Engine Oil and Trans. Fluid Change Intervals
Discussion in '5th Gen 4Runners (2010-2024)' started by rickystl, Jan 3, 2025.
  1. Jan 3, 2025 at 7:46 AM
    rickystl
    rickystl [OP] New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    Hello ALL. Happy New Year.
    Subject: 2021 Toyota 4Runner ORP.
    I'm sure this subject has been beaten to death in the past. But I wanted to run this by you all for your opinions. I retired from work in January of 2022. So I am now putting about half the annual mileage I did in 2021, my last year working. So my more recent experience shows I will probably log only about 6-7K miles a year. So just a couple questions:
    1. I'm currently changing the oil and filter every 5K miles. But it will take me close to 3/4 of a year to get to 5K. Is that OK ? Or should I look at doing it by months ?
    2. Transmission Fluid Flush/Change. I know what the owner's manual says. But I was planning to have this done anyway at 30K miles, which will be closer to the end of this new year. Would this be considered prudent ? Or should I wait ? I figure it can't hurt.
    Thanks for any opinions.
  2. Jan 3, 2025 at 7:54 AM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    Happy new year, Rick. Sounds like you already RTM, congratulations.
    You're retired, and working on the car is probably a hobby, so I'd say do whatever makes you happy. I'm willing to bet the car wouldn't care if you went 18 months / 10,000 miles between changes, but what you're doing now is fine. The oil isn't going to break down from the car just sitting (think of how long it sits on the shelves, or how long it's been underground).
    If you're dead set on 30k for the transmission, I'd suggest just doing a pan drain and fill each time. 60k is the recommended interval for a fluid change if you tow a lot (which it doesn't sound like you do), so anything at 30k is just gravy, so a drain and fill would be more reasonable on your wallet and the environment. Again, I bet you could get away with never changing it, but it's your time in the garage, not mine.
    You can do damage with too frequent transmission services if you screw up the fluid level, so I'd say first and foremost, make sure you understand and are comfortable with the fluid level check procedure. Maybe even buy an UltraGauge or similar s you can see the exact temps, and also to geek around with for other vehicle measurements.
  3. Jan 3, 2025 at 8:08 AM
    60K miles for the trans.
    Stoney Ranger and rickystl[OP] like this.
  4. Jan 3, 2025 at 8:09 AM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Oil in an operating engine is not the same as stored in containers on a shelf. Oil is hygroscopic for one thing. There is always some blow bye and water vapor is a bi-product of combustion. Then there are driving patterns. If you make a lot of short trips your engine runs rich on startup and oil can become contaminated by fuel if you don't take longer trips at temperature (which will also boil off water in oil).
    I'm putting just under 5K miles on my 4Runner each year, change engine oil annually and make a point of min half hour freeway runs every couple of weeks if that didn't happen with normal usage.
    I'd say 30K on the trans fluid is overkill but you aren't hurting anything.
  5. Jan 3, 2025 at 8:22 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    60-100k on the transmission depending on use.
    If you're running very high temperatures going for shorter intervals is not a bad idea.
    I've got my transmission temp to 275 before. Came home and swapped the fluid out.
    I was at 35k miles at the time, but that fluid was definitely burnt.
  6. Jan 3, 2025 at 9:13 AM
    I would stick with the 5K oil change or once a year.
    Changing the transmission fluid at 30K seems like a huge waste. I’m at around 115K and still on the original fluid without issue. I’ll change it in the spring along with the diffs and spark plugs.
    Nhmountainman and rickystl[OP] like this.
  7. Jan 3, 2025 at 9:37 AM
    java
    java fauxrunner
    2023 ORP ice cap
    I do engine every 4-5k. TC was ar 17k. Planning trans at 30k as well.
    captrussia253 and rickystl[OP] like this.
  8. Jan 3, 2025 at 9:46 AM
    2016Pro
    10k oci any brand synthetic oil drive it 500k miles
    rickystl[OP] likes this.
  9. Jan 3, 2025 at 9:52 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    I’ve never gone by the months over miles for oil changes theory.
    if you barely drive, change it once a year.
    trans is 100k for me. No flushes. A true dealership or very trustworthy shop that has a fluid exchange system and will pump in 10-11 fresh quarts
  10. Jan 3, 2025 at 11:40 AM
    Can I ask why 30K for the trans? Where is this info even coming from? I’ve never owned any vehicle that required anything even close to that.
  11. Jan 3, 2025 at 12:21 PM
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    It won't hurt to drain and fill tranny [severe use use to be at 30k], just do it correctly. Oil is cheaper than parts. I used to overhaul transmissions and fluid is a major failure causer [dirty/abrasive contamination]. If miles are going to be low annually, go by time and not miles on engine oil. I would personally do oil changes spring and fall. I would also throw in a coolant change now. Once you have tranny and coolant changed you most likely will never have to do them again, if you keep miles low. Coolant becomes acidic and causes a lot of gasket failures. In the past gasket material was better and seldom failed. In today's ENVIREMENTAL world the material has changed and not necessarily for the better. If you have time and want to, go to a major truck shop and ask where they get their PH strips for testing coolant acidity. Simple test; again coolant is cheaper than gaskets to maintain. Bottom line, it's your vehicle and maintain it how you want to.
    rickystl[OP] and 2021venture like this.
