Engine won't turn over.
Discussion in '4th Gen 4Runners (2003-2009)' started by Buildintoys, May 15, 2025.
  1. May 15, 2025 at 11:35 AM
    Buildintoys
    Buildintoys [OP] New Member
    Ol Man EMU suspension lift , ARB Brush guard/Warn winch, Bilstien 6500 shocks
    I own a 2004 4 Runner with 236,000 miles. It has been maintained very well. My problem is that the other night I went to the store and back and parked it. The next day I went to start it and all the lights radio PW's work , and can also hear something under the hood being run for several seconds 12.4 volts on a 1 year old Die Hard battery. I had someone turn the engine over with the brake depressed and had 0 voltage at the starter solenoid wire. All regular fuses and fusible links are good. In the power distribution box under the hood there is a space for a IG relay that you can tell has never been used. Attached to the side of the Fuse box is another small box with 2 brown relays in it that are not labeled under the cover and are held in there so tight I can't get them out. Any Idea what these 2 are? I'm thinking possibly Ignition and Starter relays. I'm thinking one of those or the ignition switch. Also, IT will not crank over in neutral. Any help would be very much appreciated. I hope I am posting this in the right place as I'm new to your Forum.
  2. May 15, 2025 at 12:00 PM
    Do you have another key you could try? On my 2007, I had a transponder chip fail and it exhibited as similar situation.
    I am sure others will add some additional possible scenarios.
    Buildintoys[OP] likes this.
  3. May 15, 2025 at 12:58 PM
  4. May 15, 2025 at 4:14 PM
    Buildintoys
    No i recently lost the original key to it kept telling myself to go get another one made before this all happened.
  5. May 16, 2025 at 10:24 AM
    welcome
