2025 at 1:02 AM
    STrooper
    STrooper Let’s Go Places!
    Wow, didn’t know those sensor cover existed, that’s a great idea to protect them from the elements!
  17. Jan 8, 2025 at 5:12 AM
    4Daughters
    Ken
    Powder Springs, Ga
    TBD
    Update: cranked it up in 16° and snowing, and the lights were off. Amen! Pulled out of the hotel and the lights came back on. Drove about a mile and the lights went back off. Yesterday I disconnected the battery waited about 10 minutes and reconnected it. Maybe the ECU is resetting itself. Toyota have self healing powers. :) Will give more updates later.
    Yotaholic and 1SilverRunner like this.
  18. Jan 8, 2025 at 5:37 AM
    Sioux
    Sioux New Member
    Wisconsin
    2020 TRD Off Road
    I can't imagine that was caused by the cold. It was -16f here more than one day last week and it started and ran fine. (as I'd expect it to). Just don't drive it hard until it gets a chance to warm up a little. I'd run codes and see what it's reporting.
    4Daughters[OP] likes this.
  19. Jan 8, 2025 at 6:02 AM
    BgBmBoo
    BgBmBoo New Member
    Kansas
    The safety systems that utilize the front sensor will shut down when it is blocked. I've had the same experience when there is freezing rain/slush coving the sensor. Hopefully that was your issue as well!
  20. Jan 9, 2025 at 3:54 PM
    mattkoz
    mattkoz New Member
    Right rear wheel speed sensor was the issue. There were no signs of physical damage, but it was not responding to the computer. Replacing the harness fixed all the errors. ~$460 repair. Luckily it was covered by the 3-year/36k-mile warranty.
  21. Jan 9, 2025 at 7:16 PM
    4Daughters
    Ken
    Powder Springs, Ga
    TBD
    Similar quote at the Boone dealership, but I’m out of warranty. Took it to my local mechanic when I got back into town this afternoon and he could not clear the code because there is a short in the left rear wheel speed sensor. I’ll inspect it this weekend. It will have to be repaired. Thanks for the follow up.
  22. Jan 9, 2025 at 11:31 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Nah, it is not the cold weather. Mine has seen much worse in North Dakota. Something is wrong with the truck, rodents' work?
  23. Jan 13, 2025 at 3:09 PM
    4Daughters
    Ken
    Powder Springs, Ga
    TBD
    We have a resolution! I replaced the left rear wheel speed sensor and disconnected the negative battery cable for about 10 minutes. After driving about 150 miles, the light show is over! Went with the CarQuest sensor (part number ARC1067) from Advance Auto, $145 with on-line discount code. Dealership wanted $475. Thanks for all the feedback.
    Steely123 and 1SilverRunner like this.