  12. Jan 3, 2025 at 12:41 PM
    rickystl
    Rick
    St. Louis, MO
  13. Jan 3, 2025 at 12:50 PM
    Who is he and why do we care what he says?
    If changing the transmission fluid that often was even remotely necessary then Toyota would say it in the service manual and the dealerships would be pressing people to get it changed. They would not want to miss out on that potential income.
    rickystl[QUOTED][OP] likes this.
  14. Jan 3, 2025 at 12:54 PM
    I know a vast amount of Dealerships try to work this in on a 30k service. Maybe the Dealership attempted to push it on their "Scheduled Maintenance".
  15. Jan 3, 2025 at 1:13 PM
    jeepster09
    Twin Cities MN
    4Runner 2008 Sport
    A lot of factory maintenance schedules are developed as a MARKETING TOOL. "Our vehicle only costs XX dollars every XX miles to own, our competitors cost XX more to own". Years ago they actually had commercials stating such. Many vehicles will make it with little maintenance; most people get rid of vehicle after 3 or so years because they want the NEWEST trend/color. If you plan on holding on to your vehicle for some time MAINTANE it.
  16. Jan 3, 2025 at 1:21 PM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Many people are interested in lowest cost of maintenance not what is best for longevity. Almost doing nothing will get you thru warranty. If your in the salt belt and it's going to rust out in 10 years it might not last long enough to justify it. The constant debate X maintenance not needed vs others planning on keeping 20 years it's cheap to do it yourself.
  17. Jan 3, 2025 at 1:40 PM
    Have any of you seen any 5th gen’s with failed transmissions? I would imagine most people do no maintenance to their transmission at all.
    2016Pro likes this.
  18. Jan 3, 2025 at 1:51 PM
    I don’t think they are going to promote a maintenance schedule that is going to cause a mass failure in vehicles. That would be pretty bad for marketing.
    2016Pro likes this.
  19. Jan 3, 2025 at 2:14 PM
    In my completely unprofessional opinion, 30k (+/- 5k) mile drain/fill intervals are exclusively for CVTs of the variable pulley persuasion but I might personally push up my drain/fill to 50k for no reason but to make myself feel better or if I'm bored.
    Either way, doing fluids too soon really only hurts your wallet, time.
  20. Jan 3, 2025 at 2:22 PM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    You people and your silly ass drain and fills :crapstorm:
    Do you drain some of your engine oil and mix in new oil, too?
  21. Jan 3, 2025 at 2:26 PM
    Startrek
    Startrek New Member
    - keep going to 200K, and after that you don't have to change it EVER
  22. Jan 3, 2025 at 3:00 PM
    Gumpus
    Gumpus New Member
    Just to reinforce...
    Go by mileage, not time. Changing your oil every 6-7000 miles is just fine.
    Leave your trans oil until at least 60k. Mine was changed at 60k and my mechanics told me it looked good and didn't really need to be changed. Waiting until 100k should be no problem at all.
  23. Jan 3, 2025 at 3:04 PM
    Do you know the difference between the purpose of engine oil versus transmission fluid. One is involved in explosions and one isn’t. Guess which one?
  24. Jan 3, 2025 at 3:07 PM
    It will get a drain and fill in the spring and that will probably be it for the rest of the life of the vehicle. That will freshen up the additives in fluid but not remove too much of the particulates that keep the trans happy. Rust will most likely kill it before the trans or engine fails.
  25. Jan 3, 2025 at 3:14 PM
    2021venture
    Todd
    2021 Venture
    I don't think there is a one size fits all depending on mods and use. Total stock 4r only driven city streets by soccer mom will be totally different than one with mods and used off road or climbing mountain passes. Anyone wondering on how often to change should have an idea on what temperatures they are experiencing. Heat rapidly degrades ATF and is most common cause of failure.
  26. Jan 3, 2025 at 3:24 PM
    I’ve heard the same thing about not changing the trans fluid out too frequently because the suspended clutch particulates actually help preserve the clutch linings or at least improve their performance.
  27. Jan 3, 2025 at 3:31 PM
    Yes. The particulates help the clutch plates engage as they get older. If you completely replace all of the fluid you can create issues with slipping.
  28. Jan 3, 2025 at 3:41 PM
    Well ackshually, there's still old oil running around in the engine anyway! (I know it's not half though! but if we get to high enough age where the engine is leaking consistently and being topped off, you could call that the perpetual oil change ;))
    I'm just Ship-of-Theseus-ing it, choosing shorter intervals over flushes.
    "Can you tell which is which?"
  29. Jan 3, 2025 at 3:57 PM
    jeepster09
    Twin Cities MN
    4Runner 2008 Sport
    Well as a former master tech, service manager and vehicle warranty auditor, I have NEVER had an engine or mechanical failure due to maintenance issues. Fluids are cheaper than parts.....or as the INTERNET EXPERTS will say.....SAVE SOME MONEY and don't change them so often. I don't care which way others want to do it. I know what saves MORE money in the long run. :crapstorm:
    Gracio, java and 2021venture like this.
  30. Jan 3, 2025 at 3:57 PM
    2021venture
    Todd
    2021 Venture
    Is this an argument for drain/fill not full ATF replacement? I have always been told the drain/fill refreshes the additive pack.
