Engine whining noise
Discussion in '4th Gen 4Runners (2003-2009)' started by runnergal, Nov 3, 2024.
  1. Nov 3, 2024 at 12:59 PM
    runnergal
    runnergal [OP] New Member
    1997 4Runner
  2. Nov 3, 2024 at 9:13 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Does it change with RPM?
    My guess a bearing on engine front. Do you have serpentine belt? Generally easy to take off. Carefully sketch or photo its exact pattern. Find the tension and idler pullies. Following procedure ease tension and slip belt off.
    Spin by hand the tension pully feeling for noise, roughness or wobble etc. then spin idler pully & check same.
    Then inspect water pump (not sure about 4th gen), Alternator, power steering pump.(do not know details of 4th gen) maybe have their own belts?
    Hopefully you can find a worn out noisey bearing.
  3. Nov 8, 2024 at 6:51 AM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Agree with the above re: possibly a belt pulley bearing. How many miles on your truck?
