Engine Air Filter
Discussion in '5th Gen 4Runners (2010-2024)' started by Woody88, Jul 10, 2020.
  1. Jul 10, 2020 at 5:00 AM
    Woody88
    Woody88 [OP] New Member
    2011 4Runner SR5
    Winch
    In your opinion, what would be the best engine air filter for a 5th gen 4Runner SR5 ?
  2. Jul 10, 2020 at 5:55 AM
    Woody88
    2011 4Runner SR5
    Winch
    I hear about K & N performance filter but as far as I know it is not all positive as it requires more maintenance due to it's oily characteristic. Sure maybe oil traps more dust. But at the same time, it gets dirty a lot faster. Also K & N claims to add more power to the engine. Well, that is not a concern at all to me. Therefore, I will do like you and stick to the Genuine Toyota regular filter ... unless someone can convince me with another product. I always keep an ear out for people's opinion ... and FACTS if possible. Thanks.
  3. Jul 10, 2020 at 5:57 AM
    Woody88
    2011 4Runner SR5
    Winch
    BTW, how often do U change the filter (kms) ?
  4. Jul 10, 2020 at 7:33 AM
    Best to change it when it is dirty, mileage really doesn’t matter.
    A&P and 7385 like this.
  5. Jul 10, 2020 at 8:06 AM
    Mtbpsych
    Mtbpsych New Member
    OEM.
    If you never drive on anything other than pavement I would change it every time you change your oil. If you off-road and are stuck behind people then I change mine every 3-5k miles depending how much dust the engine ate.
    A&P likes this.
  6. Jul 10, 2020 at 8:38 AM
    Living the dream
    Living the dream New Member
    ABQ
    2019 T4R Off-Road KDSS
    Blue 4ever Runner and alittleoff like this.
  7. Jul 10, 2020 at 9:02 AM
    Woody88
    2011 4Runner SR5
    Winch
    Mtbpsych,
    when you mention changing filter every 3-5k miles, you are referring to the engine OIL filter, right ?
    I was asking about engine AIR filter ...
  8. Jul 10, 2020 at 9:11 AM
    Living the dream
    ABQ
    Toyota owners manual says every 30k, depends on your driving habits, if your driving dusty fire roads or out in the desert then you would change it my frequently.
    The owners and maintenance manual are a wealth of information. Download the Toyota owners app.
    Plug in your vin and it’s all right there on your phone. It’s free.
    A&P likes this.
  9. Jul 10, 2020 at 9:16 AM
    Woody88
    2011 4Runner SR5
    Winch
    I know all that. I just wanted to know what other peeps do in every day life.
    I don't like to change/replace parts for no good reason as the part is still in good running order.
    Thanks anyway.
  10. Jul 10, 2020 at 10:03 AM
    Mtbpsych
    Mtbpsych New Member
    Yes I replace my engine AIR filter that often when I off road in dry dusty conditions. Every tine I change it it’s gunked in dirt. Sounds like you don’t hit anything but the pavement so you’re good.
    A&P likes this.
  11. Jul 11, 2020 at 3:13 AM
    Woody88
    2011 4Runner SR5
    Winch
    When you do change the engine air filter, does any of you notice a change of any kind at all (i.e. performance, fuel consumption, etc) ?
  12. Jul 11, 2020 at 10:13 AM
    Glenn Goodlett
    Glenn Goodlett New Member
    Glenn
    2020 TRD Pro
    Paid for
    If you notice a change in performance, you were late in changing your air filter, way late.
    I change my air filter at every oil change at 5000 miles, but I drive off road in dusty conditions every day.
    7385 likes this.
  13. Jul 11, 2020 at 11:58 AM
    Randy H.
    Randy H. New Member
    Crew Chief
    Nevada and Utah
  14. Jul 11, 2020 at 11:59 AM
    Randy H.
    Randy H. New Member
    Crew Chief
    Nevada and Utah
    I think I will install a Cold Air intake. That way I can see the filter and clean or replace as necessary.
  15. Jul 12, 2020 at 1:16 AM
    Woody88
    2011 4Runner SR5
    Winch
    Does installing CAI require engine tuning adjustments ?
  16. Jul 12, 2020 at 5:20 AM
    Randy H.
    Randy H. New Member
    Crew Chief
    Nevada and Utah
    You don't have to do anything when you use a CAI, although I believe most tuners will ask if you have a CAI. I used a tuner to correct my speedometer on my jeep due to tire size, and it asked the question.
  17. Jul 12, 2020 at 5:26 AM
    Woody88
    2011 4Runner SR5
    Winch
    That would make sense as speedometer and tire size and linked. Thanks.
  18. Jul 14, 2020 at 10:35 PM
    bautistasamuel
    bautistasamuel New Member
    You can try K&N filter. It is providing quality product.
  19. Jul 15, 2020 at 2:21 AM
    Woody88
    2011 4Runner SR5
    Winch
    I looked into the possibility of going with a K&N filter.
    Unfortunately, even though it has it's advantages, it also has many disadvantges.
    Considering everything specific to my personal situation, I finally chose to stick with TOYOTA OEM.
    SlvrSlug and 7385 like this.
  20. Jul 15, 2020 at 6:11 AM
    bautistasamuel
    Hope it will work good for you.
  21. Jul 15, 2020 at 7:00 AM
    abner
    abner New Member
    OEM
  22. Jul 15, 2020 at 10:37 AM
    MAXIM
    MAXIM New Member
    OEM Toyoata intake is already COLD AIR Intake. Other than silencers and reservoirs in it's tubing it is not a bad intake. As for filter - you can't go wrong by sticking with original Toyota part.
  23. Jul 15, 2020 at 10:53 AM
    Woody88
    2011 4Runner SR5
    Winch
    Great thinking. I couldn't figure out why oem was not cold air. It is !!
    And yes, can't go wrong with oem parts to keep everything in balance.
  24. Jul 15, 2020 at 12:47 PM
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    Dasaíta HU, Bilstein 5100s, AT Tires, Coveted grill lights
    I go with whatever local parts store has in stock and change my air filter every time I change the oil. It is extremely dry and dusty in CA during the summertime so I don't mind changing it more often.
