Engine Troubles with my '07 4.0L
Discussion in '4th Gen 4Runners (2003-2009)' started by ElDreezy, Jul 29, 2021.
  1. Jul 29, 2021 at 9:22 AM
    ElDreezy
    ElDreezy [OP] New Member
    2007 4th Gen 4runner 4.0L
    3" lift, Bilstein Rear Shocks
    Hey all, new around here. I've had my runner for about a year now and have had my share of problems with it. Apparently the cylinders were bad so I ended up having the engine replaced. However shortly after having it replaced I started having the same/similar issue.
    Problems:
    - Christmas Tree Dash Lights
    - Feels under powered
    - When putting my foot down to accelerate in higher gears is shift funny and bogs down/rumbles, I have to release the accelerator and push down again to get it to change into a lower gear for more acceleration, and even then it doesn't feel strong.
    - I smell gas pretty heavily
    - This occurred about a month after getting the engine replaced, in that time it drove fine.
    Any help or thoughts would be appreciated, I have pulled the codes from it a few times and it either says cylinder misfire which is what I was getting before the swap, or a cat problem.
    Thanks!
  2. Jul 29, 2021 at 1:25 PM
    iamincrediboy
    iamincrediboy New Member
    South FL
    Gas cap loose? Leak in the fuel lines? Failed fuel filter? Fuel pump? Transmission electrical input/servo issue? Any codes thrown when reading the OBD II port? What did the mechanic say when you were fixing to replace the first engine?
  3. Jul 29, 2021 at 7:19 PM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    I would take it right back to those who replaced your engine and let them figure it out on their dime. Should be under warranty if you got one.
    Letsflyman likes this.
  4. Jul 30, 2021 at 12:35 AM
    Letsflyman
    Letsflyman New Member
    96 Tacoma 400k running strong
    What he said. If what you've told us is true, common sense would dictate that you take it right back to the shop that did the work.
    Anything else is simply chasing your tail.
    Toy4X4 likes this.
  5. Jul 30, 2021 at 1:25 AM
    Mtbpsych
    Mtbpsych New Member
    Check and clean the mass air flow sensor.
  6. Aug 2, 2021 at 12:40 PM
    ElDreezy
    Hey all sorry for the late reply but thank you for all those who replied.
    Unfortunately the troubles started right after the warranty expired for the engine (go figure).
    I have since replaced my gas cap to see if that was the cause and its still quite loose, thinking I might have to replace the fuel fill neck.
    As for the codes I pulled I'll have to run it again to get the specifics and I'll report back on that. Today I'm going to try chasing the fuel lines to see if there are any kinks or pinches, thinking the engine might be running to lean or starved of fuel, and also going to clean the MAF. Thanks all!
  7. Aug 2, 2021 at 12:42 PM
    ElDreezy
    When replacing the engine the first time the mechanic I took it too said that a couple of my cylinders/valves were messed somehow and it would be cheaper to get a new engine than pay for all he labor of a valve and cylinder job.
    But I was picking misfire codes on the old engine from multiple/random cylinders.
  8. Aug 5, 2021 at 8:09 AM
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    Eldrez... how many miles on your 4runner when the problems started? And what problems did you have? Can you be more specific?
    I have a 2005 with 170,000 miles and have owned it since new, and it's been trouble-free. OEM tranny and engine.
    My 4runner has never tripped a code! Doesn't use oil or burn any. I'm hoping for another 150,000 trouble-free miles from here.
  9. Aug 6, 2021 at 10:16 AM
    Toy Yoda
    Toy Yoda New Member
    That's pretty specific...
  10. Aug 18, 2021 at 5:04 AM
    importman
    importman The mountains are calling and I must go...
    Danny
    Carolinas
    05 Silver SR5 V6 4X4
    Blacked out, Ironman 3" Nitro Gas Suspension lift, JBA High Caster upper control arms, Differential drop and sway bar relocate, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX100 with Apple Carplay, USB Jack, Backup Camera, Black TRD Pro Wheels with General Grabber ATX 265/70/17, Rear differential vent extension, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Weathertech floor mats, Homemade rear storage compartment with built in pull out table.
    Just FYI, a bad gas cap can and will cause the check engine light to come on, but it won't affect the running.
    Toy Yoda likes this.
  11. Aug 19, 2021 at 12:30 PM
    mr5vtps
    mr5vtps New Member
    Charles
    2008 Titanium Metallic 4x4 Urban Runner
    When replacing the gas cap i use oem cap. Never had any luck with aftermarket ones
  12. Aug 6, 2022 at 9:37 PM
    NebraskaRunner
    NebraskaRunner New Member
    07 SR5 4wd Salsa Red
    2-3” lift, rear bags, trans cooler, 275 70 17 on 5th gen wheels
    Last year driving into Wyoming that same thing happened. We attributed it to bad gas. We finished our trip driving to Idaho and had been fine since- until right now. Driving into Wyoming again and same thing except this time we have a camper!
    Both times it was hot, 90+ and around 4-5k feet elevation. We actually turned around and started driving back to Nebraska this time. Seemed like it got better so we turned around and made it to Laramie. We’ve been driving around all week in the mountains and it hasn’t done it again. Still feels under powered though. Brought my scanner this time. Did get a too lean dtc while it was doing its no power thing.
    I was thinking clogged cats or bad/clogged fuel pump. I replaced the fuel pump a couple years ago, ran it with it not working completely and suspect I damaged the cats then? I’ve searched a lot for this since last year and you’re the first person that seems to have had the same experience or at least worded it the same- haha. Please post your conclusion and will for you as well. Hopefully we make it back to Nebraska without issue this time, its downhill so hopefully. Haha
    Best of luck!
