Engine Performance
Discussion in '5th Gen 4Runners (2010-2024)' started by mrsocal2012, May 17, 2021.
  1. May 17, 2021 at 5:05 PM
    mrsocal2012
    mrsocal2012 [OP] New Member
    2015 4Runner SR5 Silver. Like new with 27,000 miles
    LED lights
    Hello,
    My 2015 4Runner has 29,000. Bought it six months ago with 26,000 miles from first owner.
    I noticed something unusual, once I change the oil, the 4Runner becomes very responsive and smooth. Few hundred miles later precisely after 500 to 600 miles the engine becomes sluggish and lacks being responsive.
    Could there be something wrong with the engine? Your thoughts please.
    Thanks
  2. May 17, 2021 at 9:15 PM
    mrsocal2012
    LED lights
    I'm concerned because the car was not driven much by the first owner and that may have caused sludge build up which in turn causes
    the oil to break down fast and affect performance. Could that be possible?
  3. May 17, 2021 at 9:48 PM
    Mtbpsych
    Mtbpsych New Member
    I’m guessing you have only done one oil change since you’ve only had the 4runner for 3,000 miles. Did you put the correct amount of oil in? Changed out the oil filter and installed everything back correctly?
  4. May 18, 2021 at 5:18 AM
    importman
    importman The mountains are calling and I must go...
    Danny
    Carolinas
    05 Silver SR5 V6 4X4
    Blacked out, Ironman 3" Nitro Gas Suspension lift, JBA High Caster upper control arms, Differential drop and sway bar relocate, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX100 with Apple Carplay, USB Jack, Backup Camera, Black TRD Pro Wheels with General Grabber ATX 265/70/17, Rear differential vent extension, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Weathertech floor mats, Homemade rear storage compartment with built in pull out table.
    I can't think of any scenario where changing the oil would give you a noticeable difference in performance. If the oil was broken down to the point that you had friction that could restrict the rotation of the engine it would destroy itself in short order. I think it's psychological. JMHO
    A&P, Mtbpsych and canadian.bacon like this.
  5. May 18, 2021 at 7:19 AM
    mrsocal2012
    LED lights
    I changed the oil four times. The engine started and accelerated very smooth after every oil change. Then after about 600 miles it became sluggish. That happens consistently 500 to 600 miles after every oil change.
    The first oil change was done by the dealer, second by my mechanic third and fourth by me.
    Used 0W-20 oil, 6.6 quarts and Toyota filter.
    Mobil 1, Valvoline and the last oil change I used AMSOIL all synthetics. Had the same sluggish response with every oil. Valvoline was the longer lasting smooth performance.
  6. May 18, 2021 at 8:12 AM
    Mtbpsych
    Mtbpsych New Member
    The oil was changed four times within 3,000 miles? Interesting. I have to agree with above that it could just be a psychological feeling. If you’re convinced somethings wrong have a trusted shop/dealer check it out, it would be a first for me to hear about engine performance issues linked to an oil change.
    A&P, Thatbassguy and importman like this.
  7. May 18, 2021 at 8:19 AM
    importman
    Danny
    Carolinas
    Starting to get the feeling we're being trolled. 4 oil changes in 3K miles?
    Tuco S., A&P and Thatbassguy like this.
  8. May 18, 2021 at 8:42 AM
    What does the oil look like coming out?
    This seems like a very unusual issue. I can't imagine what would cause it.
  9. May 18, 2021 at 8:53 AM
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    So.... OP has had it 3000 miles.
    Uh....
    This might be the most charitable comment I've read all day.
    No one believes there is or could be a reason for the engine to perform well on a fresh oil change then become sluggish after 500-600 miles.
    2Toys, A&P and importman[QUOTED] like this.
  10. May 18, 2021 at 11:21 AM
    mrsocal2012
    LED lights
    This happenes consistenly after about 600 miles, not after 200, 300 or 400 miles.
    I think something is going on with this engine. I thought being such low mileage in five years, not driven much and maybe the oil was not changed on time has to do with this issue. Sludge perhaps. I didn't get maintenance records from original owner, he may have not changed oil on time.
    The oil comes out darker than usual for such an early oil change.
    I have three other Toyotas with no issues. I had a 2015 Tacoma and it didn't have that issue either.
    I took it in and was told that the issue can not be duplicated the reason I posted here hoping for an answer.
    Thanks
  11. May 18, 2021 at 11:51 AM
    ^^^^this! Good call!
    Mtbpsych likes this.
  12. May 18, 2021 at 3:19 PM
    mrsocal2012
    LED lights
    My mechanic checked codes and they were all fine. Sure, I'll ask him to do a compression test.
    Thanks
  13. May 18, 2021 at 4:38 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    2Toys, A&P, SlvrSlug and 2 others like this.
  14. May 18, 2021 at 11:55 PM
    mrsocal2012
    LED lights
    That's a good idea. I ordered the kit.
    Thanks
